Old Dec 28, 2004, 10:53 AM
dentflyer is offline
Find More Posts by dentflyer
Joined Dec 2004
Yippee!
Blade runner mods (good ones)
Blade runner problems
Over the last few days we have encountered a number of problems with my son’s new blade runner and thought others might benefit from the solutions we found.
Charging – The unit did not charge, with the light on the controller flashing randomly. Solution, bend the contacts very slightly to the side, on the helicopter. This will increase the contact with the charging lead. We have had to do this a few times, but the charge time is approx 20 to 30 minutes and give good flight time e.g. 4 to 5 minutes.
Trim problems – The unit would not stop spinning to the left, even with full trim to the right. Solution, the trim switch operates be increasing or decreasing the speed of the rotor. The rotor need to be creating equal amounts of force to counteract each other and allow the helicopter to remain stable and not spin. If the unit is spinning to the left (anticlockwise) very gently increase the bend along the length of the plastic wings in the upper rotor, particularly at the ends. Additionally, remove some of the bend in the lower rotor. This may take a couple of attempts. The affect of this is to allow the upper rotor to have more power and so overcome the turning force the lower rotor is generating (If spinning clockwise do the opposite with the rotor)
Forward/backward movements – Remove the circle of plastic around the tail rotor, this gives the rotor more force and allows the helicopter to move quicker in the forward and reverse direction. (this works very well.)
dentflyer is offline Find More Posts by dentflyer
Old Dec 28, 2004, 01:50 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
These are all great suggestions. There is an enormous thread on one of the other forums where these and other mod's have been discussed, you can find it here:
http://www.rcgroups.com/forums/showthread.php?t=294497
Or if you don't want to spend hours reading through that giant, there is a nice synopsis of the mod's here:
http://theclassroom.50megs.com/Blade...nformation.pdf
When you're ready for even better performance, stripping the plastic body off removes 1/10 the weight and results in much more spritely climb rate and control response. It also allows better cooling of the motors and longer motor life. If you do this mod, untape the battery and slide it outside of the frame and as far forward as the wires allow, then tape it back in place. This will adjust the "COG" (center of gravity) to compensate for the body removal.
Tres Wright is offline Find More Posts by Tres Wright
Old Dec 28, 2004, 10:37 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
Your solution to the charging problem is very interesting, as this could solve one of worst problems.
I think one of the best mod is the landing gear mod. The way the landing gear is made, they flatten out very easily. If you bend them in a arc (looking from the front), you will be amazed how strong they will be. And never have to be adjusted again.
Kwok_Yu is offline Find More Posts by Kwok_Yu
Discussion Blade runner 2 Mods/Problems jc141878 BladeRunner Heli 8 Nov 01, 2006 07:18 PM
Blade runner mods? grant31781 Scratchbuilt Indoor and Micro Models 0 Jul 05, 2005 02:34 PM
Kyosho Blade Runner... Dustin_v16 Racing Boats - Electric 6 Sep 15, 2004 04:03 AM
Online book stores,"Any good ones out hear" KOMET 44 Electric Plane Talk 4 Dec 28, 2001 07:55 PM
Lite-Stik mods...a good Idea bgkast Parkflyers 16 Jul 27, 2001 08:49 PM
