Old Feb 05, 2013, 10:27 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Super bling prop!!
Ben D Wing is offline Find More Posts by Ben D Wing
Old Feb 05, 2013, 10:29 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Cheers for posting the links Birger, pity thet Sussex MC are out of stock, although not any cheaper than the Graupner.
I've had cheaper spinners that have been fine, just don't fancy messing about getting 1 to find it's useless and then have to order again.
I've actually hit a stumbling block anyway. I was going to order the 16/15/2, but I'm confused on amp draw on the motor. Most websites claim it's 4600kv but Mega's website claims it's 4180kv. I'm going to email Mega or Gryphon and ask when the kv change came about. Most posts seem to hint that it's 4600kv, and I'm presuming that all amp figures have been on the 4600kv version.
I'm searching posts everywhere trying to find a definitive answer on amp draw if it's the 4180kv version.
feefo is offline Find More Posts by feefo
Old Feb 05, 2013, 01:40 PM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
I'm also confused about the different KV's claimed for the Mega 16/15/2. When you have clarity please let me know too. I'm about to order one.
hakank is offline Find More Posts by hakank
Old Feb 05, 2013, 02:17 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Im pretty sure 4600 is the old kV, I dont actually remember testing a 16/15/2s kV though (which is silly as I usually test every motor)
If you look through the the whole line of 16/15's there is an old and new kV, All my numbers are off the new kV (old higher kV is ancient now (8+ years?), there wont be any for sale). Its due to a magnet change dropping kV.
jackosmeister is online now Find More Posts by jackosmeister
Old Feb 05, 2013, 03:48 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Yeah I knew that the 4600kv was the old 1, but some posts give me the impression that their 16/15/2 is in fact 4600kv. If the change happened 8 years ago, there's a lot of retailers out there displaying the wrong info. I wasn't sure when the change in kv happened.
I was hoping that your motor, for example, WAS the 4600kv version, meaning the 4180kv would be pull a few amps less and open up prop sizes a little.
Old Feb 06, 2013, 02:14 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Hakank, I've convinced myself that the 16/15/2 is 4180kv despite lots of posts where 4600kv was mentioned.
I won't go through the maths, but if a prop is claimed to be spinning somewhere between 37000-39000 then unless the Mega is running really inefficiently, it's not a 4600kv motor. I reckon the 4600 motor would show at least 40000rpm, prob closer to 42000 in flight (on 3s).
I'll let you know what Mega say if/when they reply anyway.
Old Feb 08, 2013, 02:04 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Feefo, my 4s 1000mAh pack is about 76 x 34 x 21mm and fits snugly with a 35 ESC on top of it, so there's space for a thicker battery if the ESC is repositioned.
Secondly, the servos are mounted to an angled ply plate epoxied to the rear moulded servo well, see photos. This ensures that they're well clear of the battery and ESC.
Old Feb 08, 2013, 02:45 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Cheers, looks good. That's the layout I had planned, nice touch with the rx there, looks like the RX5 was made for it.
Old Feb 08, 2013, 02:53 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
The Rx only just fits between the servo arms, but 'just' is good enough! The plywood servo mount is wrapped in carbon effect just 'cos I had some in my spares box. A solid piece of carbon would be the ultimate in bling though.
Old Feb 08, 2013, 08:02 PM
NeilRivera is offline
Find More Posts by NeilRivera
United States, FL, Kissimmee
Joined Dec 2008
Quick question guys- what do you use to glue the stab and vertical fin to the fuse ? I was thinking finishing resin mixed with milled fiber...
NeilRivera is offline Find More Posts by NeilRivera
Old Feb 08, 2013, 08:50 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Standard 30min epoxy will be fine. Even thick CA would do it.
SB7 is offline Find More Posts by SB7
Old Feb 08, 2013, 08:55 PM
Auckland NZ
Joined Aug 2007
Mine came already attached.
Make sure the surfaces is roughened up well.
Old Feb 08, 2013, 11:11 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Mine came ready attached too. No glue required!
Old Feb 09, 2013, 07:57 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
I've had an email about some testing Dan did on the 16/15/2, results are
MEGA 16/15/2
KV= 4055 RPM
RI = 5,85 MILIOHM (1 PHASE)
IO = 3,5A /9V
It was also mentioned that any kv testing I might do would probabaly show around 100kv more.
Are you still using the 2W Hanank?
Just wondering if you are why you're considering the Mega?
Now I know the kv for sure, I've confirmed my order for the motor with a few options added.
Old Feb 09, 2013, 08:04 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Thanks for confirming. Meanwhile I found the source I think: http://www.megamotor.cz/v4/script/default.php and there is spec as 4180kv which is in line with Dan's testing. I'm happy with the 2W in my Voodoo, running really well. I'm putting together a Sunracer dealt with in another thread and wanted something hotter.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
