Old Jul 22, 2012, 08:48 AM
mofosheee is offline
Find More Posts by mofosheee
Joined May 2009
Voodoo.......can you please enlighten me on your spoileron settintgs for slowing your Voodoo down on landings? i.e. travel of spoilerons and elevator. Thanks again
Jerry
mofosheee is offline Find More Posts by mofosheee
Old Jul 22, 2012, 10:29 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Jerry
Actually, the manufacturer recommends (and I use) flapperons, not spoilerons.
Look at the manual for their recommendations:
http://www.rcgroups.com/forums/showp...&postcount=844
Look at this post for my setup and mixes:
http://www.rcgroups.com/forums/showp...postcount=1102 (note, I have since adjusted my ailerons to 60% for low/high-speed rate)
I still need practice to smooth out my flying at full throttle but I can tell you it has been a long long time since I missed a landing, the setup works great for me.
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Jul 22, 2012, 10:47 AM
Joined May 2009
Regards,
- Birger
Thanks Birger!
Jerry
Old Jul 22, 2012, 01:51 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Thanks Birger!
Jerry
Birger knows the VooDoo like no other I am using 3mm down on the ails.Are you close to flying it ?
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jul 22, 2012, 02:07 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Well, I'm not sure about that, there are plenty of people that fly this plane in competition and know it much better than I do. I'm just a sport flyer who likes to share my experiences so that others may learn from them .
- Birger
Old Jul 24, 2012, 05:22 AM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Just to be sure I got this right before I maiden my Voodoo. I should have 3mm down at landings? And not up which I have had on my Dragon Red which caused a significantly amount of air break.
Thanks, Håkan
hakank is offline Find More Posts by hakank
Old Jul 24, 2012, 07:24 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Thanks, Håkan
Thats it! I even found with mine I didnt need any elevator mixed in to compensate. The voodoo is such a well flying plane.
SB7 is offline Find More Posts by SB7
Old Jul 24, 2012, 08:00 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Thanks, Håkan
Yes, down. It's just a little and it helps a lot, it still glides forever but at least it does it a lot slower. I will typically do two or three circuits around my field after power off before setting up for a landing, and even then I set up for a long approach. With a little practice you will find that it is very easy to land.
Hälsningar!
- Birger
Old Jul 24, 2012, 08:12 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Ok, thanks a lot both of you!
/Håkan
Old Jul 28, 2012, 05:08 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
A question about gluing the aileron servos. What if I need to replace them, assuming I use 30 min epoxy and glue it directly to the wing. Is there a better way?
if mounting them in the stock position?
Thanks!
/Håkan
Old Jul 28, 2012, 06:01 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Heathrink or tape arounnd the servo case, then glue
jackosmeister is offline Find More Posts by jackosmeister
Old Jul 28, 2012, 11:20 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Thanks, Any tape or? (Don't have that diameter of my headshrink stock)
/Håkan
Old Jul 28, 2012, 11:47 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
In my case I gave it some thought and decided to glue them right in. I figured, servos are not so expensive that I would want to remove them to put in another plane if this was still flyable. If a servo goes bad and I miraculously don't crash the plane then I don't mind destroying the servo to remove it. If the plane crashes beyond repair then again, statistically, the servos will probably break anyway and even if they don't well, I'll be out $35.00. I don't love it but I would rather have that than take the risk of having an issue with the tape or heat-shrink (i.e. one more thing that could fail).
Just my two cents.
- Birger
Old Jul 28, 2012, 12:25 PM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Hmm..
It will hurt a bit but I think you are right..
Thanks for the input.
/Håkan
Old Jul 28, 2012, 12:31 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Not to beat a dead horse but remember, it's not as much a concern that the servo will come off but if it just comes loose enough that the aileron won't center correctly or if it shifts during motion that could be enough for a crash. I'd rather save my $270 airframe than my $35 servo.
- Birger
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
