Old Dec 27, 2004, 09:31 PM
snowball1288 is offline
Find More Posts by snowball1288
1Point Landing Specialist
Joined Nov 2004
Smallest Flying Wing Possible
Does anyone know if its possible to build a 12" flying wing. I think i might get some Blucore and try it. What motor/gearbox/battery combo would work best?
heh... that would be a fast plane.
snowball1288 is offline Find More Posts by snowball1288
Old Dec 27, 2004, 10:15 PM
e-sailpilot86 is offline
Find More Posts by e-sailpilot86
e-sailpilot86's Avatar
Joined Jun 2001
It's probably possible to build a 3" flying wing... For that size, I'd snag the smallest direct drive motor you can, actually, you can probably just use this:
http://www.balsapr.com/catalog/motor...ductId=U227032
Use an IPS or LPS motor from GWS to power your plane. Just use that motor, a two cell li-poly from 250-800mah's, a light Rx (R4PII or less), some .20 or .16 oz servos, and a two amp esc. Should be a piece of cake.
I'd bet the LPS setup is your best. Balsa products had a LPS short brushless motor + ESC combo, but they're out of stock. You may want to use the cirrus joule servos and Rx + ESC's to stay on the safe side. It's just that they get expensive.
e-sailpilot86 is offline Find More Posts by e-sailpilot86
Old Dec 27, 2004, 11:05 PM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
At 12" a CD-Rom motor and 4-6 gram servos will treat you very well for performance. You should be able to keep it under 3 oz. The little supermite that superflyrc has is only 16" as is the micro speed wing. It isn't hard to cut them down smaller, but probably isn't worth it.
To build much smaller than that you have to go to the expensive micro gear, and those aren't built to perform... only to be very small and still fly.
mjws is offline Find More Posts by mjws
Old Dec 27, 2004, 11:08 PM
jimsky is online now
Find More Posts by jimsky
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
That Hobby Electronics 1230 motor/prop set was built basically as a GWS EDP50 copy. It's the same size and weight as the GWS motor but it doesn't perform as well. I've done extensive testing of both motors and the EDP50 motor is more efficient, run cooler, uses less current and produces more thrust. I'd just stick with the EDP50.
That HE 100mm X 80mm (4030) "twisty" prop is a very cool prop. I use them on some wings and other planes I have. Fits right on an EDP50 shaft. BP sells them alone for less than a buck, I love them.
I've heard that a certain wing manufacturer is working on a 12" EPP flying wing prototype. That would be a panic to fly!
Jimsky
jimsky is online now Find More Posts by jimsky
Old Dec 27, 2004, 11:39 PM
marjamar is offline
Find More Posts by marjamar
SpeedWing Test Cruncher
marjamar's Avatar
Loveland, Colorado, United States
Joined Jan 2003
Below 16" has too many diminishing returns to be fruitful. Acer made a 12" version over a year ago, but it's just too small to be useful outdoors and indoors there are funner things to fly. I'm having so much fun with the µsw running the Feigao Brushless on 3-cell 830 lipos at about 4.6 AUW, I decided to make another lighter version using 3-cell 340 lipos. It should come in at about 3.7 oz. AUW with the lighter cells and a couple of other mods for even more fun . These do totally unlimited vertical. The 4.6 oz. will do about 30 MPH vertical and 70 MPH level flight. The 3.7 oz. should do vertical at about 45 MPH and 70+ MPH level flight.
-Rodger
marjamar is offline Find More Posts by marjamar
Old Dec 28, 2004, 01:26 AM
Joined Nov 2004
Yes... id like it to go pretty fast, so maybe under 16" isnt a good idea. What setup is good for a REALLY fast wing? Im a little short on $$, so i think a brushless is out of the question, but... what size is speedy?
or rather... whats teh best size wing for my current equipment:
-Electron 6 receiver
-HS-55 servos
-Blucore foam
-3S1P 1500 Kokam pack
Maybe i could add:
Speed 400 motor
C-20 ESC
What size do you guys think? 24"?
Old Dec 28, 2004, 02:49 AM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
Did you search through the Micro and Indoor model's forum? There's planes well under your 12 inches there.
Arthur P. is offline Find More Posts by Arthur P.
Old Dec 28, 2004, 06:39 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
We built a 12" UP in the past , flew fast with ips -s1, 700 lipos, well it's sort of a wing...???
gpw is online now Find More Posts by gpw
Discussion How to make the noisiest flying wing possible Accu157 Flying Wings 17 Mar 31, 2007 10:03 PM
Pitcheron flying wing possible? MattyB Slope 14 Dec 03, 2005 01:48 AM
Looking for SMALLEST flying wing superdave42 Scratchbuilt Indoor and Micro Models 25 Jun 14, 2004 10:59 PM
Is a jedelski flying wing possible? Moogee Modeling Science 14 Sep 05, 2002 10:36 PM
Smallest flying wing? snowman610620 Foamies (Kits) 9 Mar 02, 2002 12:00 PM
