Old May 21, 2010, 09:02 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
I'm shooting for 37k! but whatever the number, I'm gonna be light.I'm thinking of light 5s too... Same weight as 3s hot wind but ? k more rpm.
This motor has seen 6s on wings at 1.5 kw so I'm sure it has the potential. Its those 90c peak packs that may make this dream happen
MikeRx is offline Find More Posts by MikeRx
Old May 22, 2010, 09:38 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Maidened
It Goes fast! Guesstimate it to be in the 140mph in a tight circuit, Jeepers does it turn fast, Pulled some serious G's. I like it, I like it alot.
Easily the best flying speed 400 racer ive ever flown. Unfortunatly broke the prop on landing and forgot to bring my box of spares, so no video. Next time
I think a 16/15/2 is in my future.
jackosmeister is offline Find More Posts by jackosmeister
Old May 22, 2010, 10:46 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Sweet Jacko! One more story confirming I'm making the right choice getting a Voodoo. Can't wait for the video.
I thought 16/15/2 was too hot for 3s? ...something about demagging and shafts coming unglued with 3s/4.1x4.1? After hearing those reports I figured a neu 1107 was the way to go for 180mph craziness.
Kev
Truglodite is offline Find More Posts by Truglodite
Old May 26, 2010, 07:22 AM
Auckland NZ
Joined Aug 2007
Just bought a 16/15/2
Seems to be mixed thoughts on how they hold up on 3S, My 16/15/3 cracks 1000W at the moment, So 600 odd with 2 turn should be shweet. I managed to get a heatsink on the ARC in the nose of the voodoo, Ill do the same with the mega. This thing is gonna scare the old farts at my club
Old May 26, 2010, 08:51 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
That motor should be fine with heat sink and cooling vents. What prop and battery are you going to use? Folded wing on rifle..
Im gonna be paying more attention to this thread because I only had a taste of the S400 experience. I want the full meal!!
Old May 26, 2010, 09:11 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
does this look right?
(Dr Kiwi's post)
Motor: Mega ACn 16-15-2; 4600rpm/V; 2.97A no-load; 0.012 Ohms.
Battery: Thunder Power TP3200 (G4 ProRace 40C) (40C); 3 series x 2 parallel cells; 3200mAh @ 3.7V; 0.003 Ohms/cell.
Speed Control: Castle Creations Phoenix 60; 0.0012 Ohms; High rate.
Drive System: 4.1x4.1 (Pconst=1.16; Tconst=1) direct drive.
Airframe: Anything you want.
Motor Amps = 53.0
Motor Volts = 10.8
Input (W) = 572.6
Prop RPM = 45821
Thrust (oz) = 30.2
PSpd (mph) = 177.9
Since max amps for this motor are listed as 38A... no way with a prop! (that should have been obvious given the 4600KV!)
Old May 26, 2010, 06:08 PM
Auckland NZ
Joined Aug 2007
Dr. Kiwi is very conservative , and those numbers are calculated, and way off too.
Heather from my LHS tested one.
Well I have some interesting numbers from an APC 4.1x4.1 on a Mega 16/15/2 motor.
Tests where performed using an Apache 70A ESC (Similar to Jeti), 3s-3300mah battery (1yr old Hyperion), Eagletree V3 150A Data logger with brushless sensor & Tahmazo motor thrust gauge. Temp - 22c. Pole count set to 6 for rpm sensor.
10.58V 54.5A 575W 37313rpm 520grams Thrust
I regreted not having earmuffs on....
By feeding these and the Microdan velocity numbers into www.badcock.net's efficency calculator we get an interesting comparison. Velocity = 68.4%, Mega = 79%
Ive got a scorpion 60A V2 in the voodoo, and the G3 35C 1800 3S hyperion pack, so it'll just be a motor change. 4.1" props will be the max.
Old May 26, 2010, 06:51 PM
Auckland NZ
Joined Aug 2007
Found this, doesnt look particularly fast, but he may have esc issues, listen to the prop when he launches it -
Sokol Pylon ca. 250km/h (0 min 53 sec)
Old May 26, 2010, 07:01 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
http://www.youtube.com/watch?v=TZpW_gLlj1U
yea that ones scary.. it seemed sensitive to the shove of the launch and appreared to cut out hear and there. thanks for the motor info..
Old Jun 05, 2010, 06:46 AM
Auckland NZ
Joined Aug 2007
Rubbish weather and boredom resulted in motor swap Some arctic silver on the heatsink in the hopes of keeping the poor 4600kV mega 16/15/2 alive!
37,000 rpm sounds shweeeeeet!
Scared? Yes.
Old Jun 05, 2010, 11:32 PM
jetdryvr is offline
Find More Posts by jetdryvr
jetdryvr's Avatar
United States, CA, Fairfield
Joined Aug 2004
Yeah baby! Here we go.
jetdryvr is offline Find More Posts by jetdryvr
Old Jun 06, 2010, 01:00 AM
Auckland NZ
Joined Aug 2007
Haha
Is taping the aileron tips on this setup a good idea jetdryvr? Did yours flutter?
Old Jul 02, 2010, 08:21 PM
Auckland NZ
Joined Aug 2007
Ungodly fast! Stupid fast! Fastest model I have ever seen in person
CG is slightly too far fwd, and my elevator throws of 2mm are too much! But it survived its first 16-15-2 flight, my underpants did not.
Had a video camera pointed at it, dunno how much footage of the plane we got, Ill have a look later and upload some.
Did I mention im still shaking?
Old Jul 02, 2010, 09:07 PM
golem is offline
Find More Posts by golem
golem's Avatar
Maryland, USA
Joined Mar 2006
Now it sounds like you're having waaaayy too much fun.
Great to hear it went well. Looking forward to the vid!
Cheers!
golem is offline Find More Posts by golem
Old Jul 03, 2010, 02:01 AM
Auckland NZ
Joined Aug 2007
Hope you like pink specs in blue sky
Cheap chinese camera didnt pick up much.
Miro Urban Voodoo F5D-400 - Maiden Flight, STUPID FAST! (4 min 27 sec)
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
