Old Dec 14, 2004, 02:45 AM
flighttosky is offline
Find More Posts by flighttosky
Hong Kong
Joined Apr 2004
F14 Tomcat fly to sky video!!!
Total Weight 850g,
power set: seek your recommandation!!
Battery: E-power 11.1v 2200mah(8C) Proposed
wings can swing
Test flight will be on this sat / sun
flighttosky is offline Find More Posts by flighttosky
Old Dec 14, 2004, 02:51 AM
n1troboy is offline
Find More Posts by n1troboy
Sydney Rose Bay, Australia
Joined Sep 2004
who makes this model? is it dual engines?
n1troboy is offline Find More Posts by n1troboy
Old Dec 14, 2004, 02:56 AM
Hong Kong
Joined Apr 2004
I made that!! from building foam kit to finished model.
still left one kit for parts replacement
I plan to use pushed motor to fly her!!
Old Dec 14, 2004, 04:24 AM
n1troboy is offline
Joined Sep 2004
sweet - what a masterpiece....well done - hmm I'm no good with pushers but would assume a geared 400 / 480 brushless setup would make her scream....
Old Dec 14, 2004, 04:35 AM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
What are the dimentions?
I would say maybe a mega 3 turn and 8.4 volts.
skyhawk is offline Find More Posts by skyhawk
Old Dec 14, 2004, 04:42 AM
Arthur is offline
Find More Posts by Arthur
Ceredigion, Wales.
Joined Oct 2000
Lovely job flight, all the best on the maiden and keep us posted. Arf
Arthur is offline Find More Posts by Arthur
Old Dec 14, 2004, 04:55 AM
Hong Kong
Joined Apr 2004
wing span is 120cm(max)
length is 115cm
try to take a movie if she can fly to sky!!
Old Dec 14, 2004, 05:00 AM
Hannibal is offline
Find More Posts by Hannibal
Hannibal's Avatar
Rome
Joined Jul 2004
This is the first RC Tomcat that seems a Tomcat. Really good good work! Tell us something more!
Hannibal is offline Find More Posts by Hannibal
Old Dec 14, 2004, 05:02 AM
Hong Kong
Joined Apr 2004
Post some internal details
Old Dec 14, 2004, 09:55 AM
milky2971 is offline
Find More Posts by milky2971
FLY PEMBREY (PFC)
milky2971's Avatar
Wales (UK)
Joined Aug 2004
V Nice
Trev
milky2971 is offline Find More Posts by milky2971
Old Dec 14, 2004, 10:29 AM
Fulcrum is offline
Find More Posts by Fulcrum
mig-29 freak
Fulcrum's Avatar
Jonage (Rhône), France
Hi, very beautiful work
Personnaly from my experience with my depron mig-29 of 840g i would recommend a Mega 16/15/5 with a APC 7x5 (large blades) and 3s lipo. Under that config my mig has a T/W ratio of 0.8 and draw 16A and fly very well and fast. I tried a 16/15/3 which drew 31A with a cam pro 4.7x4.7 and 37A with a 5.2x5.2. I never was thinking to try in that config and waited for receiving the 16/15/5. I also tried the 16/15/4 and got a ratio of 1.1 with 3s and the APC 7x5-large blade but drawing 29A (I didn't try flying under that config, only static record on scale and wattmeter) which drop down to 23A with an APC 7x5 narrow blade and conserve a ratio of 0.8. With that latter config the autonomy is shortened, the hand "take-off" as much easy as with the 16/15/5 APC 7x5 large blade but the speed is a little quicker. My mig is 67cm wing span smaller than your 120cm max wingspan for that reason i really recommend you the 16/15/5 rather the 16/15/3 and maybe you can consider 4s instead 3s lipo, it is only speculation because I never tried 4s lipo. For sure with the 16/15/5 and 3s lipo and a 7x5 APC large blades she will fly great with a reasonable consumption therefore duration of flight. My 3s is a Poly-Quest 3100 slim (220g) which can deliver 37A (12C).
Good flight
Fulcrum is offline Find More Posts by Fulcrum
Old Dec 14, 2004, 10:30 AM
Fulcrum is offline
mig-29 freak
Fulcrum's Avatar
Good flight
Old Dec 14, 2004, 11:01 AM
Hong Kong
Joined Apr 2004
Thanks , I just got a 380 brushless motor(look like mega, but made in Taiwan) with 1800kv,
when using 7x4 APC propeller draw about 12A, can provide about 650g pushed force,
I hope can use that, I will try 8x4 tomorrow, hopefully, if it draw below 16A, it provide more power(>700g)!!
Old Dec 14, 2004, 11:22 AM
Fulcrum is offline
mig-29 freak
Fulcrum's Avatar
Dear Flighttosky,
It seems the motor you find is similar in spec as the mega 16/15/5. On the other hand I tried myself a prop greater than 7x5 with no more thrust, but it is true for the mega. I even got less thrust you will see. In fact less thrust with a larger prop of the same pitch will not means more speed for a lower static thrust as it is the case when you lower the diameter but keep high the prop pitch and coming close to the square prop ie the pitch equal the diameter. I am curious of your data assay. I would advise you rather the 8x4 to use a 7x5 APC large blade as it is very efficient in fact.
Old Dec 14, 2004, 02:35 PM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Have you seen the Matt Holden/JHH F-14??
New Stearman just finished. Paul Wilson Fuel Warbirds 11 May 02, 2005 11:15 AM
Chris Wolfe and his F14 Tomcat MAN Apr Appie Electric Ducted Fan Jet Talk 20 Feb 05, 2004 11:31 PM
New Mini Telemaster finished! MAKODS Parkflyers 0 Jan 18, 2004 01:59 PM
New P-47D Finished! mtflyr Foamies (Kits) 22 Jul 07, 2003 06:55 PM
New Tiny Almost Finished skyfox Parkflyers 8 Jul 16, 2002 10:06 AM
