I don't think a 20mAh cell will take the current draw of a 6mm pager, radio, and actuators.
What operating system are you running on your computer? Win XP? Try this Image Resizer |
Mike,
Still waiting for pics of your Baby Ace ![]() Used a single piece for each top and bottom half of the wing. Bottom looks great. Top of the wingtips...not so good. In reality they are good enough. If it turns out to be an outstanding flyer, I'll worry about recovering the tips then. They may also be included in the red trim scheme assuming I get to that too. The fuse turned out fairly nice so far. Better than I thought it would when I started placing the tissue. How did you handle the longeron on the center of the side of the fuse? I just attached the tissue around the perimiter and shrunk it up with alchol. I've got to move my air compressor into the basement before I can seal the tissue and paint the nose. Should I apply any trim tissue before or after I seal/finish the tissue? I think trimming the tail would be much easier before it is attached to the fuse. |
I've been hung up getting a job. That entailed taking tests and creating a sample programming assignment. Almost done so I can get back to the fun stuff...
On the longeron, I just made it in pieces added into the sides during building the side frames. Since the nose box was going to come out square and flush with the fuselage box, I kept it all in one plane. I think you should shrink the tissue, dope it lightly, then add the trim tissue sticking it down with dope. That way, there won't be any uneven shrinkage issue to deal with... Pix to come... |
E,
As heavy as it is, I will be going 'big' on the power with a geared N-20 and 2 small LiPolys. I have both a coule of RFFS modified for 2 cells and a Micro Joule with 2 cell ESC. I also have JMP RXs, but they are single cell only (I don't have a 2-cell adapter). I think I will add the MJ RX and use 2 Falcon servos like Tiberius shows in post #184 above. The balsa sheets let into the fuselage in front of the tail will be where the push-rods exit. I have played around with the radio gear placement, and it looks like EVERYTHING will need to go in front of the LG - its going to be pretty crowded in there! I will mount the 2 servos on a thin balsa sheet that will span the fuselage frame-work and move it back and forth until I get it close to balancing, then lock it down. When I get it figured out, I'll post photos of that part, too. BTW, Naomi is quite happy to be in the model. She is refering to it as her model! |
| Thread Tools | |
| dime scale fokker d-8 | billystiltner | Free Flight | 15 | Dec 31, 2007 11:22 PM |
| Dime, peanut, walnut, etc scale | Martin Hunter | Indoor and Micro Models | 9 | Jan 14, 2005 12:30 PM |
| Dime Scale Micro RC? | mcross | Indoor and Micro Models | 11 | Dec 08, 2003 09:28 AM |
| Large scale set up | VF-84 | Sport Planes | 1 | Jul 17, 2003 02:44 AM |
| New Free Flight Cook-Up Begins.... | jernst | Free Flight | 0 | Jul 01, 2003 06:32 AM |
