Old Dec 21, 2004, 06:11 PM
acannell@wwc.com
acannell@wwc.com
Guest
n/a Posts
R/C Airplane with the most payload capacity
I'm planning on getting an R/C airplane to experiment with sensors and
video cameras, etc.. I'm wondering if anyone can recommend a .60 size
airplane with great payload handling capabilities, and what a realistic
upper limit on payload capacity might be (1lb? 5lbs? 10lbs?). I don't
want to go larger than .60 scale. Also, is there a way to estimate
payload handling capability based on wing surface area, and wing
loading specs? What is the wing loading spec anyway? Is it just the
weight of the airplane over the wing surface area? And is there some
upper limit on wing loading where there is no longer lift or something?
Asa
Old Dec 21, 2004, 08:11 PM
aeropal
aeropal
Guest
n/a Posts
Re: R/C Airplane with the most payload capacity
Aerial photography forums:
http://www.rcgroups.com/forums/forum...s=&forumid=128
http://www.rcuniverse.com/forum/Aeri...umid_81/tt.htm
It would be helpful to know the payload physical size, weight, and
estimated flight elevation above sea level.
Old Dec 21, 2004, 10:11 PM
acannell@wwc.com
acannell@wwc.com
Guest
n/a Posts
Thanks for the links. I don't have a certain payload in mind, I am
trying to get an idea of what is feasible with a .60 size. I don't
think I would ever go above 1500 feet above sea level.
Asa
Keith Schiffner
Keith Schiffner
Guest
n/a Posts
<acannell@wwc.com> wrote in message
news:1103685769.063829.159180@f14g2000cwb.googlegr oups.com...
> mind, I am
> I don't
One of the Telemaster series of planes ought to work
then...hope you LOVE lots of wood.
Nefarious Necrologist 42nd Degree
Some people ride, some just like to show off their butt
jewelry once in a while.
Dum vivimus, vivamus
<3 )3~~ <3 )3~ <3 )3~
<3 )~ <3 )~
Old Dec 22, 2004, 12:11 AM
aeropal
aeropal
Guest
n/a Posts
Some candidates:
Senior Telemaster Kit
http://www.hobby-lobby.com/srtele.htm
World Models Super Frontier Senior ARF (mostly constructed)
http://ecsvr.com/abm/shopexd.asp?id=53
Sig Kadet Senior ARF
http://www2.towerhobbies.com/cgi-bin...&I=LXBDE9&P=ML
If this happens to be your first RC airplane, finding an experienced RC
model pilot would be advisable. Flying Model Simulator will give you a
feel for what RC model flying is like.
http://beginnerparkflyers.nexuswebs.net/index1.html
acannell@wwc.com
acannell@wwc.com
Guest
n/a Posts
Thanks for the suggestions aeropal. I had been considering a Hangar 9
Alpha .60 Trainer RTF. Whadda ya think? The RTF kit is $389 with engine
and radio, and I can go buy it local. I had looked at the telemaster
and it does seem more payload capable (its huge), but is it overkill? I
have no idea how much payload any of these aircraft are realistically
capable of, might you have any idea?
Asa
aeropal wrote:
> Some candidates:
RC
a
Fubar of The HillPeople
Guest
n/a Posts
A Sig Kadet Senior ARF will carry a pretty decent payload. I have one that
has carried as one payload:
A micro wireless transmitter, micro camera (standard servo mounted in the
wing), 10 cell 12vAA nicad pack, 2"X3"X5" black box telemetry unit, 5 cell
6v AA nicad pack, several switches and all the wiring to hook the whole mess
together. Standard servos, rx, power pack, plane is in the stock
configuration. No mods other than hard points added for mounting the various
bits.
Powered with a Super Tigre .51 ringed engine.
http://fubar1.net/movies/wireless/blackboxtest2.wmv
http://fubar1.net/movies/wireless/Kadet%20900.wmv
The top link is airborne video from the plane while carrying all the stuff.
Altitude telemetry readout stops at 1000 feet while the plane is still
climbing.
Second link is airborne video (much higher altitude) but without telemetry
unit and 6v power pack for it.
I bet the plane would carry a small handycam without much trouble but I
would keep the aerobatics down to a minimum.
Dan
AMA605992
KE6ERB
http://www.fubar1.net
"I've heard the screams of the vegetables..."
Take out the "trash" to reply
"aeropal" <rcaeropal@hotmail.com> wrote in message
news:1103688810.463172.29190@f14g2000cwb.googlegro ups.com...
> Some candidates:
aeropal
aeropal
Guest
n/a Posts
As you referenced in your first post, the ounces per square foot "wing
loading" is a factor. At 7-8# and 911 Sq In wing area, the Alpha 60
calculates at 18-20 oz/sf. If the payload was around an additional 2
pounds, that would still only be around 25 oz/sf . . which is not
excessive for the estimated 1500' elevation. The higher wing loading
would require a slightly faster airspeed, however.
