Old Dec 13, 2004, 09:28 PM
Sackie is offline
Find More Posts by Sackie
Sackie's Avatar
Steinbach, MB, Canada
Joined Nov 2004
Rave
Need suggestions on Stinson SR9 color scheme
This is my first attempt at scale aircraft and I am just completing a Top Flite Stinson Reliant SR9 100" ws. I would appreciate links to picture site as all I can find is red, white, black, each with the usual Stinson flash down the side and on the wheel pants. I am looking for something more colorful, yellow, blue, etc as the main color. I am also trying to find full figures in 1/5 scale for this same airplane, male and female. Any assistance is appreciated.
Sackie is offline Find More Posts by Sackie
Old Dec 16, 2004, 11:03 PM
tone is offline
Find More Posts by tone
Pontificating Member
tone's Avatar
Atlanta
Joined May 2003
here are a couple
http://images.google.com/images?q=St...ff&sa=N&tab=wi
tone is offline Find More Posts by tone
Old Dec 18, 2004, 11:25 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Here's a website with scads of Reliant pics. BTW, I'm building an electric conversion of an old Berkeley Stinson Reliant SR9-C ( modified as an SR-8 flat windshield panel version) ( See thread under Electric-Scale Modelling.
http://www.stinsonreliant.com/
E-Challenged is offline Find More Posts by E-Challenged
Old Jan 22, 2005, 08:45 PM
Hans Bruhn is offline
Find More Posts by Hans Bruhn
Beeton Ontario Canada
Joined Nov 2003
Stinson Reliant
Could you tell me what the quality of the Kit is,money well spend or?
Would sure like to know.
H. Bruhn
Hans Bruhn is offline Find More Posts by Hans Bruhn
Old Jan 22, 2005, 10:40 PM
Sackie is offline
Sackie's Avatar
Joined Nov 2004
H. Bruhn
Hi Hans, the quality of the kit is good BUT......I have built 4 kits and scratch built a Pylon Racer .40 sized prior to this kit and I must advise that it is a long build and a complicated one as well. You will reach some points where you will wonder 'how am I to do this?' and some you will figure out as you make mistakes as there are some complex areas where the instructions do not help, one such area is bending the balsa sheeting multiple ways over the top and the bottom of the wing, remember the wing shape?...from root increases and at rib 5 I think, it decreases to the tip, complex bend, you must glue to front and using much ammonia soak and bend then glue to sub spar but only from tip to rib 5, then bend sheet to meet front between 5 and root and glue, then bend to sub spar and glue....lots of CA glue and remember that Ammonia retards the drying of CA glue, so watch your fingers...
Fuse formers are construced from many pieces, for former 3 about 16 I think, kinda get to you after a while. But nice looking airplane when finished. Also I had to contact Top Flite when I reached the point of gluing the canopy top front to the former...they have stated that you BUTT JOINT the PVC canopy to the EDGE of the TOP of Former 3 with medium CA, well I refuse to glue like this so I took some scrap square balsa and rounded one corner with a sanding block cut into 3/4 inch pieces and glued to front top edge or former, rounded the edge to match shape of former 3 and then glued PVC canopy to this scrap.
It is a truly good kit but NOT ONE FOR BEGINNERS. I have installed a larger engine than needed, I am using a US Engines 41 and have 3 servos in tail and will still need some weight in tail to balance. Hope this helps.
Old Feb 20, 2005, 10:13 PM
Joined Oct 2000
I'm getting ready to cover my old Berkeley SR-9/now SR-8. Building and converting this old fashioned kit to electric R/C has been a chore with more head scratching than building. The structure is probably as complex as your large TF version but I think that larger is in some ways easier to work on. I'll bet the die cutting is lots better. My kit was produced after Duke Fox bought out Berkeley and the dies must have had round edges by then. I wondered about the need for jig saw puzzle formers and other parts in this kit too. I'd like to see GWS make a park flyer Reliant with nicely molded foam gull wing for all the Reliant lovers out there.
Old Feb 21, 2005, 09:23 AM
Sackie is offline
Sackie's Avatar
Joined Nov 2004
Hey E-Challenged, have you as yet selected your color scheme?...I find the basic Red or White schemes too plain. I have completed mine to the point of needing to mold epoxy with filler around the edge of the windshield for a nice look but can't get any true SLOW epoxy locally so waiting until I travel to a LARGER city to purchase some to complete the build. Other than that everything is complete with the exception of covering/painting.
Old Mar 06, 2006, 05:12 AM
dwils is offline
Find More Posts by dwils
Joined Mar 2006
stinsonreliant.com
dwils is offline Find More Posts by dwils
Old Mar 06, 2006, 08:24 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
[/IMG]Here's my cream and blue SR 8.
TomCrump is offline Find More Posts by TomCrump
Old Mar 07, 2006, 03:48 PM
dgliderguy is offline
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Eric Anderson's SR9
One of the prettiest Top Flite Stinsons I have ever seen has to be Eric Anderson's green-and-cream rendition. Elegant and stately. A real trophy bird.
dgliderguy is offline Find More Posts by dgliderguy
Old Mar 09, 2006, 02:06 PM
jetmex is offline
Find More Posts by jetmex
Humble, TX
Joined Dec 2003
The military version of this airplane was the AT-19, which has some pretty neat camo schemes. Many of the RAF airplanes had yellow, or yellow and black striped undersides. A good google search will bring up quite a few of these:
http://rwebs.net/ghostsqd/at-19.htm
http://www.war-eagles-air-museum.com/at-19_1.html
jetmex is offline Find More Posts by jetmex
need suggestions on what lipos to buy lagcisco Batteries and Chargers 7 Dec 02, 2003 02:46 PM
I need suggestions on an indoor plane. Steve Vasdekis Foamies (Kits) 3 Sep 29, 2003 02:45 PM
Need suggestions on torque rolling plane H-tail Parkflyers 0 Aug 10, 2003 11:13 AM
Need suggestions on what to build with the following: micron Foamies (Kits) 7 Apr 15, 2003 03:37 PM
Need suggestions on how to stabilize a T-Hawk wing worldzfree Parkflyers 6 Feb 15, 2003 12:44 AM
