Old Dec 09, 2004, 01:21 PM
Tregurtha1013 is offline
Find More Posts by Tregurtha1013
Its only a model.
Tregurtha1013's Avatar
United States, MI, Clinton Township
Joined Nov 2004
Ballast Tank Pumps
Any of you guys built a large model with ballast tanks? If so what did you use to pump water in and out. My present plan is to use these bilge pumps for boats, one in and one out pump. Has anyone found an affordable solution to where you only need one pump?
SBT
Tregurtha1013 is offline Find More Posts by Tregurtha1013
Old Dec 09, 2004, 03:57 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
I've been thinking about this one for a while, as I eventually plan on building a laker.
I was considering a servo-controlled flapper valve on the bottom to let water in (no pump) and a single pump to unload the ballast tank. A micro-switch to control the the pump could be activated when the valve is closed.
RGinCanada is offline Find More Posts by RGinCanada
Old Dec 09, 2004, 04:12 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
You could try the SubTech ABP Ballast Pump with their Tee valve and the RS-5 Electronic Reversing Switch . Both are available from Mikes Sub Works . You could also try some of the vendors listed with the SubCommittee.
CG Bob is offline Find More Posts by CG Bob
Old Dec 10, 2004, 05:27 AM
afc is offline
afc
Find More Posts by afc
afc
Massachusetts, USA
Joined Jun 2004
RG,
That is a nice idea. I think that if the flapper was located on the bottom of the hull, you would need a pretty strong servo to open the valve as I assume it would have to overcome water's displacement pressure against the hull. The deeper the draft of the hull, the greater the pressure.
regards,
Albert
afc is offline Find More Posts by afc
Old Dec 10, 2004, 06:19 AM
OhioMike is offline
Find More Posts by OhioMike
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
Go to the Sonictronics web site and check out their Mark X fuel pumps. they have 2 models that differ only in voltage. Anywhere from 4.8volts to 12volts. They have the Super Mark X pumps but i dont think they would be of any benefit to us. Basically these were suggested to me for submarine model ballast tank pumps but these reportedly wont allow water to siphon back the pump to your holding tank after their shut off. I bought one at a LHS the other day for $17.00, but havent had any means yet to test it. Their cheaper than most pumps and the info i have recieved from them was that if they go bad, send it to them and a new one is in the mail! Hope this helps.
OhioMike is offline Find More Posts by OhioMike
Old Dec 10, 2004, 07:29 AM
Its only a model.
Joined Nov 2004
Thanks for those guys. I've e-mailed about that APB pump and the Mark X fuel pumps. Need to find out how much water they move as the Tregurtha's tanks are quite large.
Link Video link to dual syringe ballast tank CarreraGTSCS Submarines 10 Jan 27, 2007 10:39 PM
Piston type ballast tank question CarreraGTSCS Submarines 21 Oct 29, 2005 02:06 AM
ballast tank and blow system Netminder321 Submarines 3 Jun 07, 2004 10:01 AM
