Old Dec 21, 2004, 11:53 AM
IAD is offline
IAD
Find More Posts by IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Burt Rutan's Pond Racer, Shockflyer Style
Thought I would share my latest Bluefoam experiment...
A 36" span Shockflyer-style Pond Racer, to be powered by two IPS-A units and a 2-cell 700 mAh E-tec pack. Controls will (naturally enough) be throttle, aileron and elevator.
I managed to get 138"^2 of wing, without stretching anything. With an AUW of hopefully under 8 oz., it should have a decent wing-loading, and remain a fairly tame small-area flyer.
~Luke
P.S. Ignore the chess pieces. CG finding procedure. You know, tape weight, glide, move weight, repeat.
IAD is offline Find More Posts by IAD
Old Dec 21, 2004, 12:08 PM
stjobs is offline
Find More Posts by stjobs
Gainesville, Florida, United States
Joined Sep 2001
Looks pretty cool, but that wing seems on the small side... Question - where will the battery go to get the right CG? The center area doesn't have any foam far enough forward...
stjobs is offline Find More Posts by stjobs
Old Dec 21, 2004, 12:55 PM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Nah, there's plenty of wing... (Famous last words. ) Seriously, though... This isn't a 3D ship, and 7-8 oz/ft^2 isn't too bad at all. For some reason, the Pond Racer has a bad rep. in re: wing area. It actually has quite a bit, for a given span.
The center pod actually reaches all the way to the LE of the wing. I was planning on putting the battery about there. Still behind the CG, but with a couple 1 oz. motors all the way forwards, the elevator servo up next to one of the motors, and maybe a couple ESCs, for differential thrust, it should balance. And if it doesn't, dead weight to the rescue!
~Luke
Old Dec 21, 2004, 03:07 PM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Just an update: The wing area is fine, I just flew it around on the last of a battery charge, and it was quite flyable, did some nice pylon turns, but unfortunately, the battery was probably down around 6.75 volts or so. Needless to say, it was underpowered in that state. Need to charge that LiPoly!
Bottom line: It flies, and does so like a park/indoor flyer.
~Luke
<<Edit: Just ran it with a 8-cell 650 KAN pack, AUW 9.33 oz. Still no problems with the wing loading.>>
Old Dec 21, 2004, 03:22 PM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
~Luke
I NEED ONE!!!!!!! if at all possible could I get plans??? Pm me if this would be ok. Thanks Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Dec 21, 2004, 03:48 PM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Well, the funny part here is... There are no plans. I found a 3-view somewhere (I don't even remember where) and scaled them up this morning to have a 36" span.
I may draw up plans yet, but...
I'm recharging the batteries right now, so I'll probably get in one night-flight, during which I can finish assessing performance.
~Luke
Old Dec 21, 2004, 08:05 PM
Bsouthwell is offline
Find More Posts by Bsouthwell
Bsouthwell's Avatar
USA, MS, Iuka
Joined Jan 2002
Really Cool Luke!!
Bill
Bsouthwell is offline Find More Posts by Bsouthwell
Old Dec 21, 2004, 08:46 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
Plans for me too Luke! I agree there is eough wing area, after all this is a "racer" so a high take off speed would be understandable. less wing=less drag = more speed.
To turn this into a more well behaved parkflyer all one would have to do is make the wing just a tad bigger all around. Maybe 2" span increase and 1/2" to an inch in the chord. It might look a bit less scale but make some a little happier with its wing loading.
Me? I like it just as it is and because of the "Shock-flyer" treatment the horizontal fuse and boom pieces actually add a little "wing area as it is.
Robert
willin is offline Find More Posts by willin
Old Dec 21, 2004, 09:53 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Once the Pond racer gets thrashed we wanna see ya make a Rutan Boomerang...
dayhead is offline Find More Posts by dayhead
Old Dec 21, 2004, 10:17 PM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
I don't see any reason to add any wing. The thing already turns on a dime without tipstalling. I can't imagine it being any better behaved.
I flew it in the backyard, which is a place rank with trees, bushes, etc. Granted, the battery was dead, so I didn't really get much testing in, but... There is definitely no reason to 'un-scale' the wing. (By the way, the wing loading is about 7.5 oz/ft^2 with the LiPoly...) The only thing I have to complain about is that the design feels very draggy, which, due to uncontoured LEs on the wing/tail, etc., it is. I'll see if I can't improve this, with a bit of sanding.
~Luke
Old Dec 22, 2004, 07:26 AM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Well, the good news, and the bad news:
Good news: Freshly charged LiPoly flight confirmed initial reports, it does fly, and flies quite nicely. Needs a regearing, though. Probably a pair of S2 drives would be better than the A drives. (Required near-full throttle to fly well.) Either that, or a higher-voltage pack. I'm leaning towards the first option.
Bad news: Have you ever seen an aileron-only plane do a knife-edge harrier? If I turn too tight, I go into a [very nice, coincidently] hovering knife-edge! (And since I don't have a rudder, I get stuck in it, too!) I'll adjust the CG.
~Luke
Old Dec 22, 2004, 11:14 AM
stjobs is offline
Joined Sep 2001
What props are you using with the IPS A drives? Did you go with differential thrust? What about the elevator? Cool looking design. It's hard to tell the scale from the photos, so I guess the wing area is OK. I tend to like my designs with plenty of area for that "floaty" feel
Old Dec 22, 2004, 11:23 AM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
No differential thrust, I realized my twin ESCs were still embedded in another project. The elevator is joined by a bit of ply, which coincidently came apart, and needs fixing... I've got the 9"/7" on the IPS... Pretty good setup, but definitely needs either (a) more thrust, or (b) more prop-speed. It only flies well as long as the battery gives about 8 volts, which if you look at the discharge curves of a LiPoly, isn't very long at all. (Thus my plan to remotor/regear it.)
I wouldn't say it's floaty, but it definitely doesn't fall like a rock. Just sort of putters around. I would say it is similar to a Hobby-Lobby Rare Bear... (Not that I have ever flown one of those... But it looks about the same, maybe a bit slower, and definitely draggier.)
~Luke
Old Dec 22, 2004, 12:13 PM
willin is offline
willin's Avatar
Joined Mar 2003
Luke, I was wondering how you have your ailerons linked. Kinda looks like a pull pull set up. could we get some closer pics and a little more info?
Robert
Old Dec 22, 2004, 01:27 PM
IAD is offline
IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
I'll try and get some pictures... Here's the basic idea, though...
It is pull-pull, but with a twist. (One that personally, I don't like much, but I was desperate.)
The idea is... Starting at left aileron, working right...
Top cable:
Aileron horn-->plywood bearing-->servo-->plywood bearing-->aileron horn.
Bottom cable:
Aileron horn-->plywood bearing-->plywood bearing (under servo)-->plywood bearing-->aileron horn.
Yes, definitely a picture is in order, to explain this properly....
~Luke
Cool ···Prop-er's 30" Pond racer (full-fuses)··· Prop-er Foamies (Scratchbuilt) 295 Jan 06, 2013 03:01 PM
Burt Rutan's plane from the movie Death Race 2000 sbg300 Parkflyers 30 Aug 06, 2011 08:43 PM
Gallery Burt Rutan's "Pond Racer" Prop-er Scale Kit/Scratch Built 63 May 07, 2007 09:03 PM
New Electrics ! Including Burt Rutan's QUICKIE ! Seattle Models Product Announcements 10 Dec 24, 2005 01:19 AM
What happened to Burt Rutan's (Scaled Composites) Boomerang? atsiang Life, The Universe, and Politics 0 Apr 06, 2002 03:43 PM
