Old Aug 27, 2012, 08:59 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by dougmontgomery View Post
Flew mine this weekend- it is amazing how far it travels on spektrum lock out. It recovered and I pulled out of it safely and landed. Just purchased a Futaba Fast module last night- save the spektrum junk for my slope junk.
I have a Neu motor 1105/2.5Y/3.2- Is the 4.1x4.1 prop the best one for this motor on a 2100 3 cell?
doug
Heck No....get a 4.5X4.1 on there Fast ....But strange,i have a AR600 in mine with over 60+ flights with not so much as a shutter....I could not imagine a lock out at those speeds.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Aug 27, 2012, 09:10 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
I was not pushing it too much kind of getting used to it when i was bringin it around high to low when it locked, i quickly landed after that.
Thanks for the recommendation-
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Aug 28, 2012, 08:38 PM
olllian is offline
Find More Posts by olllian
olllian
olllian's Avatar
United States, AZ, Chandler
Joined Nov 2011
Can you use a specktrum 6210 reciver in this plane?? I herd that on carbon fiber planes you need a special reciver thx
olllian is offline Find More Posts by olllian
Old Aug 28, 2012, 08:40 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
I haven't used this receiver in particular, I fly Futaba but note that this plane is not carbon fiber, it's fiberglass with the exception of a little carbon tow around the wing saddle. I haven't heard of anyone having any problems but I fly a mid-range receiver in mine and have so far been totally glitch free.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Aug 29, 2012, 07:17 AM
hybris is offline
Find More Posts by hybris
hybris's Avatar
Houston, TX
Joined May 2003
That would be fine. I use an ar7000 in mine. I just took the cases off and used shrink tubing. I fit the satellite behind the elevator servo in the fuse. The main receiver antenni stick out the fuse sides.
hybris is offline Find More Posts by hybris
Old Aug 29, 2012, 08:03 AM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
That's good idea
Old Sep 02, 2012, 10:33 AM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Third flight today despite the rain hanging in the air. Still in one piece and I'm still in shock, can't really get use to it, after giving it full throttle. It was a bit windy and it's rather sensitive, or it might have been very windy in fact, rocking sideways. I was thinking of maybe adding a gyro on one aileron. If I can squeeze it in. Anyone tried that in the Voodoo? I have fitted all my other electric planes with multiwii (3 axis stabilization) so I might be a bit spoiled.
/Håkan
hakank is offline Find More Posts by hakank
Old Sep 02, 2012, 10:55 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
/Håkan
Hi Håkan,
This plane, when set up correctly, is rock solid no matter what the wind is, no need for gyros. Note the key point here, when setup correctly. So let's go a little into the setup to see if you need to tweak anything. There are two things that can make it nervous when flying, CG or Aileron Rates.
What is your CG? The CG on this plane is a balance between a great locked-in feel and ballooning under high throttle. If your CG is too far forward the plane will fly very locked in but it will want to climb on the straight aways at very high speed. If the CG is too far aft then the plane will not climb (or at least not as much) and it will actually land even easier as you will have enough elevator but unfortunately it starts getting nervous at high speed (harder to fly it smoothly). I have a compromise in my CG where it flys pretty locked in but still ballons a little at the highest speeds, for this a have a little reflex mixed in with my throttle to kill some of the lift at full throttle.
In your case double check the CG to make sure it is not to far aft (or just try it a little farter forward).
What are your rates on your ailerons? Remember that this is a speedster and as such it demands very low rates. I have mine set up that at full throw, on landing approach I can barely get it to bank. I mean, I hold full stick for over a second to get in or out of a 45 degree bank. Even at that super reduced rate and with a 60% low rate for high speed, when I'm full throttle up at about ~130MPH it is hyper sensitive on the ailerons and about 1/4 second on full stick will give me a 90 degree bank.
The faster you go the less movement you need, maybe a switch with tripple rates? Remember the manual calls for 3.5mm up and 2mm down. I have less than that and I certainly would not go more.
One more thing, if you had to bring your endpoints down on your radio to get to the required throws then you may have centering problems due to poor mechanical advantage. When I did my installation I had to drill a new hole in my control arm inside the hole that was closest to the center as this was the only way I could get the correct throws without sacrificing mechanical advantage.
Some pictures on my setup (note the picture that shows how close the control arm is to the center of the servo): http://www.rcgroups.com/forums/showt...0#post19489783
Hope this helps but feel free to ask any more questions,
Hälsningar,
- Birger
Old Sep 02, 2012, 10:57 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Forgot to add one thing, due to the sensitive nature of the control surfaces at high speed a little bit off on the trim at low speeds, something that may just seem to be an annoyance, may actually cause the plane to roll over at high speeds so double check your trims. Also, check your motor and rudder incidence to ensure that they aren't off.
- Birger
Old Sep 04, 2012, 11:01 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Thank you very much for the extended version in how to tune the Voodoo! However I might have been a bit unclear. What I meant was it was sensitive to wind, or gust making it roll over rather easy and not by my input. It's not a big problem when flying it fast but at sub ~50mph I really have to watch it and make constant corrections. Note, it was probably rather windy and I should maybe not made it airborne that day..
But I will walk through your recommendations!
/Håkan
Old Sep 04, 2012, 02:40 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
/Håkan
the past days I almost crashed a few times, my small planes rocked their wings, I thought I was getting out of control sometimes, very hard to fly, gusty winds... I think is mostly the wheather doing it,, wait till a calm day, then try againm that plane should be solid..
Sebbe
sebbe is offline Find More Posts by sebbe
Old Sep 04, 2012, 03:43 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
When I ordered mine from Hollein I first checked with Miro Urban who seems to be the guy building them. (He took the same price as Hollein btw) He said 4 weeks for delivery. Hollein said 4-6 weeks. So it looks like they are built on demand.
/Håkan
Yes, they are build on order. You have to get in line for that. They always are in backorder. i had to wait for mine 6 weeks. That's alright if you have other project on the bench.
Too bad my current sensor fried at full power. My Voodoo went in at max power (560W/estimated 290kmh) pretty hard. The build is somewhere in this thread.
regards,
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Sep 09, 2012, 02:32 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by bdelapen View Post
hi håkan,
in your case double check the cg to make sure it is not to far aft (or just try it a little farter forward).
hälsningar,
- birger
lmao
feefo is offline Find More Posts by feefo
Old Sep 11, 2012, 11:46 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
CG seems to be spot on but I will try with moving the battery a little bit forward. Thanks.
/Håkan
Old Sep 26, 2012, 08:55 AM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
ok, voodoo arrives soon
I am toying with the idea of getting a cc ice lite 50 and squeezing it into this little rocket
anyone had experience of this?
lukeydukey10 is offline Find More Posts by lukeydukey10
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
