Old Dec 16, 2004, 12:40 AM
AntonL is offline
Find More Posts by AntonL
antipodean recalcitrant
AntonL's Avatar
Melbourne, Victoria, Australia
Joined Feb 2004
Servos for Ion/Hoot
What is the recommended elevator servo? Will an HS85MG fit or must it be a thin wing servo like an HS125MG? I haven't got the plane yet but want to order gear.
Anton
Edit: Also interested in aileron/flap servo thickness - will it take 85s or must it be 125s as well?
AntonL is offline Find More Posts by AntonL
Last edited by AntonL; Dec 16, 2004 at 06:43 PM. Reason: additional question added
Old Dec 16, 2004, 03:20 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
How about Dymond 60? I though everybody uses it
Tuomo is online now Find More Posts by Tuomo
Old Dec 16, 2004, 06:07 AM
tigroot is offline
Find More Posts by tigroot
Bob W
Rock Hill, SC
Joined Jul 2003
Here's what the 125s look like.
tigroot is offline Find More Posts by tigroot
Old Dec 16, 2004, 06:13 AM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
Thanks, looks like the 125 is the way to go.
Old Dec 16, 2004, 06:44 PM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
What about the aileron and flap servos - what thickness will the wing take?
Old Dec 16, 2004, 08:28 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
HS85BB is good, 125/5125 is better..
Old Dec 16, 2004, 08:31 PM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
Thanks, but does the wing fit 85 size servos with no bulging? I was hoping to use MPX Polo Digis (same size as 85s) for the ailerons and 125MGs for the flaps.
Anton
Old Dec 16, 2004, 09:14 PM
Komet is offline
Find More Posts by Komet
Sydney, Australia
Joined Aug 2003
AntonL, where are getting the Hoot from? I was thinking about one myself. Can they be purchased in Oz?
Komet is offline Find More Posts by Komet
Old Dec 16, 2004, 09:40 PM
talonxracer is offline
Find More Posts by talonxracer
talonxracer's Avatar
fishs eddy n.y.
Joined Apr 2003
A HS56hb would be a good elevator servo, and is much lighter than the 125's.
talonxracer is offline Find More Posts by talonxracer
Old Dec 16, 2004, 11:32 PM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
Not to my knowledge. I have ordered it directly from the designer (who I assume is also the manufacturer), Rudi Freudenthaler in Austria. His web site is here: http://rfm.xedo.at and the Ion is listed under "RFM Produkte / Segelflug". I believe "mit Klappen" means "with flaps".
Old Dec 16, 2004, 11:37 PM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
I was thinking about that but would it be sufficient if stressed...as in pulling out of a high speed dive? Seems a bit small...
Old Dec 17, 2004, 06:39 AM
C-MIC is offline
Find More Posts by C-MIC
Hong Kong
Joined Apr 2003
HS-56 should do the job, I am using one in an FVK's Absolute. Fly/dive quite fast without problem.
Two things I would suggest are:
--No slop in linkage (No Humming sound in full positions)
-- Ensure the mounting is tight no matter glue it or mount it traditionally. And CHECK IT FREQUENTLY, BEST BEFORE EACH FLIGHT, OR AT LEAST AS LAZY AS ME, Check it after every LESS THAN PERFECT LANDINGS.
Such preflight checks are IMPORTANT. I lost one plane for a broken elevator linkage, after that I got used to check all linkages prior to launch. I saved the Absolute 2 weeks ago for I found the 2 of 3 mounting wooden blocks ( traditional way) had broken free from the epoxy base. Guess due to the flexibility of vert. fin when landed on long grass.
And yesterday, such routine preflight check spotted a loosen ail servo due to mishap when packing up in rush, the batt. loaded fuselage crushed to the exposed pushrod and thus freed the mount.
David
C-MIC is offline Find More Posts by C-MIC
Old Dec 17, 2004, 07:28 AM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
Thanks for the tips and warning, David. Sounds like good advice.
OK...maybe...but I think why not have the peace of mind of an HS125MG. I wouldn't have thought that the weight difference would present too much of a problem with an electric plane carrying a motor in the nose?
Hmm...this suggests maybe a flexible mount or simply gooping it in could be the go?
Anton
Old Dec 17, 2004, 07:47 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I prefer HS81 or better for elevator. I used an 85BB in my Ariane..
..a
Old Dec 17, 2004, 06:43 PM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
I have read too many reports about HS81s developing double-centering problems, so I tend to use 85s, which seem to be a significantly tougher and more precise servo. Which brings me back to the question about whether 85s (13 mm thickness, from memory) will fit in the wing and tail without bulging?
At the moment I am leaning towards fitting an HS125MG in the elevator (unless someone can assure me that an 85 will fit), 2 MPX Polo Digis for the ailerons (same size as 85s), and 2 HS85MGs for flaps (I got it wrong in the above post when I said I was planning to use 125s for flaps).
Anton
Question Which hacker for a Ion/hoot? Geoff Akerlund High Performance 32 Jul 07, 2007 04:01 PM
TP2000 or PQ-N2600SP for Ion/Hoot EricSoar Batteries and Chargers 5 Jun 28, 2005 09:58 AM
TP2000 or Polyquest PQ-N2600SP for Ion/Hoot EricSoar High Performance 0 Jun 25, 2005 11:57 PM
Recommend elevator servo for hotliner T-tail? Roj High Performance 2 Sep 07, 2004 03:37 PM
