Old Sep 23, 2010, 12:16 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
The setup you have is pretty quiet, which can rob you of mph when using doppler with lower quality microphones (larger cosine error). On another note, taking an upwind and downwind pass allows you to cancel the effects of wind. That said, your second pass (167mph) was cleaner than the first (160mph). This assumes 70F temperature.
That's fast, but I'm sure you didn't need me or my doppler numbers to tell you that.
What setup are you running?
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old Sep 23, 2010, 06:54 AM
skyzking is offline
Find More Posts by skyzking
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
thanks Kev, my setup is HET 2W (4750kV) on 3S and 4.5x4.1 prop.
Abdullah...
skyzking is offline Find More Posts by skyzking
Old Sep 23, 2010, 04:42 PM
sekkenes is offline
Find More Posts by sekkenes
Joined Mar 2008
Can anybody tell me the CG on the Voodoo? I changed battery in mine and lost the manual. Come on guys, I really want it in the air saturday.
Thanks, Yngve
sekkenes is offline Find More Posts by sekkenes
Old Sep 23, 2010, 06:49 PM
hybris is offline
Find More Posts by hybris
hybris's Avatar
Houston, TX
Joined May 2003
Thanks, Yngve
38-41mm
Here is the manual (sheet) that came with mine from SoaringUSA.
hybris is offline Find More Posts by hybris
Old Oct 02, 2010, 08:57 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Originally Posted by MikeRx View Post
What about throttle to elevator mix?.. Im using it with great sucess.
Elevator mix adds drag as its forcing the AOA of the wing down, adding reflex changes the foil of the wing, making less lift (and less drag)
Full throttle to ~.5mm reflex works awesome, flies like an arrow at Mach 2+ now. If ya overpowered voodoo balloons mix some reflex in to full throttle
STOKED with this plane its Ridiculously fast.
jackosmeister is online now Find More Posts by jackosmeister
Old Oct 03, 2010, 01:29 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Mixing is IMO always a last ditch effort. There's always that momentary "crap, pull up!" moment when you first drop the hammer... that's never a pleasant thing. If that didn't bother you and you survive to reach WOT steady state flight, there's the "shoot for the moon" the second you let off the throttle that will at least annoy you. Mixing is very flight speed dependent. So unless you're some how utilizing a pitot probe for input to your mix, a simple mix is never going to complete the ideal connection between man and machine. With any high performance aircraft, the devil is in the details... you will feel so much more in tune with the aircraft if you trim it out (aerodynamically) versus mixing it out (electronically).
Maybe I've had one too many strong margaritas at the party tonight... I'll find out tomorrow morning I guess.
Cheers,
Kev
Old Oct 03, 2010, 01:46 AM
Auckland NZ
Joined Aug 2007
Yup, thats were the reflex thing comes in, there is no pitching when mixed in as its such a tiny amount. The wing is just making less lift at high speed. Elevator mixing causes the scary porpoising, and thats more to deal with thrust line issues. The mix is proportional too which helps, Top 10% of the throttle starts bringing it in.
Old Oct 03, 2010, 01:24 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Thanks for the info Jacko, I'm going to give that a try on my Voodoo. I've never had great results using elevator mixing on my wings, but reflex mixing on a full house plane is a different thing.
Cheers,
Kev
Old Oct 03, 2010, 03:53 PM
plainguy is offline
Find More Posts by plainguy
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
I have flown SRII with 3S NEU 1110 & fly Escape with 1112 1Y and Viper with 4S, 1115 1Y...
The voodoo on 3S mega 16/15/2 with 4.75 x 4.75 prop as advised previously is amazing fast.
in my view -no better speed for the money!
hallelujah!
plainguy is offline Find More Posts by plainguy
Old Oct 03, 2010, 11:16 PM
Auckland NZ
Joined Aug 2007
Now i just need to find someone game enough to race.
Launch the voodoo and everyone else on the flight line calls "landing!" . Dunno what the problem is
plainguy - How hots that 16-15-2 getting with a 4.75x4.75?? Mines on a 4.1x4.1, and comes down averagely warm. 4.75x4.75 must draw some wicked current.
Old Oct 04, 2010, 10:55 AM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
Fairly warm. Battery comes in at about 130 Fahrenheit.
i don't have clear access to motor ESC to test temp but i reckon to be about 110F - 120F
System pulls a lick under 800 watts with a 1750 mAh, 3S, 45C, TPower batt.
Throws need to be decreased a tad and /or some expo added in the center otherwise she's all over the place.
Flight time: 2 minutes. unfortunately -either because of draw or because i ruined TP batt by overspending which i did twice accidentally.
-r
Old Oct 06, 2010, 12:48 PM
aleksander is offline
Find More Posts by aleksander
aleksander's Avatar
Norway
Joined Dec 2009
ok set up for a Voodoo?
Hi friends!
I`m planning to buy a Voodoo from Hoellein. It seems that they are out of stock now,so Im just planning what to use.
So far I`ve come up with this:
Het 2W ( like the Mega 16-15-2 )
graupner speed cam 4,1 x 4,1 ( starting with that )
Castle Creations ICE60 ESC
2x Hitec HS55 ailerons
1x futaba S3154 elevator
Any suggestions to battery mah?
How many watt/amp should this be? Can I use a smaller Esc? Hmmm
Thanks.
Aleksander
aleksander is offline Find More Posts by aleksander
Old Oct 06, 2010, 09:41 PM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
if you install Servo's on the wings. Thunder power 3S 1750 mAh 45C -fits like a glove and really puts out.
i'm using a Thunderbird ESC 54 amp but i am pushing it.
Old Oct 06, 2010, 10:26 PM
Auckland NZ
Joined Aug 2007
aleksander -
Id suggest S3154's on ailerons and elevator, far better servo than an HS55 and much smaller. Small components are the key to the voodoo, smaller aileron servos give you more ESC and wiring room.
Hyperion Vx 3S 1800's fit in the voodoo very well too, nearly like they are designed for it and they take a licking too.
That 2W will put you around the 60A/600+watt mark on a 4.1x4.1 , I wouldnt go for a smaller ESC as there is very little cooling room inside the fuse.
I didnt know graupner made a 4.1x4.1, thought I had every speed 400 prop in existence!
Got a link?
Good luck, for a molded ARF that is nearly built outta the box, it takes some building time, some thinking and multiple test fits to get all the gear too fit, but its worth it!
Its a seriously awesome little plane, Ive flown a bunch of speed400 pylons, none fly as well (or as fast) as a voodoo.
Old Oct 06, 2010, 11:19 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Originally Posted by jackosmeister View Post
aleksander -
Got a link?
How about this one
http://www.icare-rc.com/catalog/grau...rop-p-141.html
Thekid3418 is offline Find More Posts by Thekid3418
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
