Old Mar 05, 2002, 11:13 AM
microflyer77 is offline
Find More Posts by microflyer77
microflyer77's Avatar
Mission Viejo, California
Joined Jan 2002
Pink Foam cutting tips
Greetings Foam Experts,
Newbie question. I finally dragged myself to Home Depot to get some 1" thick Pink Foam sheet (Says 'Dow Foamular'). I'm planning to build left and right pink foam sides around a 1/18" sheet balsa profile fuselage for an Art Chester Racer from the thirties.
I know and have read all about nichrome wire/bow arrangement and also have a railroad transformer (MRC) but don't want to go the hot-wire method at least initially. (Newer houses are *really* close together here in LA and the fume might bother/scare my neighbors). I'm guessing there might be quite a bit of burnt plastic odor initially.
What other tool can you use (without making a mess) to ,
1. Cut off pieces to profile in plan (I do have a X-acto jewelers saw now, anything else?)
2. Smooth the pieces FAST (RASP should work well, but what grit sandpaper to buy?)
3. Can you wet sand for final finish with waterproof 220 grit? Will the wet sanding put water inside the foam that takes a while to dry?
Sorry if these are just too obvious.
P.S. If you all think that hotwire cutting the foam is the easiest route, then roughly what temp. range should the Woodland Scenics Nichrome wire be?
Pictures, diagrams and pointers very welcome.
microflyer77 is offline Find More Posts by microflyer77
Old Mar 05, 2002, 11:42 AM
towlebooth is offline
Find More Posts by towlebooth
St. Paul, MN
Joined Feb 2001
If you were worried about the fume/smell factor I suggest getting a Wonder Cutter. It's a small D-Cell powered bow foam cutter that sells at craft stores for $7.00. That way you can see how bad the smell is without forking over a lot of dough.
It really is not that bad if you have a window in your work area. Wire cutters are the way to go.
Chad
towlebooth is offline Find More Posts by towlebooth
foam cutting tapered tips GaryO Composites Fabrication 5 Aug 10, 2005 11:24 PM
Foam cutting tips!!! Martijn Kaandorp Foamies (Kits) 7 Feb 24, 2005 05:11 PM
Pink Foam Material realglow Electric Plane Talk 11 May 29, 2003 07:15 PM
Glues for Pink Foam WAR Parkflyers 7 May 24, 2001 09:38 AM
Foam cutting - electronics question AC to DC ChrisD Power Systems 5 May 02, 2001 05:11 AM
