Old Aug 31, 2011, 06:10 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Keep us posted on how she flies!
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 31, 2011, 06:23 AM
dwt3d is offline
Find More Posts by dwt3d
springfield
Joined Nov 2003
i flew it a couple of times but to windy to get a good video. i am going to try to get it today. i am also working on another one with a bigger tail surfaces and a 10 gram motor with a 2 cell batt. to put it on a diet mine weighs 5 3/4 now i am wanting to get down to the 4oz area
dwt3d is offline Find More Posts by dwt3d
Old Sep 17, 2011, 12:03 AM
dwt3d is offline
springfield
Joined Nov 2003
gym blu
here is a short video because all my batteries were about dead and my wheels broke doing looping touch and go's
dwt3d gym blu (2 min 10 sec)
Old Sep 18, 2011, 08:07 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Looks great!
Glad you're having fun
Old Jan 18, 2012, 12:52 PM
ParkzoneFan is offline
Find More Posts by ParkzoneFan
Flying Ostrich
United States, KY, Bowling Green
Joined May 2011
Gym Blu w/ ailerons
http://www.youtube.com/watch?v=UHxlNLU7G2Y
Thanks Gene
going to try one out with ailerons and a heads up rc "250 plus"
500 mah 2s, 3- hs55's at 6.6 oz AUW without pushrods so far.
Gym Blu
ParkzoneFan is offline Find More Posts by ParkzoneFan
Old Mar 23, 2012, 07:02 PM
Flying Ostrich
Joined May 2011
with Ailerons
Old Nov 20, 2015, 09:07 PM
bhursey is offline
Find More Posts by bhursey
bhursey's Avatar
Joined Apr 2015
Has any one tried this with DTFB or adam's or ross foam board?
bhursey is offline Find More Posts by bhursey
Old Nov 20, 2015, 09:39 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
I just finished forming an undercambered wing panel for something similar. I removed the paper from the Adams board I got at Dollar Tree and cut a 20 inch span by 7.5 inch chord panel. I scored the front half of the bottom of the panel with a roller for installing storm window seals, about 1/16 inch wide, at 1/2 inch intervals. I rolled in the undercamber with a piece of PVC drain pipe. Between rolling, I used a heat gun to temper the surface of the board as Gene does with blue foam back in Post #11. I got a nice firm undercamber with little spring back. A few ribs of the foam should hold it.
There's little difference between the Adams board and the blue foam besides the thickness. To make the resulting wing strong enough, you may need to take more care reinforcing it. I made a similar wing from blue foam for a Park Pilot EZ-Cruiser and added colored packing tape on the bottom, more for visibility than strength, where I had stripped the original plastic film skin. On board from Dollar Tree, without paper, I'll add colored packing tape top and bottom for strength, though I might not need it for a Gym-blu sized plane flying indoors.
The beauty of the cheap foam is, that if it cracks, you puts down your buck and tries again.
DuPageJoe is offline Find More Posts by DuPageJoe
Old Nov 21, 2015, 04:55 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
This is really a great flying plane ... Even Better in the Large size ..
gpw is offline Find More Posts by gpw
Old Nov 23, 2015, 10:07 PM
bhursey is offline
bhursey's Avatar
Joined Apr 2015
Well i was going to build the gym-blu slow fly stick powerd by a old gws motor and prop from my gws slow stick. I cant currently drive so i wanted something i could try and fly in a small area in my negborhood.
I went to see family my grand fauther built model boats and he passed away 2 years ago my grand mother gave me all his wood mostly balsa and bass wood.
I was given a ton of wood. So wood version? So i started drawing out a balsa version framing. I also plan on building a wing. Where is the plans.. http://www.rcgroups.com/forums/showa...1&d=1105248853
The wing i am going to try and use is the NACA4408 air foil outlined here. http://www.stenulson.net/rcflight/lsb.htm I will have to use bass wood ribs o well..
Think this will work? This is really my first balsa build since 1999 and really my forst designing custom balsa frame from plans.
So Far the tail is done..
I still may make a foam wing first but i feel the wood wing would be lighter and in general ware and tear better
Old Nov 26, 2015, 09:23 PM
bhursey is offline
bhursey's Avatar
Joined Apr 2015
Got the wing plans and pices cut out its 30 inches with 7 degree dihedral. With undercamberd wings. The wings width is 8 inches with trailing balsa edge to match the plan..
Old Nov 26, 2015, 09:53 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Following with interest. If you built this with foam you'd be flying by now, but...... I'm just joshin you, looks very cool. Nice job on those ribs.
JohnsPop is offline Find More Posts by JohnsPop
Old Nov 27, 2015, 06:52 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Really !!! Balsa is a much slower build !! An oddity in the Foamie section ...
Old Nov 27, 2015, 10:38 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
One of my first scratch-builds was a slower version of the LiteStick in Balsa and Reynolds Wrap by AZ Chuck. I wonder what happened to him, he was active here back in the day...
Old Nov 28, 2015, 05:09 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Gene , that “day” was some time ago .... hahahaha Great to hear from you again !!!
Discussion Simple Indoor 3D Micro Plane project Electronick Scratchbuilt Indoor and Micro Models 3 Dec 27, 2007 12:58 PM
Discussion Does anyone have a simple stick plane plan SPITFACED Electric Warbirds 2 Aug 10, 2007 08:47 PM
Stick plane with plastic shell SpaKack Parkflyers 19 Oct 14, 2002 12:52 AM
Ace Simple Series Ultimate Bi-plane: anyone try one? Any powerplant suggestions? Falcore Electric Plane Talk 6 Jun 03, 2002 11:54 PM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 10:52 PM
