Old Dec 24, 2004, 05:22 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Gym-Blu Simple Indoor Lightweight Stick Plane
I needed a replacement for the PFC I trashed the other day, for our inddor flying and to fly in the street out front on calm evenings and mornings.. So, here you go!
28x8 wing, 5oz using std Pico Gear & IPS w/ 2s ET250 pack.
It's a floater!
Edit, 1-8-2005: Add 1/8" additional incidence on front of wing. Makes it more stable at even slower speeds Files are updated.
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 24, 2004, 05:59 PM
snowball1288 is offline
Find More Posts by snowball1288
1Point Landing Specialist
Joined Nov 2004
did you say 5 ounces? holy cow...
How does she fly?
is it really slow?
wind abilities?
does it fly in a gym?
snowball1288 is offline Find More Posts by snowball1288
Old Dec 24, 2004, 06:38 PM
Buzz_Man is online now
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
Phantastic! I want to build one - looks like the perfect "toss off the back deck" plane. I've been looking for a plane just like this one - something to fly in the backyard & also at night under the really tall parking lights at the local industrial park (they have several empty parking lots, very well lit - this plane looks perfect).
Thanks for posting & happy flyin',
Buzz
Buzz_Man is online now Find More Posts by Buzz_Man
Old Dec 24, 2004, 08:24 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
How does she fly?
is it really slow?
wind abilities?
Yup, 4.1oz w/o battery
Peel all the skin off the Fan Fold. Go easy on the glue. Heat treat / Temper tha foam for strength.
Slow Yea, a 2 mph wind and it'll harrier! Still can stand a little more wind, though, due to fairly low drag. Maybe 5mph would be ok.
A gym will be no problem!
Edit (2-15-2005): Just so it'd be on the first page, and since I can only attatch 5 files per post, I'll post the Dome-Blu Plans, here. It's a blown up version, 440 sqin, per GPW's suggestion for a little more power and weight with the same wing loading. You can find the discussion and development further down in the thread.
Old Dec 24, 2004, 09:01 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Gym-Blu looks great! I especially like the large tail surfaces, looks like you're one of the few who realise the value of plenty of tail area at very slow speeds. Keep UP The Good Work!
dayhead is offline Find More Posts by dayhead
Old Dec 25, 2004, 07:55 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
That's pretty COOL!!!! An indoor we can enjoy without resorting to "Swedish' Watchmaking "... NICE!!!! and just in time too ....Thanks G/bond .... again !!!
gpw is offline Find More Posts by gpw
Old Dec 26, 2004, 10:24 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
OK!!! I got the plans.... now , if I build it light enough , do you think it would fly with the LPS system ???? blue gear ... 7x6 prop ???
Old Dec 27, 2004, 07:56 AM
t1mux is offline
Find More Posts by t1mux
Mocking Birds
t1mux's Avatar
VA
Joined Apr 2004
Here is a thread on another plane that is along the same lines. It uses an LPS and Split FFF. The Simple Split Stick
t1mux is offline Find More Posts by t1mux
Old Dec 27, 2004, 08:20 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
What are you using for a dihedral brace , if any ???
Old Dec 27, 2004, 11:22 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Slow Yea, a 2 mph wind and it'll harrier! Still can stand a little more wind, though, duse to fairly low drag. Maybe 5mph would be ok.
Gene, what is the procedure you use to temper the foam?
Sleedo
Sleedo is offline Find More Posts by Sleedo
Old Dec 31, 2004, 12:10 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Sorry guys, just got back in the country tonight... vacation in the tropics w/o internet, but with sun, surf and cervesas!
Should be enough... I was using a 9x4.7 on an IPS-A, so down a prop size. The 8x4.3 may be better, though, with the same loading on the motor.
Hmmm... I didn't weight the airframe without the gear, but an ounce and half is a lot of weight savings. I just wonder about the wing strength.
Nada, I formed it, bent it and and tempered it. You could actually try to do a nice smooth curved dihedral, but it'd need more tip hight for the same effective angle. The 1.5" is about 6 degrees., so maybe go 1.75-2" tip height.
Basically, you heat treat the surface of the foam. Using a heat gun, you keep it moving across the surface, watching the surface as it just starts to melt, and becomes a little shiny... It seriously strengthens the foam, without making it excessively brittle.
Old Dec 31, 2004, 12:20 AM
sir crash alot is offline
Find More Posts by sir crash alot
sir crash alot
Newportville Pa. ( Philly burbs )
Joined Dec 2004
The wizzard is back welcome home Gene !!!!!!!!!!!!
sir crash alot is offline Find More Posts by sir crash alot
Old Dec 31, 2004, 07:15 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
You missed the SNOW (even here!),luckily we had BEER .....
The GYMBLU (sounds like a rap star) will be a nice platform to test thick vs. thin UC airfoils ... at low speeds ... something we need to know more about ....
Old Dec 31, 2004, 10:36 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Oh, we didn't miss the snow, or the cold, just the thaw... -8 degrees and 12-20" of snow... returned to 60 degrees and mud
I drew this up with the 4/40 wing chamber, and I like it. The PFC had about 10% underchamber IIRC. Maybe I'll make up a 10% wing to compare. Have to take a WAG at the flat chord, or get a drawing done first. I did make up a few 4/40 templates as part of the project, so maybe I should do some 10/40's as well. Should be able to just scale the X axis...
Old Dec 31, 2004, 11:51 AM
t1mux is offline
Mocking Birds
t1mux's Avatar
VA
Joined Apr 2004
Gene,
Can you post a link to the full page plans if you have them. Thanks
Discussion Simple Indoor 3D Micro Plane project Electronick Scratchbuilt Indoor and Micro Models 3 Dec 27, 2007 01:58 PM
Discussion Does anyone have a simple stick plane plan SPITFACED Electric Warbirds 2 Aug 10, 2007 09:47 PM
Stick plane with plastic shell SpaKack Parkflyers 19 Oct 14, 2002 01:52 AM
Ace Simple Series Ultimate Bi-plane: anyone try one? Any powerplant suggestions? Falcore Electric Plane Talk 6 Jun 04, 2002 12:54 AM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 11:52 PM
