Old Dec 14, 2004, 08:41 AM
jcarstan is offline
Find More Posts by jcarstan
Dunetop Flyer
jcarstan's Avatar
Cape Cod, Mass., USA
Joined Dec 2002
A-1H Skyraider 60" by LEG - Build
Not exactly a sleek and skinny airplane, the Douglas A1-H Skyraider was first produced in 1946 and saw service in Korea and Vietnam. Originally named the Dauntless it then became known as the Skyraider or Able Dog, Spad, Guppy, Flying Dump Truck, etc. It was used by the US Navy, Marines, Air Force (AD-6) and a number of other countries as a dive bomber, torpedo bomber, airborne early warning, flying ambulance, and tanker. It was even an "air superiority fighter" with one MIG kill in Vietnam.
Having served in the Navy and seeing this plane in action I have always wanted to build one and appreciate Jack putting it out as a new offering.
First impressions of this new Leading Edge Gliders kit is: That is one huge chunk of foam for a fuselage! 5"w x 6"h x 37"l and weighing 17.5 oz.
As usual, the kit is a high quality through and through. Assembly of all components should not be difficult, even for the first time builder. There have been many excellent build threads on foamies (look for Jeff Charlot's builds) so I'm not going to document everything, nor will this be a fast build.
First thing I did was do make some reference templates for the nose and fuselage. This is a slab sided plane and the only real amount of shaping is the top, nose cowling, air scoops and the transition to flat sides and fairing into the tail. (Better read up on Jeff's fillet info.!) Also made a disk so I could turn the nose cowling on a drill press. Jack shipped the fuselage with the nose cut off, per my request.
First the teaser shot of an A1-H then on to the kit.
jcarstan is offline Find More Posts by jcarstan
Old Dec 14, 2004, 08:48 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Reference templates and finished disk.
I then glued the nose section to the disk with 3m-77 contact cement. After rough shaping with a sharp knife I used sandpaper to get the final shape.
Old Dec 14, 2004, 08:56 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Started fuselage shaping and also working on wing.
Area for dihedral braces cut out of wing cores. Instructions are very thorough so not much needs to be said except that this step is very easy using a long flexible and SHARP knife as pictures. It's been mentioned many times - use a sharp knife. Makes all the difference.
Also, thanks to all those who have mentioned Green sandpaper. Finally got hold of some and this stuff is great! Used to use sanding screens for drywall but this sandpaper is much better.
Old Dec 14, 2004, 09:07 AM
ericm is offline
Find More Posts by ericm
Vancouver WA
Joined May 2004
Wow, that's a big ol' chunk-o-foam alright...neat! Hey, you gonna put the big dive brakes on? Not that this will need them...
Looks like a fun project!
ericm
ericm is offline Find More Posts by ericm
Old Dec 14, 2004, 10:40 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Move over bacon, now there's something MEATIER!
Looks cool, should make a really sweet plane!
Steve
surfimp is offline Find More Posts by surfimp
Old Dec 14, 2004, 01:54 PM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Eric,
Dive brakes? Man the whole plane is a dive brake! Have to give the idea further thought.
Jan
Old Dec 14, 2004, 02:10 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
wow theres more foam in that than a butcher shop cool room
SteveW
steve wenban is offline Find More Posts by steve wenban
Old Dec 14, 2004, 02:28 PM
ericm is offline
Vancouver WA
Joined May 2004
If you look close in the picture you posted, the dive brake on the side of the fuselage is open. Be fun to play with...
ericm
Old Dec 16, 2004, 04:14 PM
John Rood is offline
Find More Posts by John Rood
Delusional Wanna-Be
John Rood's Avatar
Boston, Massachusetts USA
Joined Mar 2004
Jan, wow! Very cool. Good luck on this very worthy project.
John
p.s. Sorry I've not been able to get down to the Cape and fly with you...
John Rood is offline Find More Posts by John Rood
Old Dec 16, 2004, 04:30 PM
masson74 is offline
Find More Posts by masson74
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
the fuse still looks a little too square. Keep sanding!!!!!
masson74 is offline Find More Posts by masson74
Old Dec 24, 2004, 10:20 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Little more shaping done on the fuselage to get rid of the flattness on top. Final shaping I'll save until I have the gear installed and both pieces back together again.
Was a bit too aggressive in cutting out the canopy. If you build the Skyraider and want to use the plastic scoop part attached to the canopy I would recommend first cutting along the line drawn on the foam and then cutting as needed for a good fit. To make everything fit well with the cut I made I'll be using a foam top scoop that extends into the cockpit and becomes the instrument panel.
Jan
Old Dec 24, 2004, 07:08 PM
blacksheep is offline
Find More Posts by blacksheep
Mi
Joined May 2003
Skyrader
Jan,
Nice plane. Is this the one you were telling me about?
I hope you have a great x-mess and a Happy New Year.
This is form Paul In Michigan who is still working on the Same project I sent you pic of. Ill have it completed before the New Year, Just got the wing temps cut out for the hot wire.
Happy X-mess
Paul. AKA BlackSheep
blacksheep is offline Find More Posts by blacksheep
Old Dec 24, 2004, 07:23 PM
Aerobat152A is offline
Find More Posts by Aerobat152A
Tryin not to be a hack!!
Aerobat152A's Avatar
SoCal
Joined May 2004
I always loved that Skyraider..... Looks like you've done a real nice, clean job so far..... looking forward to the end result.
Kevin
Aerobat152A is offline Find More Posts by Aerobat152A
Old Dec 25, 2004, 01:27 AM
Jeff Charlot is offline
Find More Posts by Jeff Charlot
Insert custom witicism
Jeff Charlot's Avatar
San Diego
Joined Jun 2001
Very nice Jan, cool to watch the progress of others, love these build threads.
Jeff
Jeff Charlot is offline Find More Posts by Jeff Charlot
Old Dec 26, 2004, 03:08 PM
Madguns is offline
Find More Posts by Madguns
Madguns's Avatar
United States, FL, Navarre
Joined May 2004
Very nice!
I want to convert the Skyshark RC Skyraider to Electric. Good luck!
Madguns is offline Find More Posts by Madguns
60" LEG ME-109 Build Version 2.0! Tawg Slope 74 Aug 31, 2015 01:11 PM
Discussion LEG 60" Spitfire build thread Jeff Charlot Slope 175 Aug 31, 2015 12:07 AM
Build Log 60" LEG Aircobra build progress ave Slope 120 May 07, 2005 04:14 PM
60" LEG Planes Now "Officially" Available surfimp Slope 21 Nov 27, 2003 03:52 PM
60" LEG ME109 Builder Question droydx Slope 7 Nov 02, 2003 11:38 PM
