Old Aug 23, 2005, 02:23 AM
f5b@wannabe is offline
Find More Posts by f5b@wannabe
Joined Dec 2004
thats the issue im talking about......
back with the cg, as far as possible, then youll get the sensitivity with flaps down for landing......
thats the way i did on my both voodoos
f5b@wannabe is offline Find More Posts by f5b@wannabe
Old Aug 25, 2005, 03:48 PM
Kimble_Schmitz is offline
Find More Posts by Kimble_Schmitz
Ain't Dutch? Ain't Mutch!
Kimble_Schmitz's Avatar
Southampton, UK
Joined Oct 2001
First test with the HET-RC 3W motor is complete!
Setup it 5,5x4,3'' Graupner CAM Speed Prop and CC Phoenix 45 controller.
On a NEW fresh pack of 2S Thunder Power 2100 Gen 2 it draws ~24 amps static. Dropping to ~20 amps after a while.
Only thing that gets hot is the motor and I will add a NACA duct to cool the motor.
This setup will rock!
Kimble_Schmitz is offline Find More Posts by Kimble_Schmitz
Old Aug 26, 2005, 05:14 AM
Mavrik is offline
Find More Posts by Mavrik
Mavrik's Avatar
Sydney Australia
Joined May 2005
I flew my Voodoo again today 10th flight and I love it. When is your maiden ??
Draws 30 amps static 3s 1500 ma 20c lipo ! mega 16/15/3 apc 4.7x4.25
Mav
Mavrik is offline Find More Posts by Mavrik
Old Aug 26, 2005, 05:13 PM
Southampton, UK
Joined Oct 2001
Nice Mav, rub it in.
Maiden is prosponed untill I get some new servo's. I had them glued on ready to go and then I messed up soldering the wires! So now I am back to stage one. Oh well.
Two more C 261 servo's will replace the W-084. I like these servo's a lot more then the Waipoint ones, better centering.
The rest of the plane is ready to yank and bank. Including a lot of battery packs!
J.
Old Aug 29, 2005, 05:52 PM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
Just back from holidays so will start the build
I will start with a s400 brushed and move to mega 4turn and later buy the mega 2 or 3 turn all with 8*gp 1000 until I purchace the new gp2000 cells
I bought three hitec 55 instead to take out of my raz faz the three graupner 261
I hAVE such good experiences with the hs55 and graupner 261 it a close call which is best
centreing with 261 seems to be slightly better
but I rarely replace cogs on hs55 and some hs55 have years abuse and and 100 plus flying hours slope soaring and still going strong and besides the price in the LHS was so good for the hs55 I bought a few extra for other projects
ok sometimes I cheap skate a little bit
if the cheaper item has proven itself against my abilty to repeatly crash
looking at the construction have to say for the elevator servo with its premade tray system is the way to go and hopefully other model makers will follow suit
photos supplied later and I got the yellow version
but before the build starts got to fix the slightly broken planes from the holiday so that will slow things up a little bit
Ralf
treehog is offline Find More Posts by treehog
Old Aug 30, 2005, 05:55 AM
Mavrik is offline
Mavrik's Avatar
Sydney Australia
Joined May 2005
J.
How will you remove glued waypoint servos ??? Did you use CA ???
Thas how I glued mine !!!
Mav
Old Aug 30, 2005, 10:07 AM
Southampton, UK
Joined Oct 2001
Nope, I use epoxy......
The servo's are now off. Just twisted one strait off and on the other one I had to demolisch the servo and then sand the remains away. A lot of hastle and the plane has not even flown yet!!!
Ohhh well.
New servo's should be here any day now.
J.
Old Aug 31, 2005, 02:28 AM
Joined Dec 2004
powerstrips are just ok for this plane.......
then there are no problems for removing them.
I couldnt find any bad habbits using the strips
Old Sep 03, 2005, 06:09 PM
Southampton, UK
Joined Oct 2001
f5b@wannabe,
I would not suggest the use of power stips. Power strips are very flexible and don't age well. Specialy on a hot day they can get very flexible and can even completely let go if you apply a little force.
When you are flying an airplane at over 250km/uur there is no room for error.
That is the reason why I use 30min epoxy or better to glue my servos in.
My new servos have arrived today and one has already been glued on. Tomorrow I will try and do the other one and then take a picture of the finished setup.
J.
Old Sep 04, 2005, 02:49 AM
Mavrik is offline
Mavrik's Avatar
Sydney Australia
Joined May 2005
15 flights on Voodoo now and very impressed. Will post pictures shortly,
Mav
Old Sep 04, 2005, 03:27 AM
Rodebaron51 is offline
Find More Posts by Rodebaron51
Need 4 Speed :-)
Venray, The Netherlands
Joined Dec 2004
Hi Kimble,
250 KPH? What setup are you running on?
I'm using B20 15L on 8 gp1100 and 4,7x4,7... just striking the 200 KPH...
Pascal
Rodebaron51 is offline Find More Posts by Rodebaron51
Old Sep 04, 2005, 09:29 AM
Southampton, UK
Joined Oct 2001
Pascal,
If you have a read of this thread again. You wil see a post with speeds of different aircraft with their setups. Post #28
My setup at the moment is not going to cut it but I am still experimenting. I suspect that in a dive with a 3S TP2100 pack and a HET-RC 3W it will go 250kmh at some point.
Here are some pictures of my servo install. A word of warning in shortening the long control bar. It is not a solid metal rod in there! It is a tube and therefore does not bend well.
So either you need to find another ball link of the same size or you need to cut the tube and drill it out so you can glue a solid piece of rod in there. This is what I did.
The Z bend way is about the only way to make a link short enough to fit my setup. It is slightly shorter then the other short link that came with the plane.
Gregg, enjoy.
J.
Old Sep 04, 2005, 09:39 AM
Southampton, UK
Joined Oct 2001
Here are two pictures of the other servo glued to the wing as normal. You can also see the spot I sanded where the second servo will go.
There is no slop what so ever in this linkage!
In my last post you can also see a little piece of ply wood glued to the servo. This is to move the servo down and away from the trailing edge of the wing a little. The reason for this will become clear later but mainly it's because the servo sticks out behind the trailing edge of the wing for about 2mm.
J.
Old Sep 04, 2005, 04:38 PM
Southampton, UK
Joined Oct 2001
Well.
Need to catch some sleep now but the plane is more or less finished.
Here are some pictures of the motor and NACA style duct to keep it cool.
More tomorrow.
J.
Old Sep 04, 2005, 05:29 PM
Joined Dec 2004
f5b@wannabe,
J.
Thats simply not true.......
its already done, without any problems even on hot days...... note: on pilished surfaces the strips work even better.
but you can get problems with using resins on the voodoos wing... its very thin and flexible... theres a chance for the units to crack off......
so, everything may be not the optimum, but mine got today the 100 flight... no problems at all. Maybe i have special strips, i dont know
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
