Old Jun 17, 2001, 04:18 AM
trevsie is offline
Find More Posts by trevsie
Surrey,UK
Joined May 2001
How to make scale WW I aircraft wheels?
Has anyone any tips for making scale WWI aircraft wheels or somewhere that sells the for a reasonable price (in the UK preferably)? I want some 2.5 inches diameter
These wheels tend to be expensive in my experience
Regards,
Trev
trevsie is offline Find More Posts by trevsie
Old Jun 17, 2001, 04:27 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
An article in EFI recently (Jan or Feb 2001 I believe) described a way to make them in great detail.
Trizza is offline Find More Posts by Trizza
Old Jun 17, 2001, 09:01 AM
BillBowne
BillBowne
Guest
n/a Posts
If you want them quicker and easier, try this:
Sandwich two layers of 3/16" balsa sheet over a core of 1/8" light ply.
Cut the whole thing to a round shape.
Using pencil or felt-tipped pen, draw where the inner edge of the tire/tyre will be.
Drill through the center. The hole has to be big enough to hold a bolt, and will be (mostly) filled in later.
Mount the assembly on a machine screw/bolt, then tighten one or two nuts onto the bolt to hold the wheel blank firmly in place.
Chuck the assembly in a Dremel, drill, etc. (I don't have a lathe, so I don't know if one would work).
With the blank spinning at a comfortable speed, use a sharp X-Acto knife (WELL-BRACED!) shape the blank as needed.
When done, remove the wheel from the bolt, drill out the hole, and insert a (preferably) pre-drilled-out piece of dowel. This will be the wheel bearing.
Paint as needed.
Wheels done this way will work very well on grass. When the wood starts showing through the "rubber", I use a black marker to cover it up.
Bill B.
Old Jun 18, 2001, 02:05 AM
Trizza is offline
Trizza's Avatar
Joined Feb 2001
For really good looking spoked wheels the EFI method is great though.
Old Jun 19, 2001, 02:51 PM
trevsie is offline
Surrey,UK
Joined May 2001
Many thanks for the advice
Regards,
Trev
How to Make a Micro-Scale Bell 412!!! pitts Micro Helis 142 Feb 26, 2012 08:19 PM
How to make small lightweight wheels? Compared to store-bought? Martin Hunter Scratchbuilt Indoor and Micro Models 8 Sep 20, 2005 03:16 PM
Wheels and machineguns for 1/4 scale WW1 aircraft mario alvarez Scale Fuel Planes 3 Mar 18, 2005 10:45 AM
[P51D]How to make EPP scale planes that are light and almost unbreakable mimei Foamies (Kits) 2 Dec 15, 2004 07:03 AM
How to make scale smoke from electric powered planes. KOMET 44 Electric Plane Talk 0 Sep 08, 2001 07:05 PM
