Old Dec 28, 2004, 06:48 PM
psycho_klown66 is offline
Find More Posts by psycho_klown66
There are FOUR LIGHTS !!!
psycho_klown66's Avatar
Long Beach Municipal, California, United States
Joined Sep 2004
Fancy Foam Extra 300L Setup
The Fancy Foam Extra 300L is going to be my first 3D Plane and I have the following for it:
Axi 2212/34
Hitec HFS-04MG Receiver
4x Hitec HS-55 Servos
Phoenix 10
Etec 11.1 1200 Lipo
APC 11x3.8 Prop
APC 11x4.7 Prop
APC 12x6 Prop
I have those parts because that's what I have at-hand.
Now for my questions:
1. With the Axi 2212/34, I have 3 props listed. Which prop should I use?
2. Is the Phoenix 10 ok with this setup? 10 Amps is the max for the Axi which is why I picked this ESC. Or will the Phoenix 10 be a bottle-neck?
3. Hitec HFS-04MG should be fine unless I decide to go with flaps, then I would get the Electron 6.
Thanks!
psycho_klown66 is offline Find More Posts by psycho_klown66
Old Dec 28, 2004, 07:11 PM
Ynksrock510 is offline
Find More Posts by Ynksrock510
Rockland County, New York, United States
Joined Sep 2004
that depends, how many amps can your battery handle?
with the 11x3.8 at 11.1 volts you will get around 26 ounces of thrust using a little under 9 amps
with the 11x4.7 at 11.1 volts you will get around 28 ounces of thurst using a little over 10 amps
with the 12x6 the amps will be very high which will be bad.
I would go with the 11x3.8 as you get a good 26 ounces of thrust keeping the amps at a safe level.
Ynksrock510 is offline Find More Posts by Ynksrock510
Old Dec 28, 2004, 08:26 PM
Joined Sep 2004
The average discharge rate is 8.5c and 10c Max, so (please let me know if I'm wrong, still learning):
1c of 1200 = 1.2a x 8.5 = 10.2 Amp Average
1c of 1200 = 1.2a x 10 = 12 Amp Max
Old Dec 28, 2004, 11:47 PM
Boss248
Boss248
Guest
n/a Posts
You got it..the key factor is the batteries discharge rates here so I have to agree that 12-14 amps is what you wanna shoot for but the Axi can sure handle more when/if you get hogher d/s batteries.
I use an Axi 2212/26 with a GWS 10/4.7 and on the 1320 3s Thunder Power 2nd Gens it is extremely powerful. I have used a 11/4.7 on it before with good results. I have pushed 20 amps thru a CC10 and none of the smoke came out so I think you will be ok with the CC10...you are really going to enjoy the plane and power combo...keep it as light as humanly possible..try not to add ANYTHING that does not have a function to the plane...3 grams here..5 grams there..can really add up fast...I am going to design a 3D foamie that does not need glue real soon..yes a "Snaptite" FFF 3D er..no glue...!
Boss
Old Dec 30, 2004, 03:27 AM
Joined Sep 2004
Sounds good.
I'll try the 11x3.8, 11x4.7 and 10x4.7
Now, just gotta wait for the shipment to arrive!
Extra 300L scale 3 view pgleesonuk Sport Planes 1 Oct 12, 2007 01:52 AM
Article Fancy Foam Extra 3D Ultra High Performance Package Review JTinCT Foamies (Kits) 2 Sep 17, 2004 04:39 PM
fancy foam extra 300 Sammy B 3D Flying 9 Jul 29, 2004 12:49 PM
Extra 300L / 330L 3 view Martin Hunter Scale Kit/Scratch Built 3 Jul 01, 2002 04:40 PM
