Espritmodel.com Heli Air
Old Dec 12, 2004, 05:01 PM
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
Wing help: spar location with respect to airfoil and planform.
Hi there,
Given a particular wing planform, and a particular airfoil, where do I locate the spar? The planform I'm trying to replicate is shown in the diagram, and the airfoil I would like to use is the Eppler 479. The red lines represent 25% of chord at the ribs.
I'm guessing the spar should be on the 25% chord line?
What if I want to use a straight spar (say, to facilitate the use of a carbon tube).
Thanks.
Iso Octane is offline Find More Posts by Iso Octane
Old Dec 12, 2004, 05:21 PM
Pueblo, CO
The wings I have seen have had the main spar located at the high point of the airfoil.
Merry Christmas. Ron
ozzie46 is offline Find More Posts by ozzie46
Old Dec 12, 2004, 07:01 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
At the thickest point is much more common but it's not a rule. But if you try to put it back TOO far then the spar won't be at the point of maximum load on the wing and the wing will try to twist. But if you're using a tubular spar in the middle of the ribs it doesn't really matter where you put it within reason. Anywhere between about 25 and 35% would be acceptable. Bear in mind though that a carbon tube spar is not going to be as strong or rigid as a proper outer surface spar and webbing combination. Carbon is great stuff but it needs to be used in the correct manner to get the most out of it and a tubular spar that is much smaller than the wing thickness is not using the material to it's best.
BMatthews is offline Find More Posts by BMatthews
Old Dec 12, 2004, 08:49 PM
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
Thanks for the input.
I'm planning for this is to be a built up Depron wing. 37" wingspan. I guess I'll go with 2 carbon tubes through 25%, and "foam sheer webs" around the tube to join the upper and lower surfaces of the wing. Should be okay?
I ran some number through this online cg calculator. and resulted in the CG position in the picture below.
Old Dec 12, 2004, 10:11 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
The tubular spar would offer a degree of flexibility if that is important to you. A lighter and stiffer spar that would better control the structure would be an I beam made from a couple of 050 carbon rods with vertical grain balsa between them. I'd use 1/16 balsa and then wrap the whole mess with a double criss crossing wrap of kevlar or carbon thread to bind the whole lot together. The thread forming an XXXXXXX pattern on the webbing. The whole thing would then be painted with something to tie the kevlar thread to the spars.
Old Dec 13, 2004, 03:55 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The spar is preuly structural, and has no bearing on aerodynamics, so hgh4est point and deep4est spar is where it does teh most good.
Having said that, it ought to be near the center of pressure to minimise twisting on the wingtips.
If its to be straight you will have to just eyeball it. won't make a huge amount of difference.
Old Dec 14, 2004, 01:31 AM
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
That spar construction method sounds interesting, but I wouldn't want to go too overkill for a parkflier. ...or maybe I do.
Another question if I may. What's the generally accepted principle with regards to dihedral and differing rib heights. What I mean is, that the height of the ribs decrease from root to tip, so, do I centre all my ribs, or do I arrange them to form a flat wing top, but "dihedral" wing bottom? Please refer to my diagram.
Thanks.
Old Dec 14, 2004, 02:38 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Your choice. It's not that much dihedral to really matter. A pattern flier would notice if they are good enough so it may make a difference. But for a parkflyer I'd just do it whatever way is easiest. Technically your second sketch is going to be the most neutral flying option provided your wing is going to be mid mounted as shown. The upper one will tend to look less like the wing is drooping though.
Old Dec 14, 2004, 03:49 AM
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Iso by the looks of that plane and wing platform I'd go back another inch fron the LE at the root for your CG.
fnnwizard is offline Find More Posts by fnnwizard
Old Dec 15, 2004, 12:49 AM
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
Okay, I'll be going with my second drawing.
CG position noted.
I'm going to step off topic a bit and throw out another question. What are the effect of the wing and the stabilizer being positioned off the thrust line? I would rather not do things by the TLAR method, but I've been looking at a lot of glow widebody pattern type plane photos and it seems that most have the stab near or on the thrust line, with the wing below it. Are there some guidelines as to what the positions are?
Old Dec 15, 2004, 01:47 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
There are but it mostly relates to how the model performs in verticals and knife edge. It's all very subtle and mysterious if you don't fly pattern. Remember those guys are looking for Precision with a capital P and if you just want to hack around and do 3D stuff and hover the reality is that you can get away with a lot more. Even 3D has rules but they are more related to ensureing that the profile area is properley distributed to simulate a wing in knife edge flight and that the controls are massive enough.
Old Dec 15, 2004, 11:58 AM
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
I probably wouldn't notice that little bit of extra precision, nor could I acheive it since I lack any kind of professional experience in airplane design. However, given the chance, I'd rather have something better (better in this case, a more precise airframe) and more optimized (optimized for better flying characteristics, and I happen to think pattern is "better" than 3D when it comes to flying, not hovering), rather than something that is merely adequate.
Discussion help with Navion airfoil Vanning Modeling Science 7 Jul 28, 2007 11:21 AM
Question Effects of Stab and Wing Location with respect to (distance from) Thrustline? Iso Octane Modeling Science 2 Feb 10, 2005 05:30 PM
Wing Spar Location ToddO Foamies (Kits) 8 Dec 19, 2001 08:51 PM
Covering Undercambered Wing Help Needed Claude17 Electric Plane Talk 7 Jul 05, 2001 10:22 AM
Airfoil choice for flying wing, help needed slowflyer Power Systems 14 Jun 23, 2001 02:20 AM
