Old Jan 18, 2005, 07:36 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
That is somewhat confusing (the basic principle ) cause' logic would want to argue that they should move like elevons(twisting the tail for turn???), which we now know is wrong ....so much for thinking ....or not ....hahahahahaha Well put Gbond!!!!
I think I might have to build one for the ips motor...just for fun .....a little vertical in the gym couldn't hurt ....hahahahaha
gpw is offline Find More Posts by gpw
Old Jan 18, 2005, 10:34 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Yes, I got confused between V-tail and tailevons.... once Ouch!
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 18, 2005, 11:33 AM
robbie is offline
Find More Posts by robbie
robbie's Avatar
Barsoom
Joined Jan 2004
is this correct?
the motor is the 7.2v twin ips
so the gearing is s1 gearing 4:1 and i am using a 8x6 prop
on 7 cells it is drawing 3.9 amps and generating 219 grams of thrust (over 7oz)
so when i was trying to run it on a 150 mah nimh pack
3900/150=26
i was asking the battery pack to discharge at 26c?
a 700mah lipo pack weighs about the same
3900/700=5.6 (rounded up)
so 5 or 6 C is a more reasonable request.
so on the higher capacity lipo pack, the same motor will draw 3 amps instead of 4 (less wear and tear on the motor?) and still provide almost 1:1 thrust/weight ratio at 6oz. and the wings are still lightly loaded for slow flight at around 4oz.
-robbie
robbie is offline Find More Posts by robbie
Old Jan 18, 2005, 12:42 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Sounds like a winner, robbie
Yes, typical IPS runs at 2A/motor. The IPS-D should be around 4... The 150mah pack is marginal at 2A, dismal at 4A! Sounds like the right application for 6c 2s700's, or 10c 2s480-520's. They are about the same weight, and I consider them in the same class. Haven't measured run time at 4-5A, but I bet it's closer than the 500/700 rating would have you believe.
Old Jan 18, 2005, 09:14 PM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
Gym-blu
Neat Gene.... printing them out now... Have a indoor fly this weekend and will try to work one up. Have lots of 3D stuff to fly but since I don't get to fly hardly at all indoors, will probably tear up all my 3D stuff. This one should just keep flying on and on. Will use some depron.......but have some blue too. Will let you know how it does.... Thanks for the plans. STRINGFLY <>++++
STRINGFLY is offline Find More Posts by STRINGFLY
Old Jan 18, 2005, 10:55 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Sounds like a plan, String. Just remember, 'Light is Right'... Maybe you'll have a sub-4oz one?
Take some spare foam with you (or use some bits off the floor ) to play with the wing incidence. Try a couple different shims here and there, and let me know what you think. I started at 2 degrees, I revised it to 2.5 degrees (3/8"), and I'm currently flying at 3.5 degrees (1/2"). Next calm night, I'm going to try 5 degrees (3/4")...
Old Jan 19, 2005, 12:31 AM
colbyweb is offline
Find More Posts by colbyweb
Why aren't you out flyin?
colbyweb's Avatar
Overland Park, Kansas, United States
Joined Mar 2004
Gene, since you've been playing with the incidence, what do you recommend now? If it's 3.5 degrees I'd like to just build it in from the beginning. Oh I guess I forgot to mention, I'm building another one, the first wasn't worth fixing I'm not going to be -quite- so weight concious this time. I think if I can keep it at 5 oz or so it should be fine.
-Rick
colbyweb is offline Find More Posts by colbyweb
Old Jan 19, 2005, 06:52 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Rick: I'm liking the 3.5 degrees right now, witch is another 1/8" higher in the front than the current plans call for. Notice, though, it will cause some climb under power. However, I feel the slow speed stability is worth it. It's one of those balance issues that are going to be dependant on power and speed. I glued a shim in place in the front pylon to add the extra length.
