Old Dec 29, 2004, 02:43 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Question
Steve Nolan (eBird) -- Please help me choose a brushless power system
Okay, after flying my Slow Stick for two months, I'm ready to spend the dough (roughly $150 for the motor/gearbox/ESC combo) to upgrade to a brushless / LiPo setup.
I know from an earlier post, you use a PJS 800 motor (I'm not sure what that is), with a Tanic 2150 (3s?) pack.
I just spent a bunch of dough on an Air Devil P-38 kit. It uses Himax 2025-4200 motors, with a Cobri 20 gearbox (5.61:1 ratio), Phoenix 25 ESC, and Tanic 3s 2150 LiPo. I would LIKE to keep with the same equipment so I have interchangable parts.
On the other hand, I like the idea of getting away from the gearbox... Does the PJS 800 motor require a gearbox?
I have a small stash of GWS 1390 props I use currently -- I'd like to continue to use those, if possible, but it's not the end of the world if I need to move on to something else...
I'll be hauling a Pentax Optio S40 camera. I think that's all the information I can give you... Can you please help me choose a good power system? I've only been doing this for about two months now, and I want to make sure I get it right the first time.
Thanks so much,
Guy
Red 61 is offline Find More Posts by Red 61
Last edited by Red 61; Dec 29, 2004 at 02:43 PM. Reason: Subscribed to my own thread. Duh! :P
Old Dec 29, 2004, 03:52 PM
uniquewon is offline
Find More Posts by uniquewon
uniquewon's Avatar
Minneapolis
Joined Jun 2002
I know steve will chime in here but my suggestion is to get the PJS 800 and use plugs to hook it to the ESC and then put plugs on your PX25 and then you can leave the PJS on the SS and just switch the ESC, pretty easy. The battery will work from your P-38 real well. I see you only having to buy the PJS800 and some plugs, Hobby-Lobby has some nice plugs you can get along with getting the motor there. The plugs are MJ21021 and you get three sets, you need more than three sets cause you'll need to put them on the P-38 motor also. I use these plugs on all my stuff, the small ones on the 12amp and under and the medium ones for anything in the 20 - 25 amp range.
Check out the Hobby Lobby site and then maybe shop around for the motor, maybe you can get it cheaper else where cause I see they want $98 for it. The value of out $ has done that for us...
I'm sure Steve has some input but I chime in here because I use the PJS800 on my SS camera plane and its perfect. No gear box...
Gene
uniquewon is offline Find More Posts by uniquewon
Old Dec 29, 2004, 04:18 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Hmmm... To put it simply, I guess my main question is, "What prop would I put with the following setup to haul a Pentax Optio S40?"
PJS 800 motor
Tanic 3s 2150 LiPo
Phoenix 25 ESC
...and a follow-up question is, "What gearbox/prop combo would I use with the following setup to haul a Pentax Optio S40?"
Tanic 3s 2150 LiPo
Phoenix 25 ESC
Sorry to make it so complicated before -- lots of people tell me I'm "windy"...
Old Dec 29, 2004, 04:33 PM
uniquewon's Avatar
Minneapolis
Joined Jun 2002
Yep, they're right.
My setup goes at 30 oz and I use the APC Electric Flight 10 x 5 prop, amp draw under full power is around 20 amps but it's hauling the SS close to straight up.
I cannot suggest a prop for the gear drive, don't know much about that one. I really like the PJS800 because it's so smooth and quiet. You will need to balance the prop real well as you're turning up pretty good RPM and to take pictures while under power, the way mine are all taken, requires a good balance job on the prop.
Old Dec 29, 2004, 08:15 PM
4 stroken ron is offline
Find More Posts by 4 stroken ron
4 stroken ron's Avatar
Grinnell Ia.
Joined Sep 2003
Gene,, How much flight time do you get with the PJS 800 and 2150 batteries?
I am assumeing it is a 3 cell pack?????
Ron
4 stroken ron is offline Find More Posts by 4 stroken ron
Old Dec 29, 2004, 08:43 PM
uniquewon's Avatar
Minneapolis
Joined Jun 2002
Ron,
I get probably more than 10 mins, more time than I need to shoot lots of pictures. I use Tanic 2600 3S packs. I do have a 2200 and it's fine also, little shorter duration but most often I'm down before the pack shows any drop because I play it real safe.
Old Jan 01, 2005, 10:22 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Is that 10 minutes at full power (WOT), or are you using some throttle management?
Old Jan 02, 2005, 10:31 AM
TrappedinNM is offline
Find More Posts by TrappedinNM
All posts Copyright '07
Joined Sep 2004
PJS 800 motor
Tanic 3s 2150 LiPo
Phoenix 25 ESC
Tanic 3s 2150 LiPo
Phoenix 25 ESC
With the same PJS/ESC setup, I use an 11x4.7
TrappedinNM is offline Find More Posts by TrappedinNM
Old Jan 02, 2005, 12:26 PM
uniquewon's Avatar
Minneapolis
Joined Jun 2002
Wot Not
I only use full throttle for a few seconds during takeoff, the rest is half or less. Remember,the setup has PLENTY of power, needed to climb out of tight spots.
