Old Jul 28, 2005, 02:25 PM
Voodoo2 is offline
Find More Posts by Voodoo2
Joined Jul 2005
Do you guys fly it with mix?
no motor -4mm flaps down
start - 4mm flaps down or something like that
Voodoo2 is offline Find More Posts by Voodoo2
Old Jul 28, 2005, 04:47 PM
Voodoo2 is offline
Joined Jul 2005
My SES 170BB didnt fit
Does a Bluebird 306BB work or is it to weak for the elevator ?
Old Jul 28, 2005, 05:21 PM
Mavrik is offline
Find More Posts by Mavrik
Mavrik's Avatar
Sydney Australia
Joined May 2005
Voodoo2
Not sure what servo you are talking about, however remember there is minimal load especially on elevator, so it does not require much tourque but must center very accurate ! I use waypoint in mine which are only average performing servos, but cheap and are fine.
Jos you are animal. If you make voodoo any hotter it will dissapear before you know it. Gets small and far away in an eye blink. My set up pulls unlimited verticle and within seconds is a dot. Not sure why you wish to make it any hotter ?
Chris (aka Mav!)
Mavrik is offline Find More Posts by Mavrik
Old Jul 28, 2005, 05:25 PM
Mavrik is offline
Mavrik's Avatar
Sydney Australia
Joined May 2005
Instructions say 2mm. I run 3mm. 4mm may be pushing it depending on your final AUW.
Give us a report on your maiden
Mav !
Old Jul 29, 2005, 12:06 AM
polar bear is offline
Find More Posts by polar bear
Joined Jul 2004
Hello Voodoo2,
I got mine just yesterday. Nice plane.
For the setup, I am afraid a speed 4.8 at 4.75x4.75 with draw too high amp. (you will probably fry it on bench test) as quoted by Mr Spearsley (Sorry for miss spelling, David) here. I think a 4.5x4.1 or 4.1x4.1 can be an initial move.
For noise of ESC, I got bad luck with some brushless setup (before learning from this forum) while the noise from DC motor is easier to handle.
polar bear is offline Find More Posts by polar bear
Old Jul 29, 2005, 12:15 AM
Joined Jul 2004
Sorry, should be Mr Dave Beardsley.
Old Jul 29, 2005, 05:30 AM
Voodoo2 is offline
Joined Jul 2005
Hello
Mavrik I think Bluebird is another name for waypoint. It weights 6g and it is a cheap servo.
Yes my 400 4,8v pull 26A att full throttle .. hmm.
/voodoo2
Old Jul 29, 2005, 06:41 AM
Mavrik is offline
Mavrik's Avatar
Sydney Australia
Joined May 2005
Hello
/voodoo2
Again as long as it centres it will be fine.
Maiden report please !!
Mav
Old Jul 29, 2005, 07:02 AM
Voodoo2 is offline
Joined Jul 2005
Yes. soon
/voodoo
Old Jul 29, 2005, 09:39 AM
Kimble_Schmitz is offline
Find More Posts by Kimble_Schmitz
Ain't Dutch? Ain't Mutch!
Kimble_Schmitz's Avatar
Southampton, UK
Joined Oct 2001
Mavrik
Why?
I am a speed freak. Or so i have been told.
Jos.
Kimble_Schmitz is offline Find More Posts by Kimble_Schmitz
Old Jul 30, 2005, 08:56 AM
Mavrik is offline
Mavrik's Avatar
Sydney Australia
Joined May 2005
Originally Posted by Kimble_Schmitz
Mavrik
Why?
Jos.
Jos,
Yes I also need the need for Speed !!!!
Wait till you fly this thing, you will understand what I am talking about However if you wish to load it up go for it I would love the report.
What will you put in for now ??? and when will we hear about maiden ??
Mav
Old Jul 30, 2005, 10:36 AM
Southampton, UK
Joined Oct 2001
Am installing all my gear at the moment. Probably going to install the servo's as in my picture. It is a clean setup and allows me to experiment.
Going to go for something lite to start with as mentioned. This is what I have at the moment, using a HET-RC 3W on 5,5x4,3" Graupner CAM prop and 2S TP2100 pack. Should be good for 20 amps ish static. Testing to come.
The rest of my gear, one Graupner C-261 and 2 Waypoint W-084. Also a Schulze Alpha 5.35 and a CC Phoenix 45. Taking pictures of the build. This is a realy nice model so I am going to take my time. No mistakes!
Enjoy.
Old Jul 30, 2005, 04:20 PM
Voodoo2 is offline
Joined Jul 2005
Hello!
Pictures
Old Aug 04, 2005, 03:24 PM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
That is why I would need something like a 6x4'' on it, better climb performance.
Folders are also nice on landing. However there are not many good one's around in this size.
I also use folders but usualy aeonaut carbon types 6*6 cut down and sanded to 5*6 or 4.7*6
It a lot of work sanding and trimming down but as they rarely break mayby one broken blade every two years
the normal plastic type flatten out too much under high revs so gave up on those
hope to start buyilding mine next month sept using mega 4turn and 8*gp1100
too busy this month fixxing flying crashing holidays etc etc
later upgrade to 8*gp2000 (if they can fit) and mega 2 turn
as KrisS got near 150mph with this motor and 7 *gp2000 and 2 turn and fixxed 4.7*4.7 so recon thats if I use folder 4.7*4.7 and 8 cells should be able to get similar speed
http://www.rcgroups.com/forums/show...54&postcount=34
Ralf
treehog is offline Find More Posts by treehog
Old Aug 10, 2005, 02:22 AM
LoopingFred is offline
Find More Posts by LoopingFred
Vini, Vidi, Scalies
LoopingFred's Avatar
Ireland, Dublin, Dun Laoghaire-Rathdown
Joined Oct 2003
Hi there,
A short video of my slope mate Patrick's Voodoo :
http://gliderireland.modelisme.com/i.../Voodooweb.wmv
(3.3 mb)
Another video will come soon... Note the slow motion in the video in order to see a bit of the voodoo.... Fast fast fast !
I can't remember the setup of his machine, but if interrested, I can ask Patrick !
Enjoy !
Fred
LoopingFred is offline Find More Posts by LoopingFred
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
