Mine lets me fly to High!
I have a strange problem with mine too. It allows me to fly too far away I can hardly get her back. Good thing its a Slow Stick and not a Pico Stick.
I love my GWS Receivers!! It's a big picture...the Slow stick in there...I don't think anyone should be flying a park flyer this far away to begin with. WOOT! |
Joined Sep 2004
I fly the 4 channel and 6 channel GWS RX in sailplanes, slope gliders and brushless wings with lipo. Never a glitch, even when the sailplanes were at speck altitude--until I tried a rubber duck. Range dropped to about a hundred feet. With the regular antenna, no problem. I think they are great little receivers.
You see the reality of a GWS RX working right condition.
![]() If not because of wrong pluged BEC or battery, this will be a normal performance. ![]() May be I should make a plastics case with connector guide, so every one will be foreced to plug in right. See the acutally performance. Then if he like to reduce the weight, he may take off the case on his own risk to damage the filter capacitor!
Philippines
It may be good for sailplane coz there's no motor running and for parkflyer/slowflyer which could recover from glitch due to its slow speed but for fast warbird with costly brushless motor and esc up front, I wont dare.
My warbird would normally ditch at certain location even Im alone in the field using GWS rx even I replace it with another GWS rx. With the electron 6 now in place. I have the confidence to do on low pass and fly on windy condition. |
I REALLY wish GWS would start adding DSP (Digital Signal Processing) to their receivers.!!!
Otherwise they will loose a market. I only use GWS receivers for slower, less important/dangerous aircraft, for faster ones - Berg, and Hitec 555 or Electron, which are FAR better than GWS dual conversion, according to their own specs. If you need 6N receiver plus crystal = price is close to high quality Berg5... There are many DSP receiver available today, and CC will release cheap 4 channel DSP berg receivers soon, taking yet another bite from GWS receiver pie. Or you could add DSP chip to your GWS receiver yourself : http://www.rcgroups.com/forums/showthread.php?t=298197 |
Philippines
your rx case Mr. Lin cannot be corrected by making inovative case. We speak as technical people and speak with our own experience with your rx. Need to accept the fact that we sometimes operate nearby busy airtraffic which your GWS rx are prone to be affected. Why is my other brand of rxs on the same freq. not affected by such?. I may be the only one who has experienced it as of now (you may say) but the fact that it happens it will eventually happen to others.
Your rx can be as is unless it has warning tags: dont operate on busy bla. .bla.. to avoid bla. .bla. . bla.. Hovertime has one perfect suggestion I think. Nevertheless I have bought 3 GWS rxs. I use them only on my tigermoth and slowfyers. Thats the good news!!!! |
Okay, so i have an old R4P reciever (actually i have 2) that is really glitching badly. What can i do about it? what can i check on it? What capacitor? where? how do i check it? I am running 3 others with no problems but this one reciever has always been a problem. I may have reversed it when i first got it, as its my first micro reciever i purchased in 2002.
Can this be fixed? |
Why RISK it.
For only $25 dollars you can get a Brand new one. I know after I spend 8~16 hours on building an airplane I would hate to loose it due to a glitch.
Buy a New One I don't see how you could fix it for less than the price of a new one. Have you turned your crystal 180 degrees and put a piece of tape over it to hold in place? Does the problem follow the crystal? -gerald Quote:
| Thread Tools | |
| Anyone else have problems with (Toddsmodels)? | mike93 | Vendor Talk | 41 | Oct 24, 2005 09:09 AM |
| Anyone else have problems with bug blades? | hb888 | Micro Helis | 13 | Sep 28, 2005 05:53 PM |
| Anyone Else Having Problems with the GWS Videos? | aeronca | GWS (Grand Wing Servo) | 4 | Aug 22, 2004 06:00 PM |
| Anyone else have problems with GWS radio batteries leaking? | C172 | Beginner Training Area (Aircraft-Electric) | 9 | Jun 25, 2004 05:01 PM |
