Old Dec 18, 2004, 12:43 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
On/Off Speed Controllers w/low voltage cut off???
Does anybody make a motor controller that serves only as an on/off switch and has a low voltage motor cut off? Basically I'd like to be able to start the motor, fly, then in the interest of protecting the batteries, have the device shut down the motor at a predetermined cut off voltage.
Any thoughts? HELP!!!
InTheLift is offline Find More Posts by InTheLift
Old Dec 18, 2004, 01:11 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Every ESC is like that if you dont use partial throttle..
What are you trying to accomplish with a specific ON/OFF controller that a regular ESC cannot do?
Haldor is offline Find More Posts by Haldor
Old Dec 18, 2004, 06:17 PM
It could happen...
InTheLift's Avatar
Joined Jan 2004
It's actually for a non-r/c project. Electric Control Line to be exact. The ideal would be to simply fire the motor to start flying, and when voltage drops have an automatice way to shut the motor off. I was wondering if the cut off feature is available in a unit by itself.
Old Dec 18, 2004, 08:22 PM
snowball1288 is offline
Find More Posts by snowball1288
1Point Landing Specialist
Joined Nov 2004
Ive got something kinda of like that
Its simple a cut-off unit, by hitec.
no radio control though, just a switch... seeing as you're using it on a control line aircraft, that probably wont help unless you have a buddy flip the switch for you.... but it could be a remote possiblity.
snowball1288 is offline Find More Posts by snowball1288
Old Dec 19, 2004, 12:39 AM
wrenwright is offline
Find More Posts by wrenwright
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
I would think that the lack of thrust due to low voltage would just stop the plane's flight and it would land. So why not just have an on/off switch. It would be sort of like C/L models did when people used to use fuel for model airplanes.
wrenwright is offline Find More Posts by wrenwright
Old Dec 19, 2004, 12:43 AM
new flyer is offline
Find More Posts by new flyer
go flyin or die tryin
new flyer's Avatar
grafton, West Virginia, United States
Joined Jun 2004
well if the batts can take it that would be fine but if by the time it lost enough power to land the plane and chase after it the batts would probably be pretty hurt.
new flyer is offline Find More Posts by new flyer
WTS-Diversity Aircraft-"Li-Saver" Li-ploy low voltage cut-off Dog1 Aircraft - Electric - Airplanes (FS/W) 2 Aug 17, 2004 04:11 PM
Question Low Voltage Cut-off value? DoonRaker Power Systems 2 Apr 14, 2004 12:22 AM
Low voltage cut-off for battery discharger?? Chuck Batteries and Chargers 2 Aug 29, 2002 04:49 PM
Low volt cut off on a non BEC controler? Steven D Electric Plane Talk 2 Jun 07, 2002 12:46 PM
Samples of Low Voltage Cut-Off Relay Circuits jrb Control Line 7 Dec 23, 2001 07:49 AM