Old Jan 02, 2005, 01:03 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Hmmm -- I was really hopeing for more flight time than that... I'm getting at least 10 minute flight times out of my 8-cell 1050 mah KAN pack. I figured doubling the mah to a 3s 2150 mah LiPo pack would roughly double my flight time...
Old Jan 02, 2005, 03:15 PM
eBird is offline
Find More Posts by eBird
Look! Up in the sky!
eBird's Avatar
Grand Junction, Colorado
Joined Jul 2002
I get very satisfactory flight times out of my Tanic 2150 packs.
I generally fly two 15 minute AP sorties with one battery. When charging, the battery rarely accepts more than 1400 mah meaning I had quite a bit to spare.
The PJS does not use a gearbox, which is a primary reason I love this motor. Very quiet and powerful.
I use an APC 11x7 prop which is ideal for me. It pulls about 18 amps WOT (20 initally then drops pretty rapidly to a steady 17-18amps). HUGE power.
You don't want to use those GWS 13x9 props with the PJS.
I don't own a Himax motor, but I had really good results with a similar motor, the miniAC 1215/16. I used that motor with a planetary 6:1 gearbox and a GWS 13x9 prop on my AP Slowstick with great results. I just feel that, with the PJS, there's one less thing to go wrong (no gearbox) and so that increases the reliability of the whole system somewhat.
I'm just real partial to the PJS800 and Tanic 2150 setup. It's very solid, quiet, powerful, and I get long flight times.
eBird is offline Find More Posts by eBird
Old Jan 02, 2005, 04:56 PM
RCFEVER is offline
Find More Posts by RCFEVER
Team HeliProz
RCFEVER's Avatar
Saint Clair, MI
Joined Jan 2004
I get the exact same results as Steve!
Excellent setup. No gearbox hassle and easy to mount, very low noise, plenty of power for those gusty sorties, and low vibration.
I love being able to drop my plane down on a sidewalk, street, parking lot, etc.. Rocket into the air in about a 3ft rollout and once its about 70-100ft up it's virtually silent! People walking, jogging by, in their homes look at me and wonder what is that guy looking at! They can't hear a thing so they can't find anything in the air. I just look like some crazy guy outside, hehe
You will be happy w/ this setup.
Matt
RCFEVER is offline Find More Posts by RCFEVER
Old Jan 02, 2005, 05:14 PM
rpm3 is offline
Find More Posts by rpm3
rpm3's Avatar
Pleasanton, California
Joined Nov 2000
I've been lurkin....I need an upgrade!
OK.....been kind of watching this link.....and it sounds like the Slow Stik is a pretty good AP platform. I have the PJS 800, and 3 cell Kokams.....I guess I need the plane, and the camera. I have been using the Aiptek 1.3 mega camera, but for all the effort, my photos don't compare to the likes of Mr Nolans!!!
I need an upgrade for AP!
Are you guys using a Pentax Optio S4 with an electronic switch or mechanical servo?
Is the Slow Stik the platform of choice? Where's a good place to get it?
I know there are others, but it seems pretty simple. I know there are some mods to be done for AP with it.
thanks.....
When I grow up...I wanna take photos like ebird
Ralph Matile
rpm3 is offline Find More Posts by rpm3
Old Jan 02, 2005, 05:57 PM
RCFEVER is offline
Team HeliProz
RCFEVER's Avatar
Saint Clair, MI
Joined Jan 2004
I am using a Nikon 4200 w/ a servo. I've been really happy with the results from this camera, but I still have a lot to learn about it and how to post good crisp pics at 100k. I just got the Adobe Photoshop Elements software and so far its great!!
It's very hard to beat the SS in lightwind conditions! When the winds get above 10mph it can get a little frustrating at times. Although, with a co-pilot on board these winds can be managed a little bit. It can also give you nice level pictures.
There are quite a few people selling SS kits on the FS forum! Otherwise order from www.allerc.com and I know there are others but I'm not sure the prices are much different.
The Nikon 3700 takes excellent shots which alot of people seem very happy with. It can also be found at a good price.
Good Luck,
Matt
Old Jan 02, 2005, 06:19 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I also use a PJS 800, but i use a 3s 2480, and i easily get around 15-20 minute flights.
This is with a full throttle climb out to 650 feet, then i throttle back, take pictures until my neck hurts, decend to about 100 feet, and take more pictures..
Plenty of picture time..
ash
ashdec87 is offline Find More Posts by ashdec87
Discussion guys help me choose a cheap power system for my Kaos MustangAce17 Glow to Electric Conversions 6 Nov 28, 2006 09:38 AM
GWS4CEO - Please help me choose a battery pack for the E-starter whitlecj GWS (Grand Wing Servo) 7 Dec 30, 2003 11:42 AM
Please help me pick a brushless controller mitchydkid Batteries and Chargers 7 May 28, 2003 11:18 AM
help me choose a brushless for my picojet! opualuan Foamies (Kits) 49 Sep 19, 2002 12:10 AM
Please help me choose a radio. Lagrange Electric Heli Talk 7 Aug 19, 2002 06:34 AM
