Old Dec 14, 2004, 06:00 PM
bwoodencock is offline
Find More Posts by bwoodencock
Joined Dec 2004
Wot 4 conversion
Hi,
Has anyone converted a wot 4 to electric?
If so, what batteries do you use?
Brian
bwoodencock is offline Find More Posts by bwoodencock
Old Dec 14, 2004, 06:16 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Hi Brian
Welcome to RC Groups
Yep there have been a few Wot-4s converted to electric - two are described in this thread
http://www.rcgroups.com/forums/showthread.php?t=306677
I've used 16xCP2400s and been very pleased with them and have just made up a pair of 8xGP3300 NiMhs to use in the Wot-4 as well. I found that I needed all the battery weight I could use, right up front to counteract the effect of lightweight motor and short nose.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Dec 14, 2004, 08:12 PM
twest is online now
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Of course you will have to change the name to "watt for?"
twest is online now Find More Posts by twest
Old Dec 16, 2004, 03:04 PM
Joined Dec 2004
LMAO! Thanks. So a 4s2p would probably not be enough? I built mine at 4.5 lbs (glow)? This would be too heavy I am starting to believe?
Brian
Old Dec 17, 2004, 06:26 AM
Sloping off....
leccyflyer's Avatar
Joined Sep 2000
Brian
My battery pack weighs 2lbs 3oz on it's own. The airframe weight is around about 4lbs 3oz, including the motor, motor mount, esc, radio gear, prop, prop nut and receiver pack, giving an AUW of 6lbs 6oz. The key thing is whether you actual model will balance with the lightweight LiPo pack, you may need to switch gear around but if you could accomplish that then it would be doable at lighter than the weight mine ended up.
Brian
Wot- 4 Twister 60 e-conversion leccyflyer Sport Planes 51 Jun 14, 2010 10:25 AM
Hitec Flash 4 conversion? injunnut Radios 5 Aug 09, 2009 07:21 PM
JHH F-4 Conversion? VF-84 Electric Ducted Fan Jet Talk 138 Apr 10, 2005 06:33 PM
G.P. RV-4 conversion Robert Belluomini Scale Kit/Scratch Built 0 Dec 02, 2002 09:12 AM
Great Planes RV-4 conversion anyone? All__talk Sport Planes 7 Apr 01, 2002 02:53 PM
