Old Dec 22, 2004, 06:57 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Stevens Aero Stella: Building Thread (part 3)
This is part three of the Stevens Aero Stella thread.
Part one can be found here - http://www.rcgroups.com/forums/showthread.php?t=269783
Part two can be found here - http://www.rcgroups.com/forums/showthread.php?t=290586
Enjoy!
SchiessCo is offline Find More Posts by SchiessCo
Old Dec 22, 2004, 08:57 PM
smsgill is offline
Find More Posts by smsgill
Scott Summersgill
smsgill's Avatar
Thousand Oaks, CA
Joined Feb 2001
I'm not too familiar with the many versions of the Himax motor, so I have a question for those "more in the know." What's the ultimate Himax setup for the Stella? Motor, battery, gear ratio, and prop. I've read through this thread, but there are so many combos it's difficult to tell which is best.
Thanks much,
Scott
smsgill is offline Find More Posts by smsgill
Old Dec 22, 2004, 09:08 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
I use a:
Himax 2025-5300
Geared 6:1
10x47 prop
Tanic 1550
The power is truly INSANE. Only down side is it draws 18 amps, at full throttle... Just check out my videos to see the power...
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Dec 22, 2004, 10:24 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Mine's planned for an RZ2500/5.2:1/3s Apogee 1570s/APC 11x4.7, Scotty.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 23, 2004, 08:25 AM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
I'm going RZ-2500/6.?:1/12X6 SF prop. With this set up I am not pushing the motor at all, 13A WOT but it allows me to use my E-Tech 1200HP's which give me 15+ mins in my 15oz+ Funplanes Yak, I am guessing this the above set-up I should be pretty light with those packs and it gives pretty impressive pull outs from hover. I was hoping to maiden her on Christmas day but I am not sure if I am going to make it and the local weather is calling for wind.
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Dec 23, 2004, 09:48 AM
LJH is offline
LJH
LJH
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Shhhh...don't tell the boss but we are dead today, go figure a mail order joint is slow two days before Christmas . I am finishing up some details on the Stella and I am wondering looking at the motor stick does the arrow side go into the fuse or is it the other way around?
Cheers,
Jim
Old Dec 23, 2004, 09:53 AM
bobsean is offline
Find More Posts by bobsean
www.rcfoam.com
bobsean's Avatar
Lilburn, Georgia, United States
Joined Jun 2004
It seems to me that everyone is hooked on geared motor setups, which is not a bad thing. But, has anyone had similar results with AXI outrunners? I'm guessing that a 2212/26 or /34 might beable to power this but I just want to hear about other peoples experiences. Thanks,
-Sean-
bobsean is offline Find More Posts by bobsean
Old Dec 23, 2004, 11:26 AM
smsgill is offline
Scott Summersgill
smsgill's Avatar
Thousand Oaks, CA
Joined Feb 2001
Thanks gents. I'm researching for a newbie e-plane flier friend of mine. I'll pass the info along.
Off topic. Mark, hows it going? I'm hoping to make it down to MWE this year. It's all going to depend on when boy #2 arrives. My lovely wife has given me a pass so long as my mom is in town to help. Hope to see you there.
Later,
Scotty
Old Dec 23, 2004, 12:22 PM
SchiessCo's Avatar
North Hills
Joined Nov 1999
Jim -
You might also want to consider an APC 11x7 SF prop. I ran the same motor / gear ratio as you, and really preferred the additional pitch speed.
Pete
Old Dec 23, 2004, 12:38 PM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
-Sean-
Sean,
Included with the Stella is a mount for the 2212 series motor. I have flown Bill's with the 2212-26, and mine with the 2212-34. They work fine. They don't, however have quite the punch as the geared 200 watt systems. The 2212 come out more in the 150 watt range.
Honestly, 150 watts flies this model beautifully. 200 watts flies it better though
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Dec 23, 2004, 12:43 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Cheers,
Jim
Jim,
I don't think it matters. I always thought the arrows were for alignment of the seperate parts of the stick rather than the direction it goes in the model. I think the stick is actually symmetrical, and as such could go either way. What I would recommend, if you're using a high watt system (can't remember) is to drill out the end and glue a carbon rod or dowel into the stick. I had one break on a 230 watt system swinging a mondo prop. Not pretty. The whole stick thing was originally designed to accept the 100 watt GWS EPS, and never really stressed for the kind of power that is being stapped to them. The dowel does the trick...
Scott
Old Dec 23, 2004, 01:09 PM
LJH is offline
LJH
LJH
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Scott,
Thanks, I have been looking at it and there is more "tabbing" on one end compaird to the other so I would think that the more surface area in the tab would be benificial sticking out the front of the firewall. After reading some of the posts about the stick breaking in hi-watt applications I beefed mine up. Some where in the kit there are strips cut that are the same width as the dimention of the inside of the "stick. I stacked three together which gave me another stick that fit perfectly inside the motor "stick". I then tacked the "stick" together and literally soaked it in CA for 10 mins or so. It was pretty amazing how when I took the thing out how warm it got, I guess with that much CA kicking it puts out some energy , It was actually still a bit warm after an hour of me taking it out of the CA. I wish I know where the strips came from that fit perfectly inside the "stick", they are somewhere in the kit . I figured if I was not happy at @150W I could always push the RZ-2500 a bit harder, I do have a couple TP2100 GII packs so I just might have to check it out at the 200 watts, though it makes me nervious because I am sure I will like it with 200+ watts per pound . Merry Christmas all.
Cheers,
Jim
Old Dec 23, 2004, 05:58 PM
doc-e is online now
Find More Posts by doc-e
Live to fly!
doc-e's Avatar
United States, NJ, Fair Lawn
Joined Nov 2002
Here are the vids that my brother took yesterday of Stella and the Groove. I managed to extract about 4min of footage from the 12-13min Stella recording. It's the best I can do with what was recorded (mostly blue sky... ). The Groove vid came out a little better.
http://www.iona.edu/faculty/livanov/...Knife_Edge.wmv
http://www.iona.edu/faculty/livanov/videos/Stella_4.wmv
Enjoy!
Doc
doc-e is online now Find More Posts by doc-e
Old Dec 23, 2004, 07:43 PM
daking is offline
Find More Posts by daking
PRO BRO #157
daking's Avatar
Sterling hts, Michigan
Joined Jun 2003
Nice video's Doc. Dont you love the knife edge on the groove??
I need to get my stella back out for some fun !!
daking is offline Find More Posts by daking
Old Dec 24, 2004, 05:52 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Originally Posted by sukhoi26mx
Sean,
Scott
So you recommend a long can geared motor? Like a Hacker L, Himax 2025, etc? Which gearing and prop?
I guess the 2808 Axi is a little much as on 3s it runs in the 250 watt range?
Pinecone is offline Find More Posts by Pinecone
Build Log Stevens Aero Stella: Building Thread (part 5) Ted U 3D Flying 245 Dec 22, 2014 09:51 AM
Stevens Aero Stella: Building Thread (part 4) SchiessCo 3D Flying 605 Aug 18, 2005 06:10 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Stevens Aero Stella: Building Thread doc-e 3D Flying 633 Oct 24, 2004 05:52 PM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 11:17 AM
