Old Oct 31, 2012, 09:30 AM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
Originally Posted by lukeydukey10 View Post
Ps it's ice lite 50 which is different to ice50
Ice lite 50 just arrived..
You were right Jacko its a silly shape.... Not as it looks in the picture...
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Oct 31, 2012, 04:40 PM
voodoo magic maaan
Joined Jan 2011
Ice Lite 50 installed
Fits snug and looks great
Yet to rev it up and get data as baby sleeping :-(
Old Nov 02, 2012, 07:39 AM
voodoo magic maaan
Joined Jan 2011
ok, testing complete
With 3s nanotech and 4.7x4.7 prop I get 250 watts and 25amps
Seems a bit lacking in power.. Maybe I need to swap out the het 3w...
What kind of watts are others getting?
Old Nov 02, 2012, 07:57 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Pe˝a
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Seems like a reasonable place to start, I was not much above that in my mild setup. It's probably not where you want to end up but it's definitely a good place to learn the plane. I would guess that you can probably get a good 105mph - 115mph out of that setup if memory serves me right.
If you want just a little more to start with you can go up to an APC 4.75 X 5.5 which will draw a few more watts and give you a higher pitch speed without changing anything else.
I believe that the 3W is 3000KV, I started with a 2700KV motor on a Graupner CAM 4.7 X 4.7 and it was a good place to start for my first 20 or so flights but I'm now running ARC 3850KV with an APC 4.1X4.1 (still trying to master the new speed), need more practice.
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Nov 02, 2012, 11:36 AM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
I'm running mine with ~300w. A different setup with 2s though. Using the 2W HET But as Birger said, it might be a good start. And then prop it up..
hakank is offline Find More Posts by hakank
Old Nov 02, 2012, 02:51 PM
TimR74 is online now
Find More Posts by TimR74
United Kingdom, Wales, Monmouthshire
Joined Aug 2011
Anyone, with experience of lightweight setups in the Voodoo, reckon you could get the Voodoo to balance OK with a Mega 16/7 series motor (48 grams as opposed to 76 grams for the 16/15 series). This is with a small 1000-1300mAh 3S LiPo as a bigger one would kind of defeat the object.
I'm keen to keep it as light as possible and not too bothered about the outright speed given the small size. The nose does look fairly short and given it was designed around a speed 400 (same weight as 16/15) I think it might be a struggle?? Would place the ESC tucked up behind the motor at the top and battery as far forward underneath.
TimR74 is online now Find More Posts by TimR74
Old Nov 02, 2012, 04:08 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Although I obviously can't guarantee that it will work it seems to me that it should, as long as the ESC and battery can both be pushed right behind the motor (i.e. one on top of the other) and with the wing servos in the stock location you should be able to make CG.
Although the nose is short there is not much weight behind the wing, the tail moment is short and the fins are small, also, the elevator servo is mounted pretty far forward.
In my VooDoo I have this motor:
http://www.lightflightrc.com/HTML/pr...RC-28-37-2.htm
behind it I have either a 1600 3S 25C Nanotech or a 1350 3S 65C Thunderpower with the receiver above the battery, I then have the 40A ESC behind the battery and I have no issues making the CG, I actually have a 1/2" spacer behind the motor to ensure that the battery doesn't end up too far forward.
Regards,
- Birger
Old Nov 04, 2012, 05:40 PM
Joined Aug 2011
Thanks for the info.
I'm intending on using D47s in the standard location. I think I need to suss out a small thin ESC.
Old Nov 05, 2012, 06:56 PM
Edhs is online now
Find More Posts by Edhs
Edhs's Avatar
the seventh planet
Joined Dec 2010
can someone measure the thickness of the wing at a couple points? Ive been flying a Rifle for a couple seasons and want to step up speed with the same power. just wondering where the different airframe would take the speed.
Edhs is online now Find More Posts by Edhs
Old Nov 05, 2012, 09:50 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I don't have a Voodoo and can't give you any measurements, but I can tell you that damn thing is SLIPPERY and will definitely be faster than the Rifle on same power.
I have seen a Voodoo in-person and the wing is much thinner as is the horizontal stabilizer. It's definitely smaller than the Rifle in probably all ways that can be measured.
I need to get me one!
Tim
KRProton is online now Find More Posts by KRProton
Old Nov 06, 2012, 08:18 AM
Edhs is online now
Edhs's Avatar
the seventh planet
Joined Dec 2010
oh damn dont encourage me!
Old Nov 06, 2012, 08:35 AM
hakank is offline
Sweden (┼kersberga)
Joined Nov 2004
About 8mm at it's thickets point and 4mm at the thinnest. Will this get you to order?
Old Nov 06, 2012, 10:06 AM
Edhs is online now
Edhs's Avatar
the seventh planet
Joined Dec 2010
for comparison the Rifle is 10mm at root 8at half way and 5mm 25mm from the tip.
Quote" Will this get you to order? "
not on its own but the high praise and happy followers is deffinatly a push towards it!
Old Nov 06, 2012, 11:37 AM
hakank is offline
Sweden (┼kersberga)
Joined Nov 2004
I can tell it's my favorite at the moment, with only 2s!
Old Nov 06, 2012, 12:08 PM
Joined Aug 2011
I've spent a while reading thro most of this thread for some research. Gone off the idea of the Mega 16/7 now and will stick with the tried and tested 16/15. Will start off with a small LiPo or maybe 2S, gives better options to grow into more power and speed once I'm comfortable flying the plane.
Just as a heads up for people using medium power 3S set-ups, struggling with squeezing everything in. This battery looks ideal:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Light @ 118grms for its capacity and a very slim 14mm thick.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
