Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Dec 13, 2004, 03:58 PM   #1
Dances With Wind
Brian Courtice's Avatar
Building the Sky King R/C Products Shrike
Ed Berris recently sent me a pre-release copy of his complete Shrike 60" pitcheron kit.
The plan is for me to build the kit and do a build thread. I will post detailed pictures and report on any glitches or problems I encounter while building the airplane.
Our intentions are to provide a reference for those who have already purchased (but have not yet built) one of Ed's earlier short kits, and to help Ed decide on any last minute modifications or improvements to the kit before the planned February release date.
So here we go.
Let's start by taking a look at what comes in the box. As you can see, this is going to be a very complete kit. Notice the rolled plans, detailed construction manual, lazer cut wood parts, and complete hardware package.
  • Name: shrike03.jpg
Brian Courtice is online now Find More Posts by Brian Courtice   Reply With Quote
Old Dec 13, 2004, 04:04 PM   #2
Dances With Wind
The most important parts of this kit are the fuselage and the wing cores. I was favorably impressed with both.
The fuselage layup looks very good. It's strong and free of pinholes.
The wing cores are very nicely CNC cut blue foam. There is not a ripple or a ridge to be found. Looks good so far.
  • Name: shrike01.jpg
Old Dec 13, 2004, 04:08 PM   #3
Dances With Wind
Here's another view of the very accurate looking wing core. Note the pre-drilled hole for the wing tube and the precut slots for the sub ribs.
  • Name: shrike02.jpg
Old Dec 13, 2004, 04:16 PM   #4
Dances With Wind
Ok, lets stop fondling the kit contents and start building!
The first thing to do is to cut a small foam wedge off of the tip of each foam core as shown. After the cores are sheeted, balsa wing tips will be glued on and sanded to shape.
  • Name: shrike04.jpg
Old Dec 13, 2004, 04:23 PM   #5
Dances With Wind
The next step is to put a balsa end cap on the brass wing rod receiver tube.
Ed suggests that you first sharpen the tube by inserting an exacto into the end and spinning it around a few times. This will shave away some of the brass inside the end of the tube and make it quite sharp.
Now press and twist the tube into some scrap balsa until you are able to cut out a nice balsa cap. Set the cap in place with a couple of drops of thin CA and then touch up the cap with a sanding block to make it flush in diameter to the brass tube.
  • Name: shrike05.jpg
Old Dec 13, 2004, 04:31 PM   #6
Dances With Wind
Remove one set of sub ribs and one root rib from the sheet of lazer cut parts provided in the kit.
  • Name: shrike06.jpg
Old Dec 13, 2004, 04:39 PM   #7
Dances With Wind
Dry fit the wood parts, brass receiver tube, and the wing rotation pin as shown.
For clarity, I have drawn refernce lines on the foam showing where the parts beneath the foam are, and I have set the extra set of parts from the other wing in place to show how the parts get oriented.
The brass tube should pass through the hole in the outer sub rib, and the wing rotation pin should pass through the hole in the inner sub rib.
All of the slots in my wing cores were cut out about 3/16" too far forward. This was very easily corrected by cutting a 3/16" notch at the rear of each slot. The notches allow the sub ribs to slide far enough back so that the brass tube and wing pin will pass through properly.
The gap at the front of the slots is not a problem. They can be filled with a little spackle before the cores are sheeted.
  • Name: shrike07.jpg
Old Dec 13, 2004, 09:14 PM   #8
Mr. Innocent's Avatar
Send a message via AIM to Mr. Innocent
alright so.. HOW many planes have you got??? It seems like you get a few new planes every day .. jeeze... looking great though.
Mr. Innocent is offline Find More Posts by Mr. Innocent   Reply With Quote
Old Dec 13, 2004, 09:29 PM   #9
It could happen...
InTheLift's Avatar
The SHRIKE!!!! WOOO HOOOOOO!!!!!
InTheLift is offline Find More Posts by InTheLift   Reply With Quote
Old Dec 13, 2004, 10:50 PM   #10
Challenge is rewarding
djklein21's Avatar
I want one!!
djklein21 is offline Find More Posts by djklein21   Reply With Quote
Old Dec 14, 2004, 01:06 AM   #11
jofo1's Avatar
Brian, the photos of the v-tail faring.
jofo1 is offline Find More Posts by jofo1   Reply With Quote
Old Dec 14, 2004, 03:22 AM   #12
Dances With Wind
Whoa. You just broke the record for the most humungus pics I've ever seen posted on this forum.
I took the liberty of resizing them for those among us that are not using a 38" monitor.
Thanks for posting Jofo. The fairings look great. Can you describe how you made them?
(Jofo has built a few Shrikes already and he has some very good ideas.)
How about some pictures of your finished planes?
  • Name: v-tail faring04.jpg
  • Name: v-tail faring 02.jpg
Old Dec 14, 2004, 10:31 AM   #13
jofo1's Avatar
Sorry about the pic size. I'm a beginner on the photo editor thing. I made these by gluing root ribs (had an extra set when I took Ed up on his early bird special) to the boom, slipping them over the already installed tail pins. Then I just filled the gap between the rib and the boom with bondo and sanded. It really stiffened the v-tails as they have a flat surface to mate to now, not to mention the ribs have added alot of strength to a weak spot (holes in carbon tubes can split).
I'll delete the monster sized photos.
Old Dec 14, 2004, 11:55 AM   #14
Dances With Wind
Thanks Jofo. Those fairings look good, and they serve a usefull purpose by reinforcing the tail boom too.
Let's get back to work here:
While the parts are still dry fitted into place, stick the carbon wing rod through the fuselage and slide the wings on to check the gap between the wing root and the fuselage sides. Do this BEFORE you glue in the brass tube or glue on the root ribs. A little tape will hold the root ribs in place for now.
As you can see in this picture, my wing roots were cut at the wrong angle. (This is a small error that was made by the contractor who did the CNC cutting for Ed's kits.)
If you find that there is a gap of about 1/2" at the trailing edge, remove the root ribs and reciever tubes from your wing cores, and simply cut off a wedge of foam at the root to correct the angle. The red line I have drawn on the picture shows where to make the cut.
  • Name: shrike08.jpg
Old Dec 14, 2004, 12:04 PM   #15
Brian is wing linkage something off the shelf at a LHS or is this something custom? Next question are the tail feathers slid over the pins then held by tape? The reason I ask is that Ive been tinkering with a pitcheron and about to sub the (p) for a (b) if you get my meaning.
slims is offline Find More Posts by slims   Reply With Quote
New Product Precision R/C Products hemituda Product Announcements 3 Nov 16, 2006 10:47 PM
Building the Star 45 R/C sail boat U.D. rec.models.rc.water 1 Jul 11, 2006 04:11 PM
XRB Sky Robo R/C Payload Potential crux12 Micro Helis 0 Feb 06, 2005 08:58 AM
New R/C products announce... glockengockel Parkflyers 11 Apr 03, 2004 08:51 PM
EBAY: various R/C products FA Tony Turley rec.models.rc.air 0 Feb 09, 2003 01:02 PM
11
