| Wingspan: | 28.5" |
| Wing Area: | 240 sq. in. |
| Weight: | 9.5 oz. |
| Length: | 23" |
| Wing Loading: | 5.7 oz/sq. ft. |
| Servos: | 2 Cirrus 6.5 gram, incl. |
| Transmitter: | Cirrus 27 Mhz FM 4 channel 2 stick Mode 2, incl. |
| Receiver: | Cirrus 27 Mhz FM 4 channel, incl. |
| Battery: | 7 cell 300 NiMH, incl. |
| Motor: | 12mm brushed motor with a 5.861:1 gearbox , incl. |
| ESC: | Global 5 amp unit, incl. |
| Street Price: | $179.99 |
| Manufacturer: | Clancy Aviation |
| Available From: | Global Hobby |
The Lazy Bee design by Andy Clancy has a shape and style well known to modelers everywhere. Lovers of the Lazy Bee have elevated this design to cult status in the radio control hobby, where it is probably THE single most recognized non-scale model design since the classic Ugly Stick. Some people love its dumpy but charming retro look, some people hate it, but no one is unaffected by this model that dares to be different.
Clancy Aviation and Global Hobby have taken the Lazy Bee formula of retro styling, low aspect ratio wings, high lift aerodynamics, great maneuverability, stability and ease of flight and applied it to the all new model under review here, the Lazy E-Bee. Now the parkflyer crowd can enjoy a fully Ready To Fly version of the Bee, nicely molded in foam, fully painted and assembled that delivers solid park level performance right out of the box.
Here is a brief comparison of the original Lazy Bee and the Lazy E-Bee:
| Original Lazy Bee | Lazy E-Bee | |
| Span: | 40" | 28.5" |
| Powerplant: | Glow .049-.15 up to .26 4-stroke | 12mm brushed motor with gearbox |
| Construction: | balsa | molded EPS foam |
The box containing the Lazy E-Bee was opened with some anticipation and curiosity, since I had enjoyed flying Lazy Bee models in the past. The major parts of the model were bagged in polypropylene plastic for protection and neatly nested in a foam packer. This model should ship well. The pictures of the open box show the major parts with the poly bags removed for clarity.
First impressions were good. The model came pre-painted in a red and black color scheme that brought to mind the classic Travel Air Mystery Ship racer. The under-cambered wing was neatly molded in EPS (expanded polystyrene) foam with a generous length of wooden dowel inset in the wing's leading and trailing edges to prevent rubber band damage. The injection molded EPS foam fuselage had all the radio and power components already installed except for the Nickel Metal Hydride flight battery. The Cirrus 6.5 gram servos were pre-installed externally, one on each side of the fuselage, giving exceptional access for adjustments and repairs, if needed.
Pushrods were already installed complete with external standoffs for stiffness. The model had an electronic speed control arming switch pre-installed on the upper right side of the fuse. After installing the flight battery, this momentary pushbutton switch needed to be pressed once to arm the electronic speed control. For safety, he throttle would not work until the model was armed.
The electric motor and gear drive were already mounted with rubber bands, giving a nice degree of crash protection. The Clancy geared motor appears quite similar to the well respected GWS 12 mm brushed motor, plus its own gearbox. The gear ratio is 5.86 to 1 and the shaft size is 3mm. It came with a heat sink installed, a smaller one that I had never seen before. The prop, a Clancy 10/5, is very similar to a black GWS 10/4.7, but the shape is different and the prop blades had a little more area. The electronic speed control was installed in the upper fuselage, under the wing mount and the receiver was installed inside a small hatch on the bottom of the fuselage. I did not remove the ESC and have not been able to positively identify it, so I assume it was a pretty typical 2-5 amp brushed ESC.
One of the more interesting features on this model was the flexible, crash resistant foam battery hatch on the lower nose area of the model. The hatch and area where the hatch mounted on the lower nose were equipped with Velcro. To install (or remove) the flight battery, I pulled back the foam hatch and secured (or removed) the battery. A Velcro mount for the flight battery was already installed in the battery compartment. Almost any hard landing or crash was likely to end up putting a lot of stress in the lower nose area and the foam would do a very good job of absorbing the impact of this 9.5 oz model.
The tail surfaces were molded in sheet EPS (Depron style) foam and came with the control horns pre-installed. The horizontal tail had a tape hinge and the vertical tail attached to live hinges pre-mounted in the aft fuse, giving the model a full flying vertical tail.
The landing gear was a classic Lazy Bee installation, a straight axle inside a plastic tube with two lightweight parkflyer wheels pre-installed. The true Lazy Bee purist might want to switch over to the vintage Trexler pneumatic tires. The unit was attached to the model with a rubber band on each side of the fuse.
