Old Mar 04, 2002, 07:31 AM
dntmn is offline
Find More Posts by dntmn
dntmn's Avatar
Gainesville, TX
Joined Feb 2002
Confused on Zagi Upgrade Please Help Photo Attached
I have researched several great web sites( http://www.yourzagi.com http://www.clubzagi.com http://www.trickrc.com ), looking for a way to get more performance out of my Zagi 400 x. I have desided to do the following:
1. strip tape and recover with ultracoat
2. Install Flat Carbon Fiber in Wings
3. Replace origional Canopy and tray with Chloroplast
4. Install magnatec mahem 22 wind reverse motor
5. 10 cell 12V 1700 mha amp battery
Here are my questions?
1. I know these are exterme mods but does anybody suggest anything different?
2. Which prop would be better 5.5 x 4.5 or 7 x 4?
3. The mm has 3.2mm shaft what size shaft adaptor should I use for the above props?
4. With a reversed motor do I use a standard prop?
5. Does the prop go on letters out or letters in?
6. In the 12v 10 cell 1700mha pack should I use a or sub c cells and how should I orrient them for best fit?
Thanks in advance for your help attached is a photo of some friends and planes, I am the one with the white zagi, 5 of the other planes are also mine. Enjoy....
dntmn has attached this image:
dntmn is offline Find More Posts by dntmn
Old Mar 04, 2002, 12:44 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
the recommend prop for the mag mayhem is a 6x5. the 7x4 would be too much. the 5.5 x 4.5 would work, but the 6x5 would probably be a little faster. the prop is mounted "letters forward", meaning that the lettering should be facing the motor. a "normal" prop can be used.
to mount the prop, i found a prop adapter made by astro at my local hobby shop. i think the prop shaft is 6mm, which fits the APC props perfectly.
use the CP1700s, which are 4/5 Sub C size. the best configuration would probably be side by side, but i don't know the dimensions of your battery tray, so you'll have to measure it yourself.
good luck!
Ben74 is offline Find More Posts by Ben74
Old Mar 04, 2002, 12:48 PM
dntmn is offline
dntmn's Avatar
Gainesville, TX
Joined Feb 2002
thanks
How did your Zagi Fly after the Mods compared to the stock setup?
Old Mar 04, 2002, 12:56 PM
Ben74 is offline
Ben74's Avatar
Joined Jun 2001
i don't have a zagi, but i use the MM in my spitfire, and it's awesome. i have read many reports that the MM is great for flying wings, so i'm sure you'll be happy with it. if you're wondering how the handling will be with the extra weight, it will probably not be able to fly as slowly, so landings will be a little faster. however, it will handle wind better.
Old Mar 04, 2002, 01:25 PM
Clu is offline
Clu
Find More Posts by Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
The MM with a 6 x 5 is a great upgrade. You will not be diappointed.
I have only run it with an 8 x cp1300 pack, but I hear the 10 x cp1700 is great.
Make sure you get the ball bearings for the Mag Mayhem: part #LXD080 at Tower Hobbies. See http://www.yourzagi.com/bearings.htm for info on how to install them.
You are upgrading the ESC, correct? You'll fry the stock Zagi one with that setup.
I also covered with UltraCote. I am very pleased with the results.
Clu is offline Find More Posts by Clu
Old Mar 04, 2002, 01:27 PM
dntmn is offline
dntmn's Avatar
Gainesville, TX
Joined Feb 2002
Looks Great
Looks Great With Ultracoat! Good Work.
Old Mar 04, 2002, 01:30 PM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Thanks. I could swear it flies and thermals better with the Utracote, but I don't have any evidence to back it up.
Old Mar 04, 2002, 01:32 PM
dntmn is offline
dntmn's Avatar
Gainesville, TX
Joined Feb 2002
How?
How did you get the MM to fit in the stock Cowell?
Old Mar 04, 2002, 01:43 PM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
I didn't on this plane, it's still the stock speed 400.
On my other (A Mini-Zagi), I just cut a 'U' out of the canopy where the motor was.
I have since converted the Mini to the 2mm coroplast tray. Works great, even with the heavier Mag Mayhem . Just make sure it is fastened down well.
I didn't like the look of the coroplast canopy, though, so I just fly it without a canopy.
Problems with few things on my RS4/ Please help latindragon79 Car Talk 1 Jul 06, 2004 05:51 PM
AF010 14Turn on Pic Fun? Please help! outacntrl Micro Helis 18 Nov 20, 2003 11:55 PM
Triton on parkflyer batteries...please help av8rOC Batteries and Chargers 3 Jan 22, 2003 08:11 AM
i am having a very hard time with my ZAGI 400X, please help!! compuatic Foamies (Kits) 22 Jun 13, 2002 07:45 PM
APC 9x6 E vs 9x6 SF on Sky Scooter - please help OUmed Foamies (Kits) 6 Dec 16, 2001 06:53 PM
