Old Dec 14, 2004, 05:34 AM
speedchaser is offline
Find More Posts by speedchaser
speedchaser
Brighton, Great Britain (UK)
Joined Sep 2004
Question
Offset rudders or not offset rudders...
Do rc racers have offset rudders on their boats purely for reasons of oval or 'none-offshore' racing (because boats are turned more one way than the other way in the course of a race), or is there also another reason? I.e. nearly all the pictures of riggers that I've seen have offset rudders, so it would be interesting to know if rigger types used for straight-line (offshore) speed events also have offset rudders, or if they have or can have the rudder behind the prop...
speedchaser is offline Find More Posts by speedchaser
Old Dec 14, 2004, 10:40 AM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
I think you'll find that the American off-shore class is limited to semi-scale mono's and cats. I think even the European Naviga classes for hydros also use a triangular course.
martin richards is offline Find More Posts by martin richards
Old Dec 14, 2004, 05:17 PM
speedchaser
Joined Sep 2004
Cheers, could a rigger type have the rudder behind the prop anyway just like for any other surface drive setup...(for speed/strait line events) - many thanks
Old Dec 15, 2004, 12:09 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
I've never seen anything but offset rudders on hydros, be they saw or oval racing. For saws, everything that produces drag, like rudders and turn-fins is kept to a minimum and the 120+mph boat used cut down stainless steel kitchen knife blades
Old Dec 15, 2004, 07:18 AM
Knotaddicted is offline
Find More Posts by Knotaddicted
Panama City, Panama
Joined Nov 2004
Could it also be for ease of mounting and/or weight savings? It is easier to mount the rudder pivot directly to the transom, and stronger, than putting it on a strut assembly to get it behind the prop. also mounting it to the transom saves the extra weight of the strut assembly, when every little bit counts, thats needless grams hanging of the back. Mind you I don't know from experience, as I am building my first boat, and it is a scale boat, not a fast electric outrigger.
Knotaddicted is offline Find More Posts by Knotaddicted
Old Dec 16, 2004, 01:20 PM
speedchaser
Joined Sep 2004
To 'm.r' - right many thanks on that, so an offset rudder will generally produce less drag than one behind the prop for rigger types made for strait-line (offshore) events even.
I say 'offshaw' even though I will try to run the boat (when finished) in 100% calm conditions. Initially I was erring on behind-the prop as my main tub will only be 4 inches wide - and owing to how most servo's are arranged it will be very tight to get an offset mounting, but I think it's just possible. the other reason was because I thought that the wake/thrust created by the prop would assist in turning the rudder more quickly... As to kitchen-knife blades for rudders, well you learn something new every day, and thanks also to 'knotaddicted', I agree it would be better/easier to mount it to the side of the transom. I'm also building my first totally scratch buit-boat as well - why I couldn't have started with a mono I don't know...
Old Dec 16, 2004, 03:41 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
The offset rudder also makes it more convenient to remove the prop shaft. [You don't need to remove the rudder first.] This was done on the DE-1052 Knox-class destroyer escorts, even though they were hardly race boats.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Dec 17, 2004, 04:31 AM
speedchaser
Joined Sep 2004
Thanks - that settles it for me, as I'll probably need to reposition the motor a few times over the first few test runs, so beng able to remove the prop shaft easily will be essential...
Old Dec 28, 2004, 01:54 AM
jolllyroger is offline
Find More Posts by jolllyroger
Northern California
Joined Feb 2004
a rudder mounted behind the prop would be far more likely to cavitate. The swirling water coming from the prop would cause areas of high compression on one side of the rudder and a vacume on the other side.
Cavitation occurs when the water is comressed to the point that it breaks down the chemical composition releasing gas bubbles. Another form of cavitation is when air travels down an object from the surface due to a vacume created by the motion of that object. Cavitation can quickly eat away metal as well as cause vibration and stresses that could cause parts to fail.
jolllyroger is offline Find More Posts by jolllyroger
Old Dec 28, 2004, 01:59 AM
Northern California
Joined Feb 2004
forgot to mention all of the drag that would be induced as well.
I watched a full size water speed record on tv and removing a small piece or the rudder 1/4 inch made a difference of 25 mph average speed which was all that was neccesary to break the record. They then removed another 1/4 inch and gained 33 mph avg speed breaking the record by an even larger margin. water creates lots of drag and the faster you go the more drag is created
Old Dec 29, 2004, 05:12 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
The drag issue is indeed what counts.
I run a Hopf Baracuda in the races, standard set-up (as the rules are) and gained just that bit of top speed, allowing me to clinch the Dutch mono 1 championship by changing the rudderblade from the wedges aluminum one to a steel (wedged) blade that was aprox. three times as thin.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Discussion hydroplane...1 or 3 active rudders ? mattijs321 Foamies (Kits) 2 Feb 21, 2006 07:58 PM
Litestick-Glue in the chopsticks or not? mrebman Parkflyers 7 Jul 24, 2001 01:15 AM
gear drive or not? sms Parkflyers 4 Jul 12, 2001 03:11 PM
Speed 280BB - direct drive or not? Tyson Electric Plane Talk 9 Jun 04, 2001 07:12 AM
P-40 Warhawk FLY or NOT Cosmic Shane Parkflyers 0 May 17, 2001 01:54 AM