The radio system included was the Cirrus 4 channel FM unit on 27 MHz. Kudos to Clancy Aviation and Global Hobby for supplying a decent entry level FM radio system on 27 MHz for this class of model. Supplying the model with a radio on 27 MHz helps keep the new parkflyer from coming into radio conflict with other radio controlled models on 72 MHz. The transmitter is a full size 4 channel 2 stick unit with reversing switches on the lower front of the transmitter. The transmitter has a very decent feel and even has adjustable length control sticks. Compared to most modern radios that bristle with switches and knobs, this transmitter is a very clean and simple unit. The TX requires 8 AA Alkaline dry batteries. The receiver that is pre-installed inside the Lazy E-Bee is the Cirrus 4 channel FM unit that appears similar to the Hitec Feather receiver.
The battery supplied for the model is a 7 cell 300mAh NiMH pack, arranged in a 6 pack plus one layout. As a more experienced modeler, I would've prefered if Clancy Aviation and Global Hobby had included a Li-poly battery and charger, instead of the older technology NiMH unit (as Global Hobby did with the Micro Flyer.) To be fair, the NiMH battery will work fine for the typical beginner, is less expensive keeping the total package price down, and also safer for the beginner. The connector is a black interlocking 2 pin unit that is showing up in several different brands of RTF electric models these days. The battery charger supplied is a simple wall transformer unit that will recharge the pack in two hours. The charger does not have any automatic features and the user must monitor and time his charging manually, to prevent overcharging.
The other contents of the box were a clearly written, nicely illustrated and well detailed assembly and operating manual and two poly bags containing rubber bands, screws for the rudder, a spare prop and spinner and a red ribbon to serve as a wind indicator for the transmitter antenna.
All in all, the Lazy E-Bee presented well in the box as a ready to fly model aimed at the newcomer to R/C park flying.
The Lazy E-Bee arrived on my doorstep a day before a local indoor flying event. I decided to put the box in my van and carry it along to the event and assemble it on site, during the flying. Even though the model was not advertised as an indoor flyer, I was confident sure that a Lazy Bee style model that weighs in at 9.5 oz. would do well indoors. I glanced at the instruction manual to make sure I had everything needed to complete the assembly. This very short list called for just three items: 8 AA alkaline batteries for the transmitter, a small Phillips screwdriver and a small adjustable wrench.
Our indoor group had been invited to fly a demo all weekend at the Automobile Building at Dallas Fair Park. After a morning of flying other models, I decided it was time to tackle the Lazy E-Bee. I enlisted my daughter Sarah and my good friend Richard Ng to help out with the photos needed. Many thanks for the photos they supplied! After taking pictures of the box and kit components, I plugged in the stock charger and flight battery for a charge. As I would expect for a RTF model, assembly proceeded very rapidly. It took less than 40 minutes to complete the model, even stopping at every step for photos.
This is a condensed version of the assembly instructions:
Note: Be sure to check the prop nut. The prop on the review kit came pre-installed, but was a little loose.
The model was ready to go as soon as the battery charged. As we were taking pictures, the build took about 40 minutes. An experienced R/C modeler would take no more that 10 minutes to assemble the Lazy E-Bee.
After the battery was charged and installed, it was time to double check the direction and amount of the control throws. No one else at the indoor event was on 27 MHz, so I had 27.095 to myself for the day. This Lazy E-Bee required no pushrod, servo or servo direction adjustments after the radio was turned on. Everything was centered and working properly. The model was set up with the rudder and elevator on the right stick and the throttle on the left stick. The fourth channel was not used on this model.
The review model's electronic speed control did not start to respond until the throttle was at about 45% travel. Not a huge issue, but a bit annoying for the experienced flyer. Once the ESC started the motor, all the throttle range occurred over a pretty small part of the TX stick throw.
The model was armed and placed on the concrete floor. A quick check for other models nearby and the throttle was advanced. Just like hundreds of Lazy Bee type models before this, the Lazy E-Bee trundled down the runway and floated into the air easily.
I know that people that read R/C reviews get tired of hearing it, but the model was trimmed nicely right out of the box. It had a very faint left turn tendency, but this was not an issue as it needed to be turning left often to avoid the walls of the indoor venue. It spent the next 8 or 10 minutes cruising around the indoor site at about 50-60% power, making effortless circles and figure 8's. The model was as easy to fly as any rudder/elevator/throttle model that i have ever flown. Indoors, the stock battery was good for around 10 minutes. This will improve a bit as the battery gets broken in a little.
I passed the transmitter to a number of local pilots during the first flight, among whom the model was universally enjoyed. The model did turn a little better to the left than to the right. Inspection after landing showed a small warp in the wing that needed a small adjustment. Easy to fix with some gentle bending of the wing. The model landed better with a bit of power carried until it touched the ground. The 27 MHz radio system worked flawlessly and it was pleasant to not have to worry about any radio conflicts indoors.
