Espritmodel.com Heli Air
Old Mar 03, 2002, 07:04 PM
New York
Joined Feb 2002
Collet Style Prop Adapter or Spinner
Have a Hacker B40 18S motor (no gearbox) with a 3.2 mm shaft that's going in a Ripmax Alliance pattern plane. Looking for a very good collet style prop adapter or spinner for non-folding prop. Want to avoid units that use set screws to grip the motor shaft.
Any brand/model suggestions?
Steve
SteveR is offline Find More Posts by SteveR
Old Mar 03, 2002, 08:27 PM
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Check out the prop adapters by Graupner. You can use the 1/8" or 3.2mm interchangably.
http://www.hobby-lobby.com/propadap.htm
The GR1095 or GR1269 should work.
Gerald is offline Find More Posts by Gerald
Old Mar 03, 2002, 09:42 PM
Zebulon, NC
Joined Aug 2000
Or get em for half the price from Azarr
http://www.azarr.com/propsandadaptors.htm
Steve H. is offline Find More Posts by Steve H.
Old Mar 03, 2002, 10:03 PM
St. Mary, Maryland, United States
Joined Dec 1996
Azarr's adapters are really outstading - highly recommended.
Chris True is offline Find More Posts by Chris True
4mm Collet type prop adapter spins on shaft jhamm Power Systems 2 Jan 02, 2005 12:09 AM
Aero-naut collet type prop. adapter with two folders Eflyer14 Aircraft - Electric - Airplanes (FS/W) 1 Oct 18, 2004 06:53 PM
What size prop adapter or B40 Bill Germanson Power Systems 5 Feb 13, 2004 12:07 PM
Bullet nose collet style Prop Adapter for 4mm? Jim Miller Scale Electric Planes 6 Aug 13, 2003 03:41 PM
What prop adapter or spinner ? zorro Power Systems 0 Apr 09, 2003 09:40 AM
