Old May 17, 2011, 02:25 PM
Erik v. Schaik is online now
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
The Kontronik Koby 40Lv and Jive40Lv are only 7mm thick. This is approx 1 cell thickness which could be great for 3s+2s application. Should be plenty of headroom at 30A current (ca550w)
Erik v. Schaik is online now Find More Posts by Erik v. Schaik
Old May 25, 2011, 08:02 AM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
Is anyone using the GM 4.75X4.75 folding prop on his Voodoo?
http://www.soaringusa.com/products/p...ategory_id=381
holco is offline Find More Posts by holco
Old May 25, 2011, 11:23 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I have the 5x5 GM folder on mine, have a 4.7x4.7 here but havent used it. Its going on another pylon racer in the build.
What did you want too know?
jackosmeister is offline Find More Posts by jackosmeister
Old May 25, 2011, 11:27 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
I like to know how its compare with the Graupner Cam 4.7x4.7 prop.
Old May 25, 2011, 07:19 PM
Auckland NZ
Joined Aug 2007
I havent flown or tested it, but imagine them very comparable performance wise.
The GM5x5 is a winner, draws very similar amps to a 5x5 APC, and I cant tell the difference in flight between a graupner speed 4.7x4.7 and APC 4.75x4.75, except a slightly different noise! The GM 4.7x4.7 is the same as a GM 5x5 blade shape wise, just scaled down a touch.
They get the thumbs up from me, are nicely balanced, and you dont have replace the prop every 2nd flight You can also glide much faster than with a windmilling prop on the front.
Old May 25, 2011, 08:18 PM
ukpaul is offline
Find More Posts by ukpaul
ukpaul's Avatar
Joined Aug 2006
Thanks for the comparison pic, they do look nice. A little spendy maybe.
Do they just have the one grub screw to hold them onto the motor shaft, or is there a couple?
I assume you need to grind a bit of a flat on your shaft, as it were
Can you post a pic of the other side of it if pos please
ukpaul is offline Find More Posts by ukpaul
Old May 25, 2011, 08:47 PM
Auckland NZ
Joined Aug 2007
I figured with the amount of S400 props I break on landing its not gonna take long to pay for itself! Plus, you get a nice carbon spinner
One grub screw, its not a chinese cheese steel one though (im good at stripping rubbish grub screws), and a small flat spot on shaft.
More pics (GM/Graupner/APC/TGS) The black mark on the APC means Ive balanced it
Old May 26, 2011, 06:45 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Thanks for the info
Old Jun 02, 2011, 06:22 PM
Lui1966 is offline
Find More Posts by Lui1966
Lui1966's Avatar
United Kingdom, Huntingdon
Joined Feb 2011
Where the best place to buy this folding prop set up in the Uk ??? As I am fed up changing fixed props after nearly every flight due to them snapping in landings arrrrrr
I'm using a mega 16/15/3 motor on mine too
Cheers Lui
Lui1966 is offline Find More Posts by Lui1966
Old Jun 02, 2011, 11:52 PM
Auckland NZ
Joined Aug 2007
Soaringusa
Old Jun 06, 2011, 05:19 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
jackosmeister , I asume this gm 5x5 folding is very good balanced, but is it possible to balance one if you have to, can I put it in a normal balancer ?
how is the carbon spinner attached ?
and do you have a clue how many rpm:s these will hold up to ? +50.000 ?
sebbe is offline Find More Posts by sebbe
Old Jun 06, 2011, 05:26 PM
Auckland NZ
Joined Aug 2007
Yeh it seems perfectly balanced out of the box. You could get it on a normal balancer with a 3.2mm shaft, as the shaft could exit through the hole in the front of the spinner, havent needed to try that though.
Spinner is attached with a thick fillet of resin on to the centrepeice, similar to how RFM do it but without the carbon tow loops. Its not falling off in a hurry.
I read somewhere 60k rpm, cant find that reference now though!
Old Jun 06, 2011, 05:56 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ok, thanks,,
Old Jun 07, 2011, 10:39 AM
Joined Dec 2003
Hi jack,
Nice prop!!
http://www.soaringusa.com/products/s...ategory_id=381
Can you measure the spinner diameter for us? (if possible in metric)
for me this prop is interesting as well because i have to import the APC props with considerable S+H costs. The break even point is very interesting!
Still waiting on my Voodoo...
Old Jun 07, 2011, 04:39 PM
Auckland NZ
Joined Aug 2007
29.5mm diameter, 23.9mm long
Got too use my new vernier's for the first time
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
