Old Jan 03, 2005, 07:59 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
JBC, you're right , but I'm way too cheap to buy foam safe ca to glue hinges in with , plus I prefer a sealed hinge line , reducing drag and making the control surface more efficient ..... mostly cheapo though ....hahahaha
gpw is offline Find More Posts by gpw
Old Jan 03, 2005, 08:03 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
GWS glue and other, similar foam-safe contact cements (UHU) work well, too... I've used hot glue for field repairs of torn-off control surfaces...
But I agree, tape is quick, cheap and easy. I'll have to try a little sanding next time and see if it cures the tempered foam / tape release problem.
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 03, 2005, 08:21 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Gbond.. I've decided to taper the Spruce fuselage (every effort to save weight)... will be tapering just like I taper my Arrows, with a small block plane and a pencil ...plus I found some 3mm Dep ,that I can use for the tail surfaces.... I am removing the skin on the standups and sanding them to a sorta' rounded shape ....trying to get it light enough for the lps system ... what a neat little plane !!!! Thanks Gbond!!!!!
I've been using Pacer Formula 560 canopy cement , not only to glue small parts , but to assemble any Dep or skinned foam ... slow drying ,but nearly invisible , light and really seems to stick well ... haven't run across GWS or UHU CC here ...????is it really that good ???should I get some ???
Old Jan 03, 2005, 08:55 AM
t1mux is offline
Find More Posts by t1mux
Mocking Birds
t1mux's Avatar
VA
Joined Apr 2004
I picked up a tube a while back, because Gene kept talking about it in different posts. I know people are wierd about there favorite glues and I was a total skeptic of the UHU Creative, but was sold on it after putting together a Uni-Fuse with it. Not one of my zipper notches were square and some didn't even line up, but the UHU creative holds them together so tight you can't even see the seam in some spots. It is not for everything but I couldn't imagine doing anything boxed without it. Very light and strong also.
t1mux is offline Find More Posts by t1mux
Old Jan 03, 2005, 10:37 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Yes, the UHU Creativ is good stuff. I can't remember if it was Michael's or Hobby Lobby that caries it, since ours are right next to each other. I like to use it where I used to use 3M-77 sprayed in a cup and brushed on. This is basically anywhere were hot-glue would cool faster than I can assemble it. Works as well, or better. I just picked up some other UHU glue, can't remember... almost, but not quite as good. Can't let it get fully dry before joining.
Here it is, Twist & Glue: http://www.saunders-usa.com/uhu/ looks like you can order on-line... But, it seems one of the on-line HS's was offering GWS glue cheap, as well... Maybe Balsapr.com ?
I have never been patient enough for 560 to dry seems like a week or so drying time!
Old Jan 03, 2005, 10:51 AM
sawicki is offline
Find More Posts by sawicki
Saint Petersburg, Fl
Joined Jul 2003
Originally Posted by Gene Bond
Yes, the UHU Creativ is good stuff. I can't remember if it was Michael's or Hobby Lobby that caries it, since ours are right next to each other. http://www.saunders-usa.com/uhu/ looks like you can order
Gene, the link you provided shows 6 different types of UHU Creativ. Which one do you use?
Cardboard & Craft Paper
Metal, Glass & Jewelry
Styrofoam®, Film & Foils
Mosaic
Wood & Natural Materials
Plastics & Miniatures
Felix
sawicki is offline Find More Posts by sawicki
Old Jan 03, 2005, 12:39 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The styro version: http://www.saunders-usa.com/uhu/prod...9&prod_id=9025 Sorry for the confusion.
Old Jan 03, 2005, 12:57 PM
sawicki is offline
Joined Jul 2003
Thanks Gene. I'm looking forward to trying it.
Felix
Old Jan 03, 2005, 05:56 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
me too !!! will get some!!! Thanks !!! Gbond... you know some stuff !!!
Old Jan 03, 2005, 06:35 PM
robbie is offline
Find More Posts by robbie
robbie's Avatar
Barsoom
Joined Jan 2004
gym blu under construction.
are there any plans for the pfc in pdf format?
i am using depron. should i use a bamboo skewer and/or tape to stiffen the wing?
if so, where do i put it? under the wing near the cg?
i think i saw some parkflyers that had a sort of a WWI looking thread rigging
robbie is offline Find More Posts by robbie
Old Jan 03, 2005, 08:01 PM
jbc455 is offline
Find More Posts by jbc455
jbc455's Avatar
San Jose, California
Joined Jan 2002
RTF weight- 5.54 ounces. That's mostly because I used a dual IPS I had laying around.
Not that I'll need the extra power, but I've found that "need" has very little to do with it.
jbc455 is offline Find More Posts by jbc455
Old Jan 03, 2005, 09:17 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
robbie: PM with an email address, and I can send the PFC plans in pdf. Let me know if you want tiled or full sheet. I don't want to post someone else's plans here, and it's not a foamie anyway There's no reinforcement needed on the wing at this weight. Just temper the foam with a heat gun to strengthen it.
jbc: Should be fine with that weight. Definately overpowered with an IPS-D, Heck, I'm down a prop size on the IPS! 9x4.7 instead of 10x4.7
Old Jan 04, 2005, 06:09 AM
CRASH GORDON is offline
Find More Posts by CRASH GORDON
CRASH GORDON's Avatar
sardis,bc
Joined Sep 2003
do you have to temper the wing???
CRASH GORDON is offline Find More Posts by CRASH GORDON
Old Jan 04, 2005, 06:42 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I'm afraid if you don't temper the wing it will be too flexible. You could leave the skin on instead, or add some tape, but it gets heavy, fast!
Old Jan 04, 2005, 06:47 AM
sardis,bc
Joined Sep 2003
thanks gene,im starting mine wed,[day off] i have no heat gun but ill try the wifes hair-drier.
Discussion Simple Indoor 3D Micro Plane project Electronick Scratchbuilt Indoor and Micro Models 3 Dec 27, 2007 12:58 PM
Discussion Does anyone have a simple stick plane plan SPITFACED Electric Warbirds 2 Aug 10, 2007 08:47 PM
Stick plane with plastic shell SpaKack Parkflyers 19 Oct 14, 2002 12:52 AM
Ace Simple Series Ultimate Bi-plane: anyone try one? Any powerplant suggestions? Falcore Electric Plane Talk 6 Jun 03, 2002 11:54 PM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 10:52 PM
