Old Dec 12, 2004, 02:20 PM
adcyork is offline
Find More Posts by adcyork
How do i change the oil in my shocks?
ok. i have just bought a thunder tiger ssk second hand and i'm giving it a service before i send it out on the dirt. I need to know how to change the oil in the shocks. They are the shocks that came as stock on the ssk. how do i do this?
also the shocks seem to sag through about half of the full travel with just the trucks weight. why is this?
adcyork is offline Find More Posts by adcyork
Old Dec 12, 2004, 11:24 PM
Kiiski is offline
Find More Posts by Kiiski
Will race for parts!
Kiiski's Avatar
United States, WA, Chehalis
Joined Mar 2004
Take the spring off, unscrew the cap, dump out the old oil and spray out the shock bodies with nitro spray. Refill the shock about 3/4 full with the oil of your choice. Now pump the shock slowly, not letting the piston rise above the oil. Do this for about a minute per shock. Pull the piston all the way to the bottom, fill the shock to the top, put the cap back on and screw it on one turn only. Slowly push the piston back up while screwing the cap back on. You'll know you have it right when the shock rod pushes itself out about 1/4 inch, if it pushes out too far, you have too much oil, if it doesn't push out at all, you don't have enough oil, you'll get the hang of it after a few rebuilds.
You want the shocks to sag, the lower A-arms should be about level in the front, and the rear dogbones should be slightly lower in the center than at the wheels. If they aren't where youi wnat them to be, adjust them with the shock spacers. But remember that the shocks need to have some "downtravel" to be able to follow terrain.
Kiiski
Kiiski is offline Find More Posts by Kiiski
Old Dec 13, 2004, 12:34 PM
adcyork is offline
thanks mate. that's a real help.
Old Dec 18, 2004, 07:40 PM
lectraplayer is offline
Find More Posts by lectraplayer
Professional Crasher
Joined Apr 2004
Here's a tip: if you want it stiff, you can use castor as your oil. That stuff is thick, and it seems to work great for me, though I am doing off-road.
lectraplayer is offline Find More Posts by lectraplayer
How Do I Change The Text Under My Name? Azygos Site Chat 8 Apr 16, 2004 01:54 AM
HELP! how do I change the address on my profile? fumblefingers Site Chat 3 Sep 30, 2003 07:34 AM
