Old Apr 23, 2010, 06:39 AM
DjBac is offline
Find More Posts by DjBac
Joined Jan 2010
So this would be the most powerfull motor the voodoo would accept? Any esc recommendation for this motor?
DjBac is offline Find More Posts by DjBac
Old Apr 23, 2010, 04:58 PM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
I recall in a thread maybe this thread that some of the mega 2 series were demagnitizing from heat build up
It is certianly up there as one of the most powerful motors for this plane but there were a couple of others with ~4000 to 4500 KV that were close behind but amps are way up there if i recall ~70 amps with the 4000 to 4500 kv motors
I did a brushed 3200kv and melted in flight a 40 amp kontronik sun 4001 ESC but i had a 110mha reciever pack as well
I couldnt make my kontronik 480 fun 55 (5500kv) fit as that uses ~100 amps and the 90 amp ESC a big block of thing and three suitable 30c 3200mha wouldnt fit so well as thay all do in my bigger limited F5D fox
Still working on the problem
Ralf
treehog is offline Find More Posts by treehog
Old Apr 23, 2010, 05:57 PM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Hey jacko, I know you said you read this whole thread so are you going to put the receiver behind the elev servo? You'll have to if you wanna fit serious mojo in there. And that servo extension tray also...
Yup, im copying your layout The case is coming off my optima 6 Rx and getting jammed down behind the elevator servo. Im amazed you fit an AR7000 in there!
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 25, 2010, 05:59 PM
Auckland NZ
Joined Aug 2007
Servo bracket made up
Old Apr 25, 2010, 06:06 PM
jetdryvr is offline
Find More Posts by jetdryvr
jetdryvr's Avatar
United States, CA, Fairfield
Joined Aug 2004
Sexy plate there Jacko,
Hey.....The servos are going to go on the bottom of that thing right? Is there enough room between that and whatever is in the bottom of your fuse?
That thing is way nicer than my plate though.
EJ
jetdryvr is offline Find More Posts by jetdryvr
Old Apr 25, 2010, 06:15 PM
Auckland NZ
Joined Aug 2007
Just, I hope scorpion 60A ESC sits just below it, but ive stripped it down. Im crossing my fingers that the esc/battery leads can fit in there too.
Nobody stocks micro futaba servos in NZ, so the 3154's are coming from HK, which sucks.. More waiting.
I found JR DS385's locally but the specs look rubbish compared to the futaba's, and they are stupidly expensive (~$60US each!)
Old Apr 29, 2010, 08:27 AM
DjBac is offline
Joined Jan 2010
Do you recommend a european site where I could order the Mega 16/15/2? Any ESC recommendation for this motor? Should it work on 3S LiPo?
Old Apr 29, 2010, 09:19 AM
_King_Pin_ is offline
Find More Posts by _King_Pin_
Lisbon, Portugal
Joined Oct 2005
http://www.stratair.com sell mega motors.
_King_Pin_ is offline Find More Posts by _King_Pin_
Old Apr 29, 2010, 09:51 AM
Auckland NZ
Joined Aug 2007
http://www.megamotor.cz/
You'll want a 60A esc. A very small one I hope you have some previous experience with silly fast small planes.
I gave up trying to wedge my 1850 40C 3S (and 4S) into the voodoo, it just aint gonna happen... had about 12 attempts at resoldering wires, but never was able to stick the wing on
Ordered some hyperion G3 35C 1800 3S's, they have some promising dimensions - 84.7x27.8x26.1mm This is turning into one very expensive little pink plane
Instead of 4S, Once im bored of the 28-37-2 Ill bang a 16-15-2 in it, and squeel like a little girl.
Old Apr 29, 2010, 09:55 AM
DjBac is offline
Joined Jan 2010
Thanx!!
Do you have any lipo recommendation for this esc?
Old Apr 29, 2010, 01:01 PM
critical-mach is offline
Find More Posts by critical-mach
Joined Dec 2009
Voodoo setup request.
I bought a used Voodoo not long ago but it came without documentation. Could someone tell me the correct CG location and control surface throws? Any information would be greatly appreciated.
critical-mach is offline Find More Posts by critical-mach
Old Apr 29, 2010, 02:13 PM
Joined Dec 2009
Disregard this request. I just found the setup info online.
Old Apr 30, 2010, 06:54 AM
treehog is offline
treehog's Avatar
Euroland
Joined Jan 2004
Re:critical-mach
welcome to the house of fun what gear are you using in your Voodoo
Ralf
Old May 03, 2010, 01:19 AM
Joined Dec 2009
Voodoo
Hello Ralf,
My setup: Neu 1105/3Y, CC-35, JR241 servos and pulled by a 4.75x4.75.
I haven't flown it yet though. Too many other projects on my plate at the moment. Really looking forward to it.
Old May 05, 2010, 02:06 AM
Auckland NZ
Joined Aug 2007
Lipo size comparison -
Hyperion G3 Vx 1800 3S, Turnigy 30C 1800 3S, Rhino 40C 1850 3S, Turnigy 30C 1800 4S
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 10:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 31, 2006 12:10 AM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 09:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 05:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 07:26 PM
