Old Nov 06, 2012, 01:46 PM
tho98027 is offline
Find More Posts by tho98027
tho98027's Avatar
Joined Aug 2004
A MEGA 16/7/3 on 2s with a 4.1x4.1 might be a sweet and light performer. .02
tho98027 is offline Find More Posts by tho98027
Old Nov 11, 2012, 01:23 PM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
Flew the voodoo today and was a bit disappointed with the handling
she flew great when gliding but under power was all over the place pulling up and turning a bit as well
I was using a 4.5x4.0 prop and have the cg set at 38mm
Maybe throttle / flap mix required?
Anyone had similar experience?
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Nov 11, 2012, 01:30 PM
bdelapen is online now
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
I find that my Voodoo climbs above about 110MPH. To mitigate it I have a little bit of reflex mixed in with my throttle, about 1/2 mm proportional from 0 starting about 80% throttle. I personally don't have any issues with turn or roll.
Hope this helps,
- Birger
bdelapen is online now Find More Posts by bdelapen
Old Nov 11, 2012, 01:46 PM
voodoo magic maaan
Joined Jan 2011
Hope this helps,
- Birger
thanks Birger
so, thats 1/2mm flaps up when at full throttle?
Old Nov 11, 2012, 01:53 PM
bdelapen's Avatar
Joined Aug 2008
thanks Birger
That's correct, 0 up from 0 to 80%, 1/4 up at 90% and 1/2 up at 100%. You will have to pllay with it a little to get it to work with your specific plane and CG but that is the idea.
- Birger
Old Nov 11, 2012, 03:23 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by Edhs View Post
for comparison the Rifle is 10mm at root 8at half way and 5mm 25mm from the tip.
Quote" Will this get you to order? "
not on its own but the high praise and happy followers is deffinatly a push towards it!
I you like the Rifle,you will LOVE the VooDoo....They have NOTHING in common.....and i am not trying to take away from the Rifle as it is a great piece for what you pay for it,it is just that the 2 can not be compaired by any means.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Nov 13, 2012, 03:31 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
ok, testing complete
With 3s nanotech and 4.7x4.7 prop I get 250 watts and 25amps
Seems a bit lacking in power.. Maybe I need to swap out the het 3w...
What kind of watts are others getting?
I had 560W in my Voodoo with 16/15/4,spin33 and 2s+3s 1350mAh and GM4.7x4.7 folder.
Have a browse in this thread for pics only. You'll find all info to copy my bird.
br!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Nov 13, 2012, 03:33 PM
Joined Dec 2003
Oh. It went down due to a burned current sensor... Nothing to do with over temping the hardware. in fact, temps were plain cold exept the cells which got barely warm.
Old Nov 15, 2012, 09:26 AM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
br!
Erik
Sounds to be one of the hottest set up on thread
I have all that except the Batteries .Which type were they ~20C,30C... or 50C ?? and which manufacture do you recall
Ralf
treehog is offline Find More Posts by treehog
Old Nov 15, 2012, 11:19 AM
Joined Dec 2003
Ralf
post 978-1016 shows all you need. Read the whole story
http://www.rcgroups.com/forums/showt...0#post18621312
Old Nov 24, 2012, 05:40 PM
joshy 3d is offline
Find More Posts by joshy 3d
Joined Sep 2009
Help please
Hi guys
I've had one of these which I lost on the second flight due to the esc catching fire, through a lack of cooling
My original setup was a HET 2w20 with a castle Phoenix 45amp esc
On a Overlander 3cell 1800 mah 25c lipo with the servos in the stock place.
I now have a new model, with a HET 2w 20 again with either a castle 45 amp again or a hobbywing pentium 60 amp if I have one.
I have gone down to a Overlander 1300mah 3cell 25c lipo to make it lighter and have a smaller lipo.
I have done the aileron servo mod, but I'm really struggling on getting everything in with decent cooling and not fouling the aileron servos
Does anybody have some decent pics of their layout please with a similar setup
As I'm nearly at the point of jumping on it ;-) after 6hours and getting no nearer
Josh
joshy 3d is offline Find More Posts by joshy 3d
Old Nov 25, 2012, 11:08 AM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
After flying the Voodoo for a while and have had a couple of others to compare with I can only conclude nothing flies like a Voodoo. (At least nothing I have tried). I can only find one issue with it, that includes the "build". It's lacking 200mm wing span (~8 inches) After 5 minutes in the air my eyes are acing! So my question now, you in this thread knowing how a Voodoo is to build and how it flies. What's the most similar pylon racer too a Voodoo with +200mm span?
Thanks!
hakank is offline Find More Posts by hakank
Old Nov 25, 2012, 08:59 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I havent had anything as well put together, thought out, and complete as a voodoo. Petr Janku Speedfire f5b comes close, but thats a 2m F5b model.
Theres not much out there in the size range you mention ~40" Escape AKA Stiletto (made by topmodel but its certainly not a voodoo) . The HJK Speedwings LP1.1 is a very nice plane, probably the best bet (but its still not a voodoo haha)
Maybe something like the FVK Plasma, or possibly sunracer... but theyre not perfect either.
jackosmeister is offline Find More Posts by jackosmeister
Old Dec 26, 2012, 04:18 PM
rlc2052 is offline
Find More Posts by rlc2052
Something Something RC
rlc2052's Avatar
United States, PA, Philadelphia
Joined Nov 2010
Just received my Christmas VooDoo. This little thing looks awesome!
Gear list
Mega 16/15/2
Phoenix 60 esc
CC BEC
2 X d47
Futaba 3154
1800 45c TP 2s to start 3s later
GM 4.75x4.75
AR6210 receiver
I will probably sink the d47 servos in the wing similar to lukeydukey10.
I am just trying to figure out the layout of all of the gear in the fuselage.
Can anyone with a similar gear list let me know what worked best for them? Such as esc in-front of the battery or behind.
Also this is my first folding prop. Is it supposed to be able to fold forward past the 90 deg mark. I guess the centrifugal force keeps it from going to far forward when spinning?? What type of esc braking should I use with it?
Thanks for all of the great info in here.
rlc2052 is offline Find More Posts by rlc2052
Old Dec 26, 2012, 08:41 PM
Auckland NZ
Joined Aug 2007
Sweet, youll love the Vodoo.
Id be cautious about sinking the servos into the wing, wouldnt want to compromise the strength of it it (particularly in torsion). With some thinking and tweeking all your gear will fit fine without surgery
For layouts, click the Thread tools-View attachements menu in the upper right of the forum, youll find something that fits.
The GM F5D props work well, centrifugal force keeps the blades out Hard brake is fine, dont even need a ramp. The blade mass is so low I doubt you'll ever see one with a busted hub.
Be aware that on 3S youll need a new prop, 4.7x4.7 is a tad too big and will likely cook the lil mega. 2S is fine with it though, I run the 5x5 GM on 2S with my 16/15/2 (~130mph)
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
