Old Oct 09, 2010, 10:30 PM
200mph club.
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Unless you try and 3D it or do some blenders, you wont strip a karbon/nylon gear in flight, the loads on a pylon surfaces are REALLY small, even though airspeed is high the loads are tiny.
All MG will acheive is flying like shite due to slop.
Im getting bored of saying this
jackosmeister is online now Find More Posts by jackosmeister
Old Oct 10, 2010, 12:52 AM
hybris's Avatar
Houston, TX
Joined May 2003
Always flew them with hs-55s and you can't get much weaker than than that. You do not want the slop MG give you. The plastic gears are going to be stronger than what they are connected to.
hybris is offline Find More Posts by hybris
Old Oct 10, 2010, 10:40 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Well I have never flown MG in a pylon except on the "Rifle". That was probably because the control surfaces were like rusty barn doors.
So, if I go with Nylon, what do you think of these?
http://www.horizonhobby.com/Products...285#quickSpecs
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 10, 2010, 12:42 PM
hybris's Avatar
Houston, TX
Joined May 2003
Those may be the ones I am using. I'll have to check. When I got mine, I went to a LHS and compared many for slop. They also fit the elevator tray and push rods perfectly.
Old Oct 11, 2010, 03:01 PM
aleksander's Avatar
Norway
Joined Dec 2009
Hi!
anyone tried the Castle Creations Thunderbird 54 AMP ESC Controller?
Should this be enough for a het 2W 4,7x4,7 ?
A
aleksander is offline Find More Posts by aleksander
Old Oct 11, 2010, 06:38 PM
United States, AL
Joined Apr 2007
I used a TB 54 in a different plane with a 2w-20. apc 5x5 is about 55a but runs great as in-flight power is much lower. Using the bec to power three 65hb servos and with little airflow the esc comes down very warm but never too hot.
biskit is offline Find More Posts by biskit
Old Oct 12, 2010, 05:31 AM
aleksander's Avatar
Norway
Joined Dec 2009
Is that on a 3 cell? and the built in Bec is working ok?
A
Old Oct 12, 2010, 06:01 AM
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Hi!
A
That's the ESC I'm using in my Rifle with MEGA 16/15/2, Hyperion 3S 1800 35C batteries, APC 4.1 x 4.1 prop. So far so good. About 20 flights. Full-throttle the whole time (2.5 min flights). No problems.
KRProton is offline Find More Posts by KRProton
Old Oct 12, 2010, 08:26 AM
aleksander's Avatar
Norway
Joined Dec 2009
Hi!
That sounds great! And thats almost the same engine as the Het 2W.
You dont have an external bec?
APC prop you use?
Thanks.
A
Old Oct 12, 2010, 10:05 AM
200mph club.
Auckland NZ
Joined Aug 2007
Running an ESC above its limits is doable, if ya use a lot of WOT. Part throttle will quickly cook it.
Running an ESC above its limits and using the built in BEC is asking for a smoking hole in the ground, particularly if its a linear BEC (ie Thunderbird 54)
ESC makes heat, ESC getting ass handed to it makes more heat. LBEC makes heat. ESC+LBEC=Lotsa Heat=Smoke=160mph lawn dart.
Ive got one of those little CC sbec's in mine, I have a great hatred of built in BEC's I wish more ESC's didnt have them. Theyre are next to useless for high performance stuff.
Old Oct 12, 2010, 10:25 AM
aleksander's Avatar
Norway
Joined Dec 2009
So you think an external Bec could do? on the TB54 I mean..
A
Old Oct 12, 2010, 10:40 AM
200mph club.
Auckland NZ
Joined Aug 2007
external BEC is far less likely to go up in smoke if the ESC goes pop, so you still have control.
Old Oct 12, 2010, 12:50 PM
aleksander's Avatar
Norway
Joined Dec 2009
like this then http://cgi.ebay.com/Castle-Creations...item4cf257d2f0
Old Oct 12, 2010, 06:17 PM
200mph club.
Auckland NZ
Joined Aug 2007
Yup. These work well too http://hobbyking.com/hobbyking/store...idProduct=4319
Old Oct 12, 2010, 06:42 PM
You down with EPP?
Houston, Tx
Joined May 2009
Maybe I missed something, but the TB 54 BEC should be ok if ran under 50 amps on 3s. Are you testing the amp limits?
I run one on my Sunracer but I am only pulling 35 amps. It always comes down scorching hot, but I have not found a castle controller that does not ome down blistering hot except the Ice series. My Phoenix 45 and 80 are always at the verge of meltdown, especially in a tight fiberglass plane.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
