okay, if you aren't doing RFFS no matter what, then here's what I really sinserely recomend. Really, please, please check out these items! They are the best I can think of, and are all very cheap!!!!!
the lightest reciever (either a lightened up R4P, by taking replacing all wires with smaller ones, replacing all connectors by direct soldering, and taking off the case, OR, better yet, for a ton more money, but the best available reciever there is in my opinion, the Berg 4 channel. It is $60, and very, very light) check aeromicro.com for both of those and the best prices... I would NOT get HS-50 servos!!!!!!! You REALLY need the lightest here, as these are VERY heavy - all of them. I *really* recomend the lightest servo out there today - the new Cirrus CS-5.4 servo. To lighten it, take cut off the mounting tabs, take it apart and replace all wires with skinnier wire, leave the bottom of the case off (use tape to hold the inners in) and cut out all connectors and use direct soldering. Keep lightening up everywhere you can think of until you get to 4.2 grams - that's what Matt Keenon got it down to. Anyway, the lighter, the better ESC: you will definately not need something like 7 amps like your controller - not sure, but if the GWS 5amp controller is lighter, don't hesitate, get it. battery: 2s pack of 230mAh lipos - this is *perfect* for the below combo. motor: I think this motor loooks really good. I'd look into it: http://www.allerc.com/ go to "Motors and Propellers" and the first thing there is what I'm taking about - the "GWS EDP50-XC" . Run it DD with the included propeller, or go up a half inch or so, but beware, that the motor is going to fry a little sooner that regular. They are cheap though...and you'll have lots of more performance... Please check all these items out and take a good look at them, they are the best I can think of as far as the lightest non-RFFS system goes without getting crazy with prices. Hope That Helps! -aeroP |
Aeromicro says for the GWS R4P: "4-Channel 72 MHz FM GWS Pico Receiver JR Version with Horizontal Connector Pins (0.16 oz)" .16oz = 4.535924 grams. WOW, you are very right! I stand corrected! PLus, take off the case, use smaller wires, no connectors, and I'll bet it is down to 3 grams if you *really* try! rakm, yes, these recievers are great for indoor flights. You do not need too much distance maximum....they are great for outdoors too - some people only use them, everywhere, and swear by them. -aeroP |
Mike, thanks for the clarification... 500 feet, yet it is not much in comparison, that is farther than I think I will ever fly a model from myself - maybe 300ft max definately, but one doesn't want gliching when the model blows away in the wind far, far awway.
ServoCity says that all the "good" Hitec recievers (little 2 channel-er and feather not included) have a "1 mile+" range. I assume that this is the average range, and what to expect from any reciever with a good reputation that costs more than $30 (ahem, ahem, feather, R4P). I'd assume that the micro stamp has that too. -aeroP |
AeroP, on a 15" span biplane, who cares if your Rx doesn't perform well at 1 mile. You can't see the thing at 500 feet. I still think a GWS R4P is the "smartest" choice for this airplane. I've used them in all of my Acro Bipes and have never lost one to anything related to the Rx. All it did was correctly execute the stupid commands I gave it, resulting in the models demise
![]() Jason |
yeah, yeah....
Yes, now of course that I was proven wrong that the R4P is a lot lighter, I say it is a LOT better! Who needs 300ft range for a plane like this?? Let along 500, let alone 1 mile!
Look two posts up, where I said >>>Mike, thanks for the clarification... 500 feet, yet it is not much in comparison, that is farther than I think I will ever fly a model from myself - maybe 300ft max definately, but one doesn't want gliching when the model blows away in the wind far, far awway.<<< see, I'm not making it up ![]() -aeroP P.S. far, far away won't happen in a gymnasium - the walls will grab ya! |
Victorville, CA
Joined Mar 2003
and you thought that was light...
If you really want a leight-weight "standard" receiver try Sky Hooks and Rigging's receivers (www.microrc.com). Their "standard" one is 4 channel @ 2.8 grams. For the extremist, they have a PRO model, 5 channel @ 1.9 grams (no connectors)
That, and their 4 channel receiver/ESC combo is lighter than a GWS 4rp, wieghing in at 3.3 grams (7 amp esc!!) Oh, and they are tested to 1000 feet A bit pricy though... ![]() Loren |
| Thread Tools | |
| Build Log RFFS-100 2cell Ultimate bipe | jjkwang | Indoor and Micro Models | 15 | Sep 17, 2003 10:50 PM |
| Wanted - RFFS 100 | Allan Wright | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 24, 2002 08:43 AM |
| RFFS-100 Opinions | mlitke | Indoor and Micro Models | 6 | Feb 23, 2002 10:54 PM |
| RFFS 100 Shipments | dhurd | Indoor and Micro Models | 9 | Feb 15, 2002 02:07 PM |
| RFFS 100 Videos | dhurd | Indoor and Micro Models | 9 | Feb 13, 2002 02:25 PM |
