Old Dec 17, 2004, 10:09 PM
Simon_au is offline
Find More Posts by Simon_au
Waiting for wind
melb, Australia
Joined Jul 2004
To prime...or not to prime
I'm ready to start painting my LEG 60" P-40 and I have one quick question.
Should I use an all purpose primer or just paint over the covering? I have covered the epp with tape then a clear iron-on film called "oz-cover" (this covering can be painted over with no preperation). I am going to be doing a basic camo scheme using spray cans (enamel) and templates.
Would it be worth puting a coat of primer on before I spray the plane? What are the pros and cons of using a primer in this situation.
Thanks for any help.
Simon.
Simon_au is offline Find More Posts by Simon_au
Old Dec 17, 2004, 10:46 PM
legliderman is offline
Find More Posts by legliderman
All work and no play
legliderman's Avatar
Lucas, KS
Joined Apr 2003
Pro's - primer makes it really smooth
Con's - primer flakes off so you finish wont last as long.
I give mine just a dusting of primer to "even out" the color but try to keep it light enough so it wont cause chipping. If your covering will except the paint without primer and is a neutral color I would say do not use it. Youll have a longer lasting finish.
legliderman is offline Find More Posts by legliderman
Old Dec 18, 2004, 12:50 AM
averen is offline
Find More Posts by averen
Love my Pike Superior!
averen's Avatar
Austin, TX
Joined Jul 2003
To help stop the flaking action (of either the paint or primer) take a 3M pad (like you would use for dishes...I like the green ones for this purpose) and run it over the surface. This will scratch it up enough to allow the paint to adhere better. You can also get the pads at most automotive and hardware stores. The ones without the cleaning sponge are better.
Jared
averen is offline Find More Posts by averen
Old Dec 18, 2004, 05:15 AM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
I heard somebody on here say to use bumper bar primer as it will flex and not peel, I have not tried it myself but....
Mick Molloy is offline Find More Posts by Mick Molloy
Old Dec 18, 2004, 07:07 AM
Schwemmer is offline
Find More Posts by Schwemmer
Sherpa
Schwemmer's Avatar
La Quinta, Ca.
Joined Sep 2003
The cracking happens when the plane doesn't land quite as softly as we hoped. When the EPP foam flexes the paint does not flex. Then the paint or primer will crack and flake off. I don't use primer.
Rick
Schwemmer is offline Find More Posts by Schwemmer
Old Dec 18, 2004, 12:50 PM
jdcook54 is offline
Find More Posts by jdcook54
PlaneCrazy
jdcook54's Avatar
Central California
Joined Sep 2003
use fine steel wool before and there shouldnt be a problem
jdcook54 is offline Find More Posts by jdcook54
Old Dec 18, 2004, 01:23 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Well there you have it- no definative answer!
I'd go with the advice given by the EPP manufacturer-
Jack at LEG. If anyone knows, it'd be him...
Good luck with your project!
target is offline Find More Posts by target
Old Dec 18, 2004, 01:34 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
I've had good luck using Plastikote Flexible primer. This is if I'm not using the Silver covering. Paint's don't stick as well, but scuffs look like weathering on aluminum, The other Solartex's have more of a fabric weave, which I don't think looks too 'scale' on some ships, so I use the primer to fill some of the weave. It won't fill it all. The Silver is great stuff, but seems harder to find. The flexible primer is harder to sand, but you only have to scuff it to get good top coat adhesion. I've dorked my 60" 109 many times and it still looks fine.
Andy
droydx is offline Find More Posts by droydx
Old Dec 18, 2004, 01:46 PM
Aerobat152A is offline
Find More Posts by Aerobat152A
Tryin not to be a hack!!
Aerobat152A's Avatar
SoCal
Joined May 2004
http://www.balsausa.com/ has miles of Solartex.... I just picked up, recieved in the mail I mean... a 5 meter roll of the Silver Solartex. I was told by one of the Masters that primer was not necessary on the low weave Silver, scuff it with (0000) steel wool, and paint.
Kevin
Aerobat152A is offline Find More Posts by Aerobat152A
Old Dec 18, 2004, 04:28 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Don't if it still holds true, but Rustoleum paints used to be a bit more flewible than the others out there. Used to use Rustoleum on lexan R/C car bodies because it was flexible and less prone to flaking off.
InTheLift is offline Find More Posts by InTheLift
Old Dec 18, 2004, 04:49 PM
droydx is offline
Fun ain't cheap!
droydx's Avatar
Joined Apr 2003
Kevin,
I keep forgetting about BalsaUSA...thanks for the heads up. Silver ROCKS man!
a covering groupie,
Droydxx
Old Dec 18, 2004, 05:42 PM
SoCal
Joined May 2004
Originally Posted by droydx
Kevin,
a covering groupie,
Droydxx
Your welcome..... someone told me here, just like when I asked, I think it was That Freekin Laird Guy ..... all ya got to do is ask.
Kevin
Old Dec 18, 2004, 08:04 PM
averen is offline
averen's Avatar
Austin, TX
Joined Jul 2003
As far as a definitive answer, here goes
Primer + Paint - will even out the surface to produce ultra smooth paint jobs. However, it is more brittle than paint and WILL flake if given the chance.
Paint only - Finish won't be as good as Primer + paint, but it will still look good as long as you provide enough coats and do it right. Paint is more flexible than primer so it won't flake as easily...it still can and will flake though.
Best bets for paint are those that are plastic based...like latex. 2 part paints (like car paint that requires a hardener) are much too hard and won't flex much at all, these will flake the second you hit anything!
Jared
spinner or not dorysch1 Electric Ducted Fan Jet Talk 7 Sep 14, 2001 01:29 PM
Litestick-Glue in the chopsticks or not? mrebman Parkflyers 7 Jul 24, 2001 12:15 AM
gear drive or not? sms Parkflyers 4 Jul 12, 2001 02:11 PM
Speed 280BB - direct drive or not? Tyson Electric Plane Talk 9 Jun 04, 2001 06:12 AM
P-40 Warhawk FLY or NOT Cosmic Shane Parkflyers 0 May 17, 2001 12:54 AM