Not wanting to wait for another two hours for the stock battery to charge, I made a field splice to convert the battery connector in the model to a BEC type, so I could use some of my collection of 2 cell Li-poly batteries. The only one available that would more or less fit in the unmodified battery compartment was a Thunder Power 700 2 cell pack. The foam battery compartment cover still showed a slight bulge but it worked fine. To use larger cells like a 2 cell 1200 Li-poly, the modeler would have to open up the foam at the back of the battery compartment to make room for a larger pack. The CG shifted back just a little with the 2 cell 700 Li-poly pack, but it was still acceptable. I would not recommend using a smaller Li-poly battery than this, because of balance concerns. For the outdoor flying, I carved out some foam as described above and used a 2 cell 1200 mAh Li-poly battery. The CG worked out just right and the weight change was negligible.
After installing the new battery, the Lazy E-Bee took to the indoor air again. Several more pilots tried their hand at the Lazy E-Bee and all ended up with grins on their face and were nothing but complimentary about the way the Bee flew. One of our regular indoor fliers accidentally steered the Lazy E-Bee straight into the wall at about half throttle. The Bee bounced off, the only damage being a crack in the rudder that was easily fixed with foam safe CA glue. This little crash showed that the Lazy E-Bee was tough as well as cute. The balance of this flight was spent doing endless circular touch-and-go landings, allowing one wheel to barely touch the floor and roll. Only a model with a good match of controllability and stability makes this look easy.
No aerobatics were attempted inside, as I wanted to preserve the model for upcoming outdoor photography.
With much local rain and wind recently, I have only managed one outdoor flying session so far with the Lazy E-Bee. I took this opportunity to do a range check. The first range check was a little less than the recommended 75 feet of ground range, model on the ground and antenna out. I elected to fly anyway and the radio system was rock solid in flight. (I repeated the range check the next day and got much more than the 75 foot minimum range, so there must have been a bit of 27Mhz interference at the field I flew in the first day.)
The grass was a bit long for an ROG. This was not a problem, as the little Bee hand launched effortlessly. The little E-Bee had the same good manners and pleasant handling outdoors that I had observed indoors. It looked great handling the 6-8 mile per hour wind during the two flights I was able to make.
I have not fully explored the aerobatic envelope of the Bee, but it looped nicely out of a dive. With the stock geared 12mm brushed powerplant, this model was much more of a trainer and cruiser than an aerobatic model. I spent most of the outdoor flights trying to position the Lazy E-Bee for photographs, taken by me while I was also doing the flying. Not many models other than a Lazy Bee would let the pilot multi-task like that!
If you have a non modeling friend that wants to try an RTF parkflyer electric model, you would not go wrong suggesting this one. Andy Clancy and Global Hobby have created a new Bee that will make a fine addition to the Lazy Bee family. The Lazy E-Bee is very easy to assemble, flies well, is easy to train on, is damage resistant and all the parts supplied work well together. The quality equipment provided allows room for upgrading if desired. Yes, you could upgrade almost every electric and electronic part, but the model will certainly satisfy anyone who enjoys relaxed park flying as is. I have no doubt that that there will soon be any number of Wild E-Bees out there. In fact, you could put together an airframe from the spare parts catalog, but the cost is a little high, in my opinion: A wing, fuse, tail parts and landing gear order would be around $49.50. I would like to be able to buy a complete, unpainted foam parts kit less expensively, and be free to upgrade in interesting ways. Some kit-bashing and a 12 mm or even larger brushless motor, ailerons and lots of excess power might be fun.
I did contact Mike Greenshields of Global Hobby and asked him about the possibility of releasing a ARF airframe only kit version of the Lazy E-Bee. He replied that they had no plans to offer a kit just like the Lazy E-Bee, but planned to offer something similar. As above, he mentioned that if you had to have one, you could order the airframe parts from the spare parts service.
Pros:
Cons:
| Thread Tools |
Joined Feb 2008
cAN ANYONE TELL ME WHERE I CAN BUY A LAZY-E-BEE (OR ITS EQUIVILANT?
hAROLDSHEL@AOL.COM |
| Thread Tools | |
| Discussion Wing Dragon 2 vs. Lazy e-Bee | quar | Parkflyers | 7 | Feb 09, 2006 09:38 AM |
| Lazy E-Bee, a starter or no? | CanDyRaVeR | Beginner Training Area (Aircraft-Electric) | 15 | Dec 12, 2005 02:14 PM |
| Clancy Lazy E-Bee RTF ? | BrianRickman | Parkflyers | 32 | Dec 07, 2005 04:28 PM |
| Help! Lazy E-Bee broke when recieved | CanDyRaVeR | Beginner Training Area (Aircraft-Electric) | 2 | Jun 04, 2005 03:22 PM |