The $389 Hangar 9 Alpha .60 Trainer RTF is a good value for the money.
One thought is that the 4-channel JR Quattro radio may not have enough
channels to meet your needs (if remote payload equipment activation is
necessary). One trick is to couple the ailerons and rudder together on
the right stick through a Y-harness. This would open up 1 free channel
that would be operated by the former left stick rudder channel. But a
5 or 6 channel radio may be more suitable.
http://www.horizonhobby.com/Shop/ByC...ProdID=HAN2600
acannell@wwc.com
acannell@wwc.com
Guest
n/a Posts
Thanks for the info aeropal. I'm interested in how you are using the
wing loading to determine whats realistic given the atlitude. Would you
be so kind as to explain what the relationship between oz/sf and
maximum payload is? I.e., why is 25 oz/sf okay at 1500'? What is the
most that is okay and how do you calculate that okay level for various
altitudes?
Asa
"wing
money.
enough
is
on
channel
a
Hugh Prescott
Hugh Prescott
Guest
n/a Posts
Orig telmaster with ST 71 / perry pump and carb
Fuel two 1 gallon plastic jugs strapped to the fues sides and to wing. and a
24 oz internal fuel tank. Cross country at 45 MPH. Takeoff was long but
stable. Flew nice once in the air.
total weight about 24 pounds.
Hugh
news:1103689695.982910.316090@c13g2000cwb.googlegr oups.com...
> Asa
> aeropal wrote:
> > Some candidates:
> RC
> a
acannell@wwc.com
acannell@wwc.com
Guest
n/a Posts
Wow what were you doing a UAV project of some sort? Why did you have so
much fuel? That engine is a gasoline one right?
aeropal
aeropal
Guest
n/a Posts
The wing loading statements are entirely personal opinion . . just
something you have to experience for yourself.
Old Dec 22, 2004, 01:50 AM
Li-Pu Batteries is offline
Find More Posts by Li-Pu Batteries
For that extra kick!
California
Joined Dec 2004
Uh, homeland security? Hello? Yes, I was on this site called rcgroups, and...
Maybe you could describe your application and intended payload a bit more before we go much further?
Li-Pu Batteries is offline Find More Posts by Li-Pu Batteries
Old Dec 22, 2004, 06:11 AM
The Natural Philosopher
Guest
n/a Posts
You should be able to lift about 15lb total weight, on a 60 at least.
Maybe as much as 20Lb on a big wing area, slow, old fashioned sort of plane.
Senior telemaster is a plane I have heard of in the load carrying context.
> Asa
Steve Banks
Steve Banks
Guest
n/a Posts
Another approach may yield larger lifting capacities, but it would require
considerably more time/skill to make work. Here's my thoughts on it:
get/make the largest flying wing you can:
here is one possible candidate from:
http://www.flyingfoam.com/products.html
Mother Ship
83" Span EPP/EPS Large Combat Flying Wing
Area: 1440 sq.in. / 4 lb.
EPS/EPP Full Kit: $90.00 / Econo Kit: $84.00
All EPP Full Kit: $130.00 / Econo Kit: $124.00
and mount a reverse rotation "pusher" engine to it. This will add a pound
or so. You might want to consider an electric so you arent vibrating as
much when taking pics, but this may degrade your lifting ability
considerably. If this is for very short flights then you can use a lighter
battery however and regain some capacity.
Install the camera pointing up. You'll have to fly inverted to take pics
but it will be protected on landings.
Launch it with a bungee catapult or somesuch.
Whatever the design, experiment (test fly) with non-expensive weight (a
camera sized cardboard box filled with rocks?) in small increments till you
get to the desired weight and are confident that you can fly with the weight
of the camera equipment.
It should have a lot more lifting capacity than a traditional plane design
because it doesn't have to carry landing gear or even a fuselage, which
means considerably less weight and drag. The flying wing design also only
needs 3 channels so the fourth channel, if you have one, can control the
camera.
Good luck, report back.
Discussion What's Your Most Favorite R/C Airplane? BD Flyer Electric Plane Talk 38 May 17, 2007 10:24 AM
Discussion A Promblem With My B-29 Bomber R/C Airplane dzaken2800 Parkflyers 7 Mar 30, 2007 05:58 PM
Begginner R/C Airplane putt_13 Parkflyers 17 Aug 06, 2002 11:06 AM
Newbie - Kyosho Cessna R/C Airplane ooananoo Beginner Training Area (Aircraft-Electric) 12 Jun 02, 2001 11:40 AM
