Old Dec 21, 2004, 10:21 PM
Joined Dec 2004
Help with servo choice for Herr lil extra
I've just (back) ordered a herr Lil extra and I'm hoping for some recommendations on recievers and servo's. This is my first venture into smaller sized airplanes. I'd love to save as much weight as possible, but not sure how much servo torque a plane of this type will require. Please help! thanks.
Zach
zhadley is offline Find More Posts by zhadley
Old Dec 21, 2004, 10:47 PM
booze is my co-pilot
ALEX DOUGHTY's Avatar
Joined Dec 2004
i'd reccommend just normal micro servos (i use tower and thats for my .15 herr pitts, although i have used them on smaller models). as for the receiver, i use a tower 7-channel but i would reccommend using a smaller one cause it is hard to find a place for it in small planes. that lil extra is a beauty might look into one myself.
Alex
ALEX DOUGHTY is offline Find More Posts by ALEX DOUGHTY
Old Dec 22, 2004, 12:57 AM
Joined Dec 2004
I guess I'm wondering how small is too small? I'd like to go as small as possible while retaining the necessary torque
Old Dec 22, 2004, 01:08 AM
Joined Dec 2004
me personally i wouldnt go any smaller than the micro, that is what i run in my planes. i would rather have a little extra weight and know my servos can take it rather then worry about them not having enough torque. im sure hitec or futaba make some nice ones.... you can check the tourque on one micro and compare it to the size below... my micro had no problem powering two full length ailerons so if the tourque difference isnt too much then the size below should do just fine......what engine are you using?
Alex
Old Dec 22, 2004, 08:20 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Hitec HS-55's will be fine. They will have plenty of grunt for this airplane. Let me know when you get it. Seems to be impossible to get!
Old Dec 22, 2004, 12:30 PM
Joined Dec 2004
ok, well I was considering the futaba s3108m with the 4 channel micro receiver and plugs. Is there any reason this would be a problem? the servos have slightly more torque than the hs55 and are fairly cheap at tower. However I'm not familiar with this reciever and its limitations. As far as the plane goes, I ordered it from tower and they thought they'd have it mid feb. I called the company (herr) and they said the same, so hopefully it'll come on time! I just want to have all the peices waiting for it. Oh and I'm planning on running the norvel .074 in it.
Old Dec 22, 2004, 12:53 PM
Flying is a Gamble...
N925WB's Avatar
Front Royal, VA
Joined Jul 2003
I normally run standard micros in my little planes. Futaba has the S-3101 with 35 oz/in of torque, and Hitec offers the HS-81's with 36.1 oz/in's of torque. Both are about the same size, weight, and cost, and will surely give adequate performance. I've also used FMA servos in the past, but they are no longer in production.
For recievers, check out Hitec's Electron 6. It's a little more than you'll need for the Little Extra, but might come in handy in the future. I'm currently using one in a Morris Hobbies Yellow Jacket, and it's been problem free. You definitely want a dual-conversion reciever, though. No GWS Pico or Hitec Feather recievers for this plane!
The important thing to remember, as someone already said, is that there is little penalty in getting a slighty heavier/stronger servo. The real problem is when the servo isn't strong enough, and you're out a hundred dollar airplane.
Finally, don't take my advice like it's the last word. I'm no expert, and can only speak from limited experience in small models. Get some more opinions, and average them out.
Good luck!
-Wayne
N925WB is offline Find More Posts by N925WB
Old Dec 22, 2004, 01:23 PM
Dukester's Avatar
USA, TX, Houston
Joined Sep 2003
I had a similar decision and decided to go with GWS Naro +F BB servos. 24 oz torque at 10 grams (0.35 oz). Nearly as light as a HS-55, but more torque. They run about $15 each it looks like.
Duke
Dukester is offline Find More Posts by Dukester
Old Dec 23, 2004, 12:36 PM
Joined Dec 2004
Thanks for the advice guys, I've been looking at the hitec Electron six and the hitec hs 81's. How about battery options? Any recommendations?
Zach
Old Jan 11, 2005, 09:16 PM
Broomfield, CO 80023
Joined Dec 2002
I wish Norvel made a 0.74 It's a 0.074
I second the Hitec HS81s and Electron 6 Rx. I just picked up four more HS81s today for my modified Honker Racer - plans built and bashed a bit I'm in teh midst of. It also uses a Norvel .074, presently out of my House of Balsa Spacewalker which is also equipped with HS81s, but with a Hitec 555 Rx. squished inside. I'm flying an Electrom 6 in a .40 size Decathalon at present though . HS81s also in my Skimmer 400, Texaco sailplane, and just mounted in my new larger Skimmer.
For bateries, I recommend a 350 mah NimH pack, square or flat depending on your needs. They are available from www.radicalrc.com for about $13 ea., plus $2.00 (I think) shipping.
John C
John_R_C is offline Find More Posts by John_R_C
Old Apr 06, 2005, 04:43 PM
Joined Feb 2005
Hi Guys,
Just a heads up to let you know The Herr Lil Extras arrived today and are shipping tomorrow. Should be a great plane.
mikel@sig is offline Find More Posts by mikel@sig
Old Apr 06, 2005, 04:45 PM
pda4you's Avatar
Joined May 2002
Originally Posted by mikel@sig
Hi Guys,
Mike that is awesome - we have waited a long time for this little plane.
I have one backordered with Tower right now............how quick will they get them?
Old Apr 07, 2005, 08:51 AM
Joined Feb 2005
They shipped yesterday so Tower should have them by the end of the week!!
Can't wait to hear some flight reports from you guys.
Old Apr 07, 2005, 09:17 AM
pda4you's Avatar
Joined May 2002
Mike - Will do....
Mine will be eletricuted! But I will post the build and full results here.......
My .40 size SE was one of my all time favorte Glow models. Great fun!
Mike (very excited!)
Need help with motor choice for my Herr AT-6 Texan nakman8 Glow to Electric Conversions 7 Dec 18, 2005 11:07 AM
Need help with motor choice for my Herr AT-6 Texan nakman8 Beginner Training Area (Aircraft-Electric) 3 Dec 06, 2005 07:26 PM
Need help with motor choice for GIANT Slow Stick Turbo442 Power Systems 0 Apr 30, 2004 12:58 PM
Help with ESC choice for GWS planes GreatGazoo Parkflyers 2 Sep 14, 2003 03:08 PM
Help with battery choice for MINI IFO Kyle Indoor and Micro Models 8 Jun 28, 2002 10:01 AM