Old Jan 19, 2005, 09:10 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Tried the more incidence thing , more draggy on the tiny LPS motor ... maybe 'a limit on the good thing ....especially with minimal power .... mine flies good anyway with only the original shim (TOF)...pretty slow now...Grandma'could fly it....well, you know!!!
Old Jan 19, 2005, 01:39 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
I'm using a cdrom motor with plenty of power so I think I will take Gene's advice. Should have it finished today, too bad I didn't work on it more yesterday since the weather is almost perfect today. Maybe I can finish it soon enough to go fly it before the day is over. Thanks
-Rick
Old Jan 19, 2005, 03:37 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Finally maidened mine. I've had a hard time keeping quiet--i take the 'never post until the maiden' approach.
Made a few changes, mostly to adapt to a CD rom motor and 3s lipo. I also used a wing & tail design that i've been messing with for another design. All in all it flies even better than i had hoped. This was my first VTail, so i didn't know what to expect. It's a great front yard touch & goer.
the rundown:
30" WS, 6oz AUW, 3s 520, 17T CD rom (more power than necessary, but why not?)
I'll take a pic tonight, but here's a jpeg of the plans. With Gene's approval, I'd be happy to post them in any format you guys want.
-scott
Thanks Gene!! Great design!
signflyer is offline Find More Posts by signflyer
Old Jan 19, 2005, 11:21 PM
STRINGFLY's Avatar
Joined Sep 2002
Gym-Blu
Working on my Gym-Blu...... mine is white depron... so..... Gym-whit...(dim-wit!!! he he.........) Added a inch to the span.... foam was 29 inches wide......... using a neat Avia Breeze wrapped carbon spar I had laying around from my low wind, no wind hi-tech kites for the fuse stick,,, very light but very strong. Hope to finish up before the indoor fly this weekend. I have raised the leading edge a bit, per Gene. Hope to get under 5 ounces. I have some 250 and 340 2 cells. STRINGFLY <>+++++
Old Jan 20, 2005, 12:18 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Gym-Ron???
Looking good! My Depron wing was 27.5", since that's the size I had It needs reinforced, or a lighter load, though That spar is probably the hot ticket. IIRC, the 3/16sq spruce stick I had was 3.3g... The 1/8" CF tube I have would be 2.5g... A light wrapped tube, rather than pultruded might be 1/2-2/3 of that weight.
SF: Go for it! Variations are welcome. I was just using the easy way out The tapers rob a little wing area, so you might want to cheat the chord some to make up the difference.
Old Jan 20, 2005, 07:26 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
I have a question for my motor GURU.... Gbond, would it be better to run an 8x4 on the ips (white gear )...just a little more thrust would do for me....
Another question ... when do we build the j250/D version ...Twice as big ??? Dome-Blu...???
Old Jan 20, 2005, 08:26 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
GPW: I think you said you are running LPS-B2C-C Look right?
I'd try an 8x4.3 prop on it myself. IIRC, that's the setup I loved on my PicoPiper and my Butterfly. They were both sub-5oz, as well, running the 2s250's.
I'll have to dig that one out to try on the 'light' version when I get going on it.
Let's see, Dome-Blu, huh? Yea, I've been thin'in on it maybe 25% bigger or so. May have to work on it
Maybe I'll try a Bit-Blu, too about 16-20", about 1 ounce
Hmmm... V-tail on a Bit control... Been thinking Bit-SimpleWing to figure out elevons, but....
Discussion Simple Indoor 3D Micro Plane project Electronick Scratchbuilt Indoor and Micro Models 3 Dec 27, 2007 01:58 PM
Discussion Does anyone have a simple stick plane plan SPITFACED Electric Warbirds 2 Aug 10, 2007 09:47 PM
Stick plane with plastic shell SpaKack Parkflyers 19 Oct 14, 2002 01:52 AM
Ace Simple Series Ultimate Bi-plane: anyone try one? Any powerplant suggestions? Falcore Electric Plane Talk 6 Jun 04, 2002 12:54 AM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 11:52 PM
