Old Dec 11, 2004, 06:17 PM
zed is offline
zed
Find More Posts by zed
zed
zed's Avatar
Singapore
Joined Apr 2004
My own design...comments?
Hi,
Built a plane over 2 nights, utilizing one of the foam wings from Dean (steelhead). Didn't do any calculations or design, just cut the body shape using imagination. Comments?
zed is offline Find More Posts by zed
Old Dec 11, 2004, 06:22 PM
bradinsb is offline
Find More Posts by bradinsb
Brad
Joined Nov 2004
Have you flown it?
It looks neat for a build yourself
bradinsb is offline Find More Posts by bradinsb
Old Dec 11, 2004, 06:33 PM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Nice!
TLAR.
It looks kind of Magpie-ish.
Brian
wattsup_kz is offline Find More Posts by wattsup_kz
Old Dec 11, 2004, 06:53 PM
Matthew Binder is offline
Find More Posts by Matthew Binder
The Evil Twin
Garden City, GA
Joined Feb 2004
Nice job! Lets get a flight report.
Matthew
Matthew Binder is offline Find More Posts by Matthew Binder
Old Dec 11, 2004, 07:37 PM
zed is offline
zed
zed
zed's Avatar
Singapore
Joined Apr 2004
Magpie-ish? Hmm....doesn't seem similar to me. But I did use Doug's AXI motor mount to mount my speed 400 motor. Haha...this plane is basically a collection of all the unused things in my box - speed 400 motor, 7cell kan 1050's, hs55's..
Anyway, just came back from a test flight. The plane is kind of heavy, cos the fuse is made up of solid balsa sheets. (I'm not good enough to do the the complex frames, maybe my next build). CG must be off, cos the plane was twitchy. Turns weren't as smooth as i would like. Landing approach is soooo fast. Quite a slippery airfoil, it just keeps on going. Oh by the way just in case its hard to see in the photo, the wingspan is only 32inch.
Anyone knows how to fine tune a plane? It flies but not well. I'm a little clueless as to how to go about improving it.
I'm pretty happy how I managed to get something I designed to fly...haha.
Old Dec 11, 2004, 07:42 PM
zed is offline
zed
zed
zed's Avatar
Singapore
Joined Apr 2004
maybe i should give some credit to Doug, the "basic" idea of building a square fuse and securing the wing with rubberbands came from the smoothE. But of course it flies no way similar to the smoothe. Cos the wingspan, power setup and the total weight would give it a totally different flight characterisitic.
Zed
Old Dec 11, 2004, 08:20 PM
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
If that wing has no dihedral (I can't really tell) then you will not turn smoothly without ailerons. Dihedral would also help the stability.
Brian
Old Dec 11, 2004, 08:47 PM
zed is offline
zed
zed
zed's Avatar
Singapore
Joined Apr 2004
no dihedral at all
Hm....so does that mean I HAVE to have dihedral to use rudder-only?
Zed
Old Dec 11, 2004, 08:52 PM
zed is offline
zed
zed
zed's Avatar
Singapore
Joined Apr 2004
i have another one of those wing cores, maybe i will put in some dihedral. Whats the best way to do it? cut in half then cut an angle and glue back? how would you put the spar on the "v" shape?
Wow i'm learning so much with building...i'm loving it!
Zed
Old Dec 11, 2004, 09:35 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
Originally Posted by zed
no dihedral at all
Zed
Only if you want to be able to turn decently instead of just yawing.
Rick
ElectRick is offline Find More Posts by ElectRick
Old Dec 11, 2004, 09:36 PM
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
no dihedral at all
Zed
With a straight wing, the plane is "skidding" sideways ahead to some degree when the rudder is used.
The dihedral will cause some banking through the turn helping the plane to change direction, not just orientation.
To give your other wing dihedral, cut it in half and make a support to put under the wingtip (2 or 3 inches high). Support the wing half (I tape it in place with masking tape) so the cut end is flush with the edge of your workbench and sand or cut it so it is at 90 degrees in relation to the bench top. Do the same with the other half and glue them together. You will need some reinforcement like strapping tape to strengthen the joint.
You will find it much easier to fly, and with 2 wings, you could add ailerons to the straight one.
Enjoy,
Brian
Old Dec 12, 2004, 12:18 AM
cathode is offline
Find More Posts by cathode
End User
cathode's Avatar
United States, IN, Nashville
Joined May 2002
with no dihedral, you'll be lucky to stay in the air at all. the plane will slip from side to side constantly... and you'll need ailerons to recover the plane when it falls off to the side... I've been there
cathode is offline Find More Posts by cathode
Old Dec 12, 2004, 01:04 AM
Rat is offline
Rat
Find More Posts by Rat
Rat
Come get me if you can
Rat's Avatar
Rats nest Grafton ND
Joined Aug 2004
Tape the rudder straight then move the rudder servo to the middle,top of the wing. Cut some ailerons and tape them to the wing. Now find the servo horn that extends to both sides of the servo. Install that and run a control rod from each side to the ailerons. So when the servo rotates one way it will pull one aileron up while pushing the other aileron down. Now you can fly it only using the elevator, ailerons and throttle. No need for the rudder.
Rat is offline Find More Posts by Rat
Old Dec 12, 2004, 09:34 AM
zed is offline
zed
zed
zed's Avatar
Singapore
Joined Apr 2004
Thanks for all the advice guys!
wattsup_kz: I will follow your instructions to do the dihedral, but how do I put a straight spar into a dihedral wing?
rat: Putting the ailerons seem like a good idea. Maybe i'll take out the rudder.
Zed
Old Dec 12, 2004, 09:47 AM
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Cut the spar in half. The strapping tape takes the place of the spar in the middle. For details you can go to www.jkaerotech.com and look up the T-52 build instructions where they show the wing construction. That makes a good strong dihedral joint.
The Magpie build threads show a similar type of joint.
If you go with ailerons, you can keep the wing straight.
Brian
My own design Sensor less/ Brush less/ Slot less Motor and driver Takao Shimizu Power Systems 84 Jul 28, 2005 04:35 PM
Pics of My Own Design Yak 55 Flat Foamie Boss248 3D Flying 22 Jan 13, 2005 04:54 PM
A delta wing sloper of my own design Web Slope 165 Aug 02, 2004 11:58 PM
My own design... 7homuz Free Flight 6 Oct 03, 2003 11:27 PM
My own design scratchbuilt Sopwith 'strutter for IPS power Looooeeee! Scale Kit/Scratch Built 22 Jan 29, 2003 05:02 PM
