Old Mar 02, 2002, 06:14 PM
pfsiegel is offline
Find More Posts by pfsiegel
Cincinnati
Joined Feb 2002
Speed 400 Class P-39
At a slow time during a basketball game today, I was in a discussion about a P-39 project. However, preliminary examination of three view drawings reveal a very short tail moment and small tail surfaces. Does anyone have any experience with such a scale model at about a 30" span? Any ideas on what percent increase in horizontal stab would be appropriate? Any other suggestions before I cut wood? Paul Siegel
pfsiegel is offline Find More Posts by pfsiegel
Old Mar 02, 2002, 07:46 PM
Terry Lyttle is offline
Find More Posts by Terry Lyttle
Keremeos, BC, Canada
Joined Dec 1996
P39
There are threads about the HOB kits, one of which used to be the P39, apparently out of production. If you can find the kit plans (I will fight you for a full kit!), it may be worth while to at least start there. It had the full molded turtle deck/canopy, but you shoud be able to bs that out with a Sig canopy, etc. From personal experience, I know that the HOB kit flew nicely, once you learned how to launch it (same applies to any of these kits). Once in the air, just gorgeous...
Terry Lyttle is offline Find More Posts by Terry Lyttle
Old Mar 02, 2002, 07:54 PM
Jim Ryan is offline
Find More Posts by Jim Ryan
Jim Ryan's Avatar
Cincinnati, OH USA
Joined Oct 2000
Re: Speed 400 Class P-39
It was a great game, but when the Muskies pulled away, we didn't have John Calipari to talk to, so we were reduced to designing airplanes instead.
I'm hoping Tex will surface and let us know what the areas are like on his modified Top Flite kit. I do know that Keith Shaw had an "interesting" experience test flying some guy's P-39 many years ago. The Airacobra is sure a great looking machine though....there has to be a way!
Jim
Jim Ryan is offline Find More Posts by Jim Ryan
Old Mar 02, 2002, 08:26 PM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
HOB airplanes
I think the HOB kits all used the same wing, and I suspect similar moments. Not particularly scale, so making conclusions off that series of airplanes might not be valid. They might all fly the same. My only contact with P-39's is that I made an 'Airabonita' out of a Jack Stafford P-39 kit for a friend. He says it never flew steadily, but hunted around a bunch and could never figure out why. Surely not a construction-related problem. That, too, is a model airplane, so I don't know what can be generalized off that either. Most warbirds have short-ish tails compared to aerobatic airplanes, and I'd guess would be less than sterling aerobats because of that.
PeterH is offline Find More Posts by PeterH
Old Mar 03, 2002, 09:57 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
I believe the HOB 1/2A kits all used the same design and modified the wingtips, canopy molding and tail group outlines for their variants.
Still have a HOB p39 kit .. never got around to building it after the my P51 and Me109 ones were done.. impressions after 20 years.. V nice instruction book..but a seriously overbuilt kit and the wood selection is poor, canopy molding is acceptable but not great.. amazing as to how far the goalposts have moved since then ;-)
Bare is offline Find More Posts by Bare
Old Mar 03, 2002, 07:55 PM
Joined Dec 1996
P39
Yeah, Bare, and I guess yer keepin it too, eh?
Right about moments, etc; the P39 is fairly close, but my buddy's FW190 plan has the ing about 1" back from scale. If one was to run electric, the wing could be moved ahead without penalty by moving batts, etc. I saw a 109 with the wing in scale position, and it flew fine(hot 1cc diesel power); no nasty surprises and it flew out of your hand (I launched) with a mild breeze.
Old Mar 03, 2002, 09:22 PM
kit basher is offline
Find More Posts by kit basher
Mike Swan
Oroville, California, United States
Joined Oct 2000
Heres a Earl Stahl freefight p-39,if you look at the tail surfaces you can compare the differant outlines.http://www.theplanpage.com/esp/p39/airacobra.zip (447kb)
kit basher is offline Find More Posts by kit basher
Old Mar 04, 2002, 08:15 AM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
TF P-39
Jim and all: My 'Cobra is a real tiger with the power on, yet a pussy-cat when it comes to vices. There dosen't seem to be any bad habits. I've slowed it down, banked and yanked and all I get is a bit of mushing. It's rock steady in high speed flight and it slows to a crawl on landing. I don't know just how scale the tail surfaces are, but they appear to be adequate. Wing area is touted as 850'ish I think, so wing loading is squat at 8lbs flying weight. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Mar 04, 2002, 07:28 PM
Joined Dec 1996
P39
Yup, my experience too; flies like a MUCH larger model.
Favourite trick (particularly when the left-circuit club guys were at the field) was to run out the last of the power in a climb; nearly a dot. When the model stalled from no thrust, it would snap into a dive, and I would start yelling "deadstick! deadstick!" as the model came screaming down vertically. Then I would proceed (while the club guys hid under pickups) to do a couple of big, fat loops, a series of rolls, and inverted downwind, and slide the model onto the grass a few feet away... A truly lovely model...
NEAC Speed 400 class Ed Franz Electric Sailplanes 1 Jul 08, 2003 06:15 PM
Hacker Brushless info for Speed 400 Class needed PDX Slope Pilot Electric Sailplanes 2 Oct 09, 2002 04:01 PM
A speed 400 class Graupner MIni Piper?? tnsfrk Parkflyers 5 Oct 05, 2002 09:40 PM
Is there a Speed 400 class plane that will fly for + 20 minutes PDX Slope Pilot Foamies (Kits) 24 Aug 29, 2002 03:17 PM
Speed 400 Aero L-39 Mark Haigh Electric Ducted Fan Jet Talk 14 Apr 10, 2002 04:32 PM
