United Kingdom, Wales, Monmouthshire
Joined Aug 2011
I've got a couple of the Zippy Compact 1500 3S. Fit very easily with the servos in the standard location as they're only 14mm thick. Also got some 35C 1000 mAh 3S which I'll use for the first flights. You just need to keep the battery thickness below 18ish mm if you using the standard servo location. I made a mock up of a Mega 15/7 motor at 48 grms to see if it would balance OK with a 3S 1000 mAh and it's fine provided the battery is under the ESC and pushed well forward. I'm still half tempted to try a 15/7 Mega in it for an ultra quick turning, very light set up, should be less than 350 grms. |
Length of opening, width of opening at TE and width of wing bolts, Thanks if you can. Quote:
I'm not trying to stuff in the biggest battery in I can, but would like something that will give me enough run time depending on what motor I decide to go with. I'm not convinced the 16/15/3 will satisfy my needs on 3s, if it would, battery choice would be easier. Quote:
![]() Cheers for the info Tim, I've used the Zippy Compacts in other planes, the 4500mah 4s 35c I have holds it voltage under load really well, I've been impressed with them. |
Joined Aug 2011
Maybe a good idea to wait until you've got the fus in your hands and play with some mock ups if you're looking at putting in some biggish batteries. |
| Thread Tools | |
| Discussion New Pylon Racer | dalbert02 | Electric Plane Talk | 2 | Sep 22, 2006 09:19 PM |
| Discussion New pylon racer.. whatcha think? | threcixty | High Performance | 7 | Jul 30, 2006 11:10 PM |
| Spirit 400, my new pylon racer! | Thomas Manson | Parkflyers | 2 | Aug 31, 2003 08:07 PM |
| New pylon racer launch system | sneu | High Performance | 5 | Feb 13, 2003 04:22 AM |
| T-Strike, a new pylon racer! | Harm Botman | High Performance | 15 | Jan 25, 2002 06:26 PM |
