Old Dec 22, 2004, 11:16 PM
thailandboy2 is offline
Find More Posts by thailandboy2
LEO THE LION TO THE KING
SOUTH CAROLINA U.S.A.
Micro Hydroplane Build Attemp
Hi everyone, i'm usually on the airplane side of this site, but since i'm waiting on some aircraft parts to arrive, i thought i'd try my hand at a quick boat.for those of you who have read my other treads i've started, you know i love SMALL..lol..i love the budwiser boat you see in the hobby store, but at almost $300, thats way out of my budget..after some searching i found some plans for a simi- scaled hydroplane i got from the internet. i took the plans and reduced it to a smaller size of about 7'' in lenght, as to the 12'' it called for...i will try to post as much build pic.s as i can. the framing will consist of plastic sheets. this is easy to cut out with scissors. so here it goes...any help from any of you would be greatly appreciated..tom
thailandboy2 is offline Find More Posts by thailandboy2
Old Dec 22, 2004, 11:49 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
That Hydromite must be the basis of a lot of boats. Some people may even have built it as drawn
martin richards is offline Find More Posts by martin richards
Old Dec 23, 2004, 12:53 AM
here's another pic. of the hull assembled..martin yes it is..i'm doing it smaller though..it's a good plan and very simple to construct
Old Dec 23, 2004, 12:56 AM
now for the start of engine work and skinning..tom
Old Dec 23, 2004, 06:27 AM
airibatic is offline
Find More Posts by airibatic
Fly like you stole it .
United States, VA, Lorton
Joined Sep 2004
Hydro Mite
yes I have built one per the plans amd it is a blast to drive. It has just a speed 400
airibatic is offline Find More Posts by airibatic
Old Dec 23, 2004, 10:17 PM
airbatic, what did you use for electronic to steer and speed control? i'm still debating on what motor to use, i'd like to try using the micro-sizer car parts with a larger motor of 30,000 rpms but not sure how the range would work on this set up..any ideas? my boat is only 7'' long and about 3'' wide, not much room for space..
Old Dec 23, 2004, 10:23 PM
o.k. alittle more progress on the body. as you can see in the pic.s i have added the outter side skins and bottom. also i carved a quick foam cockpit for the little budwieser.. it still need alittle more sanding and some touch ups. next i'll add the rudder and spoiler..
Old Dec 23, 2004, 11:27 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
For the prop tube and rudder, unless you can adapt parts from an existing toy boat, you will have to make your own. I think the rudder details are shown on the plan. A 280 size motor is probably a better choice than a 12 V car motor, as getting 10 cells to fit would be difficult. Another option would be to use a servo motor with the electronics serving as a speed controller. A micro receiver and servo may just fit and would be a safer choice than the micro-car type for range.
Old Jan 10, 2005, 05:49 PM
Joules is offline
Find More Posts by Joules
United Kingdom, England, Sheffield
Joined Dec 2003
For prop shaft have a think about using brass tube and stainless steel bowden cable (bicycle brake cable)... This will allow the prop shaft to be bent in line. It's easier if you have a lathe to make the parts, but can be fashioned using a mini drill.
Joules
Joules is offline Find More Posts by Joules
Old Jan 11, 2005, 12:48 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
Here's a very bad image of something like Joules mentioned. The threaded part is a brass M4 screw with the head cut off and about half the threaded length filed down to fit into a 4 mm od brass tube. The cable is 2 mm stainless steel, fitted into the same tube with the help of scrap pieces of brass tube. The outer tube is notched for better lubrication and the set up has been used successfully with a speed 400 motor, with no signs of the epoxy adhesive failing. Using the 2 mm flex allows standard Graupner motor couplings to be used.
Old Jan 24, 2005, 06:26 AM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Where did you get the plans?
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Feb 10, 2005, 11:59 AM
forresterace is offline
Find More Posts by forresterace
Maker of Sawdust
forresterace's Avatar
Richmond Hill, Ontario
Joined Mar 2001
Hydromite plans
Rocketman
The Hydromite plans are available on two different websites-
http://www.rumrunnerracing.com/plans/hydromite.htm
http://www.microhydros.com/doug_forrester/doug.htm
The original hull size as designed is 16.5" long.
Martin-
You are right, I have heard of just about every imaginable size variation of the Hydromite being built - from 7" up to a 44" gas-powered giant.
Thailandboy2-
The biggest part of the problem in building a down-sized version is not finding a suitable motor, batteries or even driveline hardware. The toughest part is to find a suitably sized prop that will work efficiently as a surface prop. Once you go below 25mm diam. (even if you could find one), the efficiency as a surface drive would be dismal. You could always try to solder one up out of brass.
Good luck.
Doug Forrester
Forresterace Designs
forresterace is offline Find More Posts by forresterace
Old Feb 13, 2005, 01:21 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
You could try the Graupner 26 mm carbon props, which are threaded for 2 mm drive shafts, They can probably be worked down to 24 mm. Beyond that the only alternative that comes to mind are the many reduction gearings available for 280 size motors.
Old Feb 15, 2005, 03:52 PM
beanoman is offline
Find More Posts by beanoman
beanoman's Avatar
Akron/Canton, Ohio, United States
Joined Aug 2004
Forresterace is absolutly right. the hardest part is getting the right prop. the only place i have found for decent, cheap props is from toys. for 10 to 20 dollars, you can pick up a toy r/c boat with two small props at walmart or toys r us. obviously they will also come with small motors, batteries, simple charger, and a reciever, although they will not be propo.
i am building a small boat also. it is five inches long, and a landing craft, so its quite boxy. it uses a 7mm motor, and is slightly overpowered.
for the seven inch hydromite, a 280 is a bit big, i think. if you are going to use a propo system, get a hs-81 servo, and use the motor and board from that. look here: http://www.geocities.com/patsmodels/lcm3/ you can see that two of those are powering a box, erm, landing craft more than twice as big as your racing boat. i would say a hs-55 for your rudder. i dont really know what you would want for your rx and batteries.
beanoman is offline Find More Posts by beanoman
Old Feb 19, 2005, 07:45 PM
discoboy is offline
Find More Posts by discoboy
Joined Sep 2004
Following this thread I'm now building an 11" Hydromite, I've already built an 18" one for EDF but never got the motor setup right... I've got most parts sorted out for this micro but I don't know what to do about the prop. My gear is:
Motor: Speed 280
Battery: 7xAAA Mi-Mh (800mAh, 5A)
I had the perfect prop from a Keil Craft Whisper kit but it threw a blade when I was trying things out for this boat. What I don't know is whether I should take something like a 29mm Graupner prop and trim it down, hunt for the right toy boat and knick it's prop or try to build my own.
How hard is it to make a prop that works well enough for a surface drive? What would be best to cast a prop with? Would bending a sheet of brass and sandwiching it between two bolts be sufficient???
discoboy is offline Find More Posts by discoboy
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
Micro glider build-off!! 2 day!! watersharer Scratchbuilt Indoor and Micro Models 31 Apr 03, 2005 09:56 PM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 11:05 AM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 10:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 02:17 PM
