Old Feb 09, 2013, 08:38 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Yeah that's the website if you want to order direct.
They've been busy recently.....
I bought a 2nd hand SRIII last year, but got so frustrated with rigging it up I sold it.
feefo is offline Find More Posts by feefo
Old Feb 13, 2013, 10:17 AM
Japac is offline
Find More Posts by Japac
Joined Feb 2011
So i tryed my voodoo on 4s with my 16/15/2 mega and a 4.1x4.1, went vell until one of my d47 servo's could't take it and decided to give full alleron on my left servo and I lost control, so it's time for some repair :-(
Wich servo's are good and small so it Can fit In the plane/wing?
Japac is offline Find More Posts by Japac
Old Feb 13, 2013, 10:37 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
I use Futaba S3154 with cut down control arms all around. They have been rock solid.
http://www.rcgroups.com/forums/showt...0#post19489783
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Feb 13, 2013, 12:12 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
4S on a 16/15/2 is a lil excessive, poor lil motor!
jackosmeister is offline Find More Posts by jackosmeister
Old Feb 13, 2013, 12:23 PM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
SD 100 servos work well for me.
Ben D Wing is online now Find More Posts by Ben D Wing
Old Feb 13, 2013, 12:53 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Motor vs airframe, round 1 to the motor...
Old Feb 13, 2013, 03:41 PM
Japac is offline
Joined Feb 2011
It's runing 70amp's but I gues it unload a bit In the air, the motor was just warm, but the air temp here is around 0*celsius, so there are good cooling.
Conserdering a new pylon racer that will fit a bigger setup, at a resonbly price, any suggestions?
Mayby a jolt or a Ariane P5
Old Feb 13, 2013, 04:40 PM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
I have an Ariane P5 and I like it a lot. The servos are installed old school just like in the Voodo which is elegant but limits the battery space. I fly mine with a scorpion 2221 3000kv, APC 4,75x4,75 and 4s 1800. You can go heavier and I've tried that but I like this plane light and super agile. Dopplered at 298 km/h out of a dive so it's not exactly slow. If you want to go faster I'd recommend one of the larger, current F5d airframes like the Viper or Swist.
Kwahn is offline Find More Posts by Kwahn
Old Feb 14, 2013, 03:06 AM
Japac is offline
Joined Feb 2011
I've been thinking about my crash and I May have had a bit flutter before it happend, hov Can i get rid of that. Heard about tapeing til aileron tips? But how? So they dont move or?
Old Feb 14, 2013, 07:47 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
The only way to get flutter on a Voodoo is to have loose or sloppy linkages, it's nothing to do with the airframe, unless of course the live hinges have been damaged.
Old Feb 27, 2013, 05:06 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Stumbled across a few pics of a Voodoo off another site, not sure how I feel about a cooling hole being put in the wing, I don't think it's something I'd do, mainly because of how I intend to mount my servo's, but even if I wasn't mounting them at the rear of the wing, I still don't think I'd cut a hole in it .
I love the catching net way of landing, if you used 1 of those nets it opens up a whole load of fields to fly from! I've seen the nets used on a Youtube vid before, I think it was for a Poky 40 composite slope wing but can't find it again so I'm not sure now.
Old Feb 27, 2013, 05:21 PM
sekkenes is offline
Find More Posts by sekkenes
Joined Mar 2008
Hi, this is me and my fellow club member flying at Gullknapp in Norway
Nice to see that our web page is read by you. We have had our Voodoos about 4 years now and they are still flying. The cooling hole is not a problem on my friends plane. Still rigid. I have not made it on my Voodoo though. The net is our only option at our field since it is only tarmac and gravel.
Check out our other site. www.artistic3d.net
sekkenes is offline Find More Posts by sekkenes
Old Mar 26, 2013, 06:14 PM
TimR74 is offline
Find More Posts by TimR74
United Kingdom, Wales, Monmouthshire
Joined Aug 2011
My Voodoo is ready to maiden now if this weather ever warms up. Weighs in at only 371 grms with a 1000mAh 3S battery, just under 400 with the 1500mAh.
I added some white trim to the tips to break up the black leading edges and help visability. I've got a small slope plane with a black leading edge and very small profile and it does tend to disappear if it's below the horizon and heading directly towards you.
TimR74 is offline Find More Posts by TimR74
Old Mar 26, 2013, 07:55 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Good job on keeping it that light Tim.
Did you stick with the 16/15/3? What esc are you using and what size prop?
Old Mar 27, 2013, 05:30 PM
TimR74 is offline
Joined Aug 2011
Got a couple of flights in today with the Voodoo. Not ideal conditions for a maiden, it was a bit breezy and v cold, little snow flurry on the second flight.
Blimey it keeps you on your toes it'll do some seriously quick turns. It really forces you to get your bank angle just right, felt a bit rusty as I haven't flown for a while. Going to take a few flights to dial in the CofG, throws and expo.
Feefo - yep, running the 16/15/3, with a Castle Thunderbird 36 - compact and light (no heatsink). Started off on a 4.7"x4" prop but will switch to a 4.7"x4.7" when it breaks, which I'm sure won't be long.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
