Old Dec 09, 2004, 09:45 PM
superboss is offline
Find More Posts by superboss
Opel Superboss, The Car!
superboss's Avatar
Auckland, New Zealand
Joined Nov 2004
Ultrafly Cessna 182 Motor - Battery Help
Hi there Forum.
I just bought a Ultrafly Cessna 182, and its come with a speed 400 motor and geared setup.
http://www.modelflight.com.au/ultraf...cessna_182.htm
See above link, I think it that.
Anyway. Because it is a Speed 400 motor and geared, will my 2S 3100 mah, 12C rated constant polyquest pack, be sufficient for this bird?
Or will I have to get a 3S lipo pack?
The current pack weighs 150grams.
Does the fact that its geared make it able to use a smaller battery pack or a bigger one? Meaning more or fewer cells?
You help would be greatly appreciated.
Cheers
Supe
superboss is offline Find More Posts by superboss
Old Dec 09, 2004, 10:27 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
2 cells wont cut it .
you need 3 for the speed 400 to work.
the packs you have a very heavy for a little ultrafly model.
the 3s 1500 polyquests or 1800 slim packs are good if you can make them fit.
on 3s of the currnt packs u may need to drop a prop size to keep the amps below 12 or the motor will burn up quickly.
ozace is offline Find More Posts by ozace
Old Dec 10, 2004, 03:30 AM
superboss's Avatar
Joined Nov 2004
Hi there. Thanks for your reply
If a 8Cell Nimh 1100 pack which is the recommended pack
weighs 169 Grams
I would think the PQ-2600mah-3S pack is the best choice as it
weighs 163 Grams.
Or am I missing something?
Old Dec 10, 2004, 04:04 AM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
I am pretty sure that ultrafly recommend a 10 cell pack for their planes not 8.
the 2600 will be heavy to cart around, you wont need more than the 1500's, but you wont have the duration of the 2600's
choices, choices
good luck
Old Dec 10, 2004, 10:11 PM
Papakeith is offline
Find More Posts by Papakeith
Imposing TeddyBear
Papakeith's Avatar
Rhode Island
Joined Jun 2004
The 8cell 1100 pack will work well with the beginner wing. It should also be able to run fine with the advanced wing that the kit comes with. However, if you have the choice, I would go with either a 10cell pack or a 3s lipo pack.
The falcon400 motor that comes with the ultrafly cessna is not a regular 400 motor. It is wound differently. It is designed to work at 12v. I believe 12A is the maximum current it can handle without frying.
I run a 3 cell lipo pack with my cessna. @11A max, and I'm not having any difficulties.
Papakeith is offline Find More Posts by Papakeith
Sold UltraFly Cessna 182 Built RTF Minus Radio and battery CHEVYMAN(67) Aircraft - Electric - Airplanes (FS/W) 0 May 29, 2006 03:03 AM
Hey All "Ultrafly Cessna 182 Guys! Help please... 2MuchAir Electric Plane Talk 4 Nov 26, 2005 10:56 AM
Ultrafly Cessna 182 Ralph A. D'Amelio Parkflyers 7 Aug 30, 2004 05:52 PM
New UltraFly Cessna 182 available now Basketcase Parkflyers 2 Aug 22, 2004 10:43 PM
Question Just bought a Terry - Motor/Battery help please. Fingerpicker Foamies (Kits) 6 Jul 18, 2004 11:19 AM
